| Spinning Vortec SC Took out my SC belt today. I was wondering how hard it is to spin the blower by hand. How much rsistance is the blower suppose to have? I can spin it by hand by turning the pulley BOLT. After I let it go, it will free spin about 1/4 of a turn then stop. It certainly not like my old turbo, where spinning the impler will free spin forever. Is that about right?
__________________ 97 M3/4: 307+ RWHP SAE Dinan SC 6 PSI RMS Aftercooler AA Turbo Clutch AA LTW Flywheel Supersprint Exhaust AA Track Pipe Dinan Suspension E46 M3 RSM AA Strut bars (F&R) XBrace BMP Rear Camber Correcting Arm IFG A5 Forged LTW wheels on Pilot PS2 CF Hood And a whole bunch of forgotten and replaced upgraded items. |
| Yes, but a SC does not have to spin as fast to create pressure. So by spinning it by hand, you could be creating pressure in the intake manifold which would cause resistance. Just speaking theoretically, I myself have no SC experience, so I could be completely wrong. |
| Gerry. turning the bolt by hand? And wouldn't it be easier to spin by turning the pulley? I never just spun the pulley freewheel style, but If I change my pulley and am tightening the nut, if the belt is not real tight, the pulley spins and does not let me tighten the bolt. I believe with the belt off, I can turn the pulley with a little resistance, but it will not rotate very far, probaly as you say a quarter turn. There is defintely some drag to the rotation, but your hand should be able to rotate the pulley, even if a little. Another example Gerry, when I change my pulley, and have it off, I can rotate the shaft of the blower so the keyway is at 12 o clock, so it is easier to line the pulley back onto the shaft. If I use my thumb and index finger, with ease I can rotate the shaft. It only rotates the blower the amount you turn it and it stops dead. I believe you are describing NORMAL blower resistance, it does not freewheel, like your old TURBO. Hope that helps you And nice hearing from you and being able to respond, I hope all is well with you and your car!! ![]() Last edited by Marc1119 : 11-01-2004 at 03:40 AM. |
| the blower will not spin freely because it is gear driven inside the housing, that is why it seems hard to spin, although you should at least be able to spin it with your hand with relative ease, it just will not spin freely |
| I dont know twin screw superchargers, i spend most all my time working with centrifugal ones and turbos at my shop. But from what I have learned about twin screws, they seem quite good. |
| well if he is the grand daddy of FI, then maybe he might know a thing or two about mounting a Non-VANOS head to an S50 block for forced induction crazyness, or should i just stick to the VANOS head? |
