Old 10-31-2004, 01:09 AM
///Mummmmm's Avatar
Entrepreneur
Rides:E36
///Mummmmm is a New Registered Member
What's exactily in a turbo kit?
So, I've have begun research on what may extreemly be my next big project. I own a 325is with 90K on the clock, and am thinking of attempting a custom turbo setup. I wonder if you may be able to tell me what items are generally in a turbo kit... ie... turbo, waste-gate, manifold... ect. A list of what ever items you may have needed would be a wonderful help. (brands and types would be great as well)
Thanks
Old 10-31-2004, 02:16 AM
orijinal_poser's Avatar
Freude am Fahren
Rides:gay car
orijinal_poser is a New Registered Member
shit, theres alot to list........
basically your turbo (no shit), wastegate, turbo exhaust manifold, intercooler, fuel injectors, all kinds of piping, hoses, clamps; some kits include a downpipe, turbo timers & blow off valves. also, braided lines for coolant and oil to & from turbo. i know i'm missing some shit, anyone wanna pitch in??
National Capital Chapter BMW CCA #375530
Old 10-31-2004, 06:40 AM
Rides:95 bmw
5speed300 is a New Registered Member
If your looking for a shop to do the setup for you, I would highly recomend going to Eurospeed Performance and talking to them about it. I went there yesterday to get some parts and the owners know quite a bit about tuning bmw's. They've already done a custom turbo setup on a 328, but I'll let him speak for himself since I dont know the details.
Old 11-01-2004, 07:17 PM
///Mummmmm's Avatar
Entrepreneur
Rides:E36
Thanks for the Info. I'll probabily be working with Alex (eurospeed) on the entire porject anyway.
Old 11-02-2004, 04:10 PM
Rides:1995 BMW M3
Bassmaster is a New Registered Member
Custom Turbo? In Durham NC
Http://members.cardomain.com/bassmasterM3
1995 M3 Custom Turbo
Old 11-02-2004, 06:03 PM
Freude am Fahren
Rides:gay car
ah, bassmaster, your custom turbo setup is amazing. i'm trying to make my own kit.
Old 11-02-2004, 07:36 PM
WCM3's Avatar
RMS-STG2
Rides:1995 BMW M3
WCM3 is a Permit Holder
see though bassmasters custom setup makes me upset. It shows everything that you can buy...but the last page of his article is how he blew up his engine. Well, hell i'm not gonna follow everything u just told me if its gonna cause my engine to blow up...haha
Old 11-02-2004, 07:45 PM
03E39LemansBlue's Avatar
Unicycle Passenger
Rides:'03 M5
03E39LemansBlue is a New Registered Member
Was that strictly the result of a too lean condition at WOT Bassmaster? And if so, why didn't it exhibit itself at lower speeds (at whatever RPM the engine was at 140mph)?
Old 11-02-2004, 08:15 PM
Rides:1995 BMW M3
The hardware doesnt change you can make your kit identical...the tuning does.
Remember With the TEC III you can adjust every perimeter of your vehicles engine function. Whether that be good or bad.
The night before about 3am I had been out playing with the timing on the tec.. Avg timing in the boosted Zones is 15-22 degrees..Just on a whim I decided to bump the timing up 30 degree across the whole MAP. You can adjust this individually are all at once. Well the next Day about 9am I went over a friend of mines just to let him check out the ride...We went for a ride letting him drive...He asked could he open it up on the hwy. I said okay...well he kicked it up to 140 mph then came to a stop on the off ramp...The car cut off..the coolant hose had blown off. The coolant had leaked out...the car was running hot. We'll we reconnected the hose..put some water in..and started the car..It was missing like running on 4-5 cylinders. I new instantly that the piston was scarred...and at that time remembered about turning the timing up.
So it was just a stupid error on my part...it wasnt a lean conditon I was only running 5psi of boost. The overall timimg of 30 degrees plus 19 degree base led to the melted # 1 piston At the sustained high rpm.
So this actually has nothing to do with building the turbo kit...it was a tuning error using the TEC III and I knew better just forgot.
W'ell now I've become much better using the tec. The rebuild cost me 1800.00 And I've got my timing right, Airfuel right and enjoy the reliable 10-14 psi of boost that I run regularly.
Here is a data log of my latest tuning Air/fuel ratio. @ about 17 degrees of timing. Air fuel is almost dead on.. a little rich..I've found that my car likes an A/R ratio about 11.5 -11.8 when running over 12psi. (Pump 93 octane)
Old 11-02-2004, 08:25 PM
Rides:1995 BMW M3
If you dont know how to dial in a standalone using a wide band..Just do the hardware part....and a custom chip.
Old 11-02-2004, 08:28 PM
WCM3's Avatar
RMS-STG2
Rides:1995 BMW M3
well i would def get a custom chip, but a tec III would be nice...
Old 11-02-2004, 08:47 PM
Rides:1995 BMW M3
The Tec III is very nice Tons of adjustments can be made...but its only as good as the tuner.
Dado had a custom chip and now he"s switch to the TecIII and really likes it...Im not sure how much he plays with though?
If you're a set and for get kind of guy the custom chips might be the ticket...only problem is they cost.
Old 11-02-2004, 08:51 PM
scottycs's Avatar
Custom Turbo 328
Rides:e28, e30, e36, e39
I would like to clarify the facts. They offer REMOTE tuning for AA, and do not actually do in house BMW tuning. Also dan's 328, well I wouldnt claim that to have been tuned, or even close to being tuned. He is not even driving it currently.
-Chris
Old 11-03-2004, 06:04 AM
WCM3's Avatar
RMS-STG2
Rides:1995 BMW M3
Bassmaster i was wondering how much did you dyno with your 60-1 turbo setup? And how much did everything actually cost in the end (without engine rebuild), i kno that you were trying to stay under $7,000. Thanks -Mike
Old 11-03-2004, 07:51 AM
Rides:1995 BMW M3
I've have not dynoed yet. I plan on dynoing soon..I just wanted to get my air fuel dial in perfect. (as you can see Im close)....so I dont have to waste the dyno time doing that. I think I've spent about 7700.00, 2800.00 of that is the Tec III and wide band.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
