Old 10-29-2004, 02:49 PM
Turbo Power Junky
Rides:An AA turbo Z3 tuned by NickG
DakarDave is a New Registered Member
dynoed my car @ icsperformance..
and as promised here are my results..
we only reved to 6500RPM... and we still need a bit more tuning.. but the power numbers are pretty good..
Here's the specs:
Redline: 6500RPM
boost: 10.3 psi
gas: 93 octane gas
temp: 72.10 F
Specs: 1998 Z3 2.8, stock engine, AA trackpipe, M50 manifold, RMS tuning (in progress), euro 3.5" HFM...
And here's the dyno... the first few runs, ICSPerformance had issues getting proper RPM readings... So, the car was heat soaked.. the best run was yielded: ~325rwhp, ~288rwtq with a redline of 6500RPM.
NEXT STEPS: 7000RPM rev limit, and we're going to try to get about 11lbs of boost...
Dakar Yellow Z3 - 411rwhp/447rwtq SAE Engine Bay | Side Profile | Side Profile | UUC/Wilwood | Dyno | European Car
Power: AA Stage II Turbo tuned by NickG:alright, .140" headgasket, ARP head studs, Porsche HFM, M50 manifold, Custom ICS 3" turbo exhaust, walbro 255 fp
Driveline: 2.93 LSD, UUC Stage 2 LTW Flywheel/Spec Stage II Clutch, Whalen Shift Machine
Suspension & Handling: TC Kline True Match Coilovers 450f/500r, Motorforce/Vorshlag adjustable camber plates, Dinan Stage II sway bars, Powerflex bushings all around, IE camber/toe kit, redline fluids, UUC/Willwood BBK, Slotted E46M3 Rotors, SS Brake Lines, Strong Strut trilogy, IE Subframe Bushings
Misc: ACS Type II racing wheels, ACS Pedal Kit, Racelogic Traction Control, Blitz SBCiD Boost controller, Zeitronix ZT2 with remote digital display (Lambda, AFR, EGT, Boost), Sound System upgrades, Gramin Nuvi 360 GPS, Indash DVD system, and leatherZ rollhoop covers, armrest, S54 radiator upgrade and more!
Old 10-29-2004, 03:01 PM
nice numbers for the 2.8!
Old 10-29-2004, 03:03 PM
Turbo Power Junky
the best part is the tuning isn't done yet.. I think with a 7000 RPM redline and some more tuning.. we could see ~350rwhp/290rwtq
Old 10-29-2004, 03:14 PM
orijinal_poser's Avatar
Freude am Fahren
Rides:gay car
orijinal_poser is a New Registered Member
damn, that is awesome man. speaking of z3's look what i saw the other night, z3 coupe
National Capital Chapter BMW CCA #375530
Old 10-29-2004, 04:08 PM
Marc1119
Guest
Posts: n/a
The dyno performed read Daves power readings up till 6476 RPM.
Although the peak torque number will not change on this dynosheet(it may with some clean up tuning on the way) the peak RWHP will change taking the readings until 6800 -7000 RPM.
My calculations say if the torque tapers off the same for the rest of the graph until 6800 or 7000 RPm, that dyno sheet will show around 335 RWHP to 6800 RPM and 345 RWHP till 7000 RPM.
With some more tuning and a 6800 or 7000 RPM redline, I see 350 or over RWHP with 290+ RWT, not bad from a 2.8 and 10.3 lb boost!!!
I told you your car rips Dave!!
Old 10-29-2004, 05:00 PM
Banned
Rides:BMW S/C 540i 6 spd.'95 and BMW 535i 5 spd.'90
Jimmyz2 is a New Registered Member
Congrate's to DakarDave another ICS(George&Brian) success story.I wanna live above George's shop.
Old 10-29-2004, 05:02 PM
Marc1119
Guest
Posts: n/a
Hey Jimmy, what about congrats to Osh and Marco? We had a big hand in this success story.
Old 10-29-2004, 05:27 PM
Banned
....Opps,my bad!Cheers to Marco and Osh!
Old 10-29-2004, 05:28 PM
Marc1119
Guest
Posts: n/a
Old 10-29-2004, 05:30 PM
Turbo Power Junky
You bet.. George and the guys at ICSPerformances are great.. but Osh and Marco are the primaries in this stage of the project.
Old 10-29-2004, 05:40 PM
Fixer
Rides:98 M3
ertelj is a New Registered Member
Any idea where ignition timing and peak cylinder pressures are?
Old 10-29-2004, 05:45 PM
Marc1119
Guest
Posts: n/a
The timing varies a little car to car in final phase of tuning,and will remain part of RMS's formula for "more power" proprietary information.
Old 10-29-2004, 05:47 PM
Fixer
Rides:98 M3
Which sensor tells the ECU the boost pressure, I'm familiar with every square inch of that intake system.
Old 10-29-2004, 05:57 PM
Fixer
Rides:98 M3
Besides compression ratio, ignition timing controls peak cylinder pressure for a given level of boost and temp. I'm just curious how peak cylinder pressures compare to a stock engine using your software which controls timing under these elevated boost levels. Not doubting just curious.
Old 10-29-2004, 06:11 PM
Marc1119
Guest
Posts: n/a
I deleted what I wrote because I reread your question and misunderstood what you were asking.
The person to answer your question is Phoenix2005 which is Osh , owner of RMS. I cannot speak for him, he is the tuner extraordinaire.
I am not affiliated financially with RMS, just a friend of Osh's and a BOOST JUNKY with a few setups under my belt.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
