Old 10-27-2004, 04:30 PM
Marc1119
Guest
Posts: n/a
My AA trackpipe dyno results on FI!!!
For anyone interested, I added an AA trackpipe to my 1997 M3 with NO other changes since the last dyno. My last dyno yielded 400.5 RWHP and 311 RWT, done on 08-17-04,75 degree day.
Today the temperature was around 62 degrees on my temp gauge in my car.
Today my dyno numbers were on 2 runs done 2 minutes apart,
415 RWHP 317 RWT run 1 and 409 RWHP 319 RWT run 2
These numbers were obtained with 1.5 gallons of 110 octane added to exactly 8 gallons of 93 octane gas.I probaly had about 1 gallon of gas in the car when I started or more. Having said that my net octane was around 95 octane. The reason I say this is because the day before I tested the car on the same dyno with ONLY 93 octane gas.
The reason I wanted to TRY the trackpipe was to eliminate the cats for RACE GAS, more flow, and eliminate 2 of the 4 O2 sensors
This is what I learned.On MY car up to 6300 RPM the race gas did ZERO. After 6300- 7000 it kept my car from dropping 10 lb/ft torque across 6300-7000 RPM. I would also like to point out the single fan at the dyno SUCKED!!
So perhaps the gas did nothing after 6300 and the lack of airflow pulled back my timing, which is entirely possible.
Now today, after adding 1.5 gallons EXACTLY of 110 octane and bringing one rug fan from the company I run (which wasn't enough either, but aliitle better than yesterday)I gained 15 RWHP and 6 RWT peak on one run and 9 RWHP and 8 RWT on the other run PEAK.
Here are the gains averaged between the 2 runs today compared to my last dyno of 400.5 RWHP
RPM RWHP RWT
3500 +10 +10
4000 + 2 +8
4500 + 5 +10
5000 + 2 +2
5500 +10 +10
6000 +10 +9
6500 + 8 +7
7000 +9,+15 +10
Every RPM today was higher than every RPM on my last run by the plus amount above.
The seat of the pants feel of the track pipe on an 11 lb boosted FI car was great. I really thought the numbers would have been higher, by the feel, by I am still very happy.
The torque and HP gains thruout the powerband and ESPECIALLY from 5500-7000 were amazing!!!
I highly recommend this mod on a FI car.Hope this helps some of you wondering and thinking about this mod.
Note, my car has 32k miles on it and the engine is 100% completly stock inside.The valve cover has NEVER been off my car or the oil pan.
Old 10-27-2004, 05:36 PM
Rides:01' 330i
Baer is a New Registered Member
Very nice Marco! Congrats
Old 10-27-2004, 06:14 PM
Turbo Power Junky
Rides:An AA turbo Z3 tuned by NickG
DakarDave is a New Registered Member
awesome numbers marco... your car keeps getting faster and faster!
Dakar Yellow Z3 - 411rwhp/447rwtq SAE Engine Bay | Side Profile | Side Profile | UUC/Wilwood | Dyno | European Car
Power: AA Stage II Turbo tuned by NickG:alright, .140" headgasket, ARP head studs, Porsche HFM, M50 manifold, Custom ICS 3" turbo exhaust, walbro 255 fp
Driveline: 2.93 LSD, UUC Stage 2 LTW Flywheel/Spec Stage II Clutch, Whalen Shift Machine
Suspension & Handling: TC Kline True Match Coilovers 450f/500r, Motorforce/Vorshlag adjustable camber plates, Dinan Stage II sway bars, Powerflex bushings all around, IE camber/toe kit, redline fluids, UUC/Willwood BBK, Slotted E46M3 Rotors, SS Brake Lines, Strong Strut trilogy, IE Subframe Bushings
Misc: ACS Type II racing wheels, ACS Pedal Kit, Racelogic Traction Control, Blitz SBCiD Boost controller, Zeitronix ZT2 with remote digital display (Lambda, AFR, EGT, Boost), Sound System upgrades, Gramin Nuvi 360 GPS, Indash DVD system, and leatherZ rollhoop covers, armrest, S54 radiator upgrade and more!
Old 10-27-2004, 06:20 PM
carstereopro's Avatar
Whos dyno was it. I'm interested in having mine run.
Marc, what part of Merrimac do you live in, I used to live on Bear Hill Road, off of 110.
Phil Chartier
Carstereopro
Old 10-27-2004, 07:40 PM
MCP
Rides:alpine white S/C e36
bemmerondubs is a New Registered Member
What other options are there for the track pipe...what do u think about supersprint?? . and is the AA really worth the money especially since i have the AA S/c and exhasut logic tells me that the AA track pipe would work best with my mods... and is having one custom made a good option and how much does something like that usually go for. Ive heard that the track pipe is one of the best mods for Fi cars cuz it frees up a boatload of horspower that the resonators were holding up andstuff
Old 10-27-2004, 08:19 PM
Rides:'96 M3 Turbo
///3oris is a New Registered Member
I told you it'd make power! Congrats We'll have to race again now to see the change
Boris
'96 Cosmos Black M3
Engine: Technique Tuning Stage 1 Turbo
348rwhp/342rwtq SAE @ 8psi (with stock cats and no other engine mods!) and AA Gen II Muffler. Drivetrain: Cosmos Black HM2's, SPEC Stage II Clutch, UUC SSK, UUC TME. Suspension: GC Coil-overs, GC RSMs, GC RTABs; H&R SB. Instrumentation: VDO Boost, VDO Oil Press, VDO Oil Temp, VDO Water Temp, Euro Gauge Cluster with Oil Temp, BMW Traffic Pro Navigation
TODO: EMC Diff Reinforcement Mod
Old 10-27-2004, 10:59 PM
Congrats man, time to update that signature
Old 10-28-2004, 11:48 AM
Banned
Rides:BMW S/C 540i 6 spd.'95 and BMW 535i 5 spd.'90
Jimmyz2 is a New Registered Member
Way to go Marco.Keep pushing that envelope!
Old 10-28-2004, 02:00 PM
469rwhp/353rwtq
Rides:e36 m3 & e46 325
m3jasper is a New Registered Member
Wink
congrats...have any other mods planned for the future? Or is this gonna b it?
Old 10-28-2004, 04:31 PM
Marc1119
Guest
Posts: n/a
Thanks!! IT IS NEVER OVER
Gotta couple more ideas, I think I gotta little power left to tap into to.
Old 10-28-2004, 04:42 PM
Banned
I think Marco could get 2 hp out of a dead squirrel lying on the side of the road.
Old 10-28-2004, 04:46 PM
Marc1119
Guest
Posts: n/a
Or waste some time and money trying, Jimmy!!!
I have a problem, I need counseling and rehabilitation. This car has a hold on me. All M3's do.
BTW Jimbob, would that be 2 flywheel HP or 2 RWHP out of that squirrel?
Old 10-28-2004, 05:03 PM
Rides:M3 e36 3L2 euro
MARCM3 is a New Registered Member
very good results
Old 10-28-2004, 05:06 PM
Marc1119
Guest
Posts: n/a
Thanks Marc from Paris!!! I am MARC with a "C" also.
Old 10-28-2004, 06:13 PM
Midnight Shark's Avatar
Will work for food
Rides:'02 Double DD, bye-bye M3 :(
Midnight Shark is a New Registered Member
nice numbers marco! Keep up the good work, don't be suprised if you see me knocking at your door!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
