| Power Options Advice please I have a '95 325is 5 speed with 144,000 miles. My goal is 350rwhp, what turbo kits can make this reliably, what do I need to make this on the M50, can i even make this on the M50.. etc. So far I've considered M3 drivetrain swap, turbo M50, and supercharged M50, please give me advice to reach my goals. I'm not exactly sure as to the budget yet, but for now, reply as if I had no budget, and you could splurge a little. I've really only found 2 turbo kits for the 2.5 litre, the AA stage 1.5 and this TSI Extreme Kit Please let me know what I should do as far as power goes, thanks in advance, Mike. |
| Money should not be an issue in your reply. I want 350rwhp, my question is, can the M50 make this? (assuming lower compression pistons, etc.) If it cannot, I have other plans that I will not discuss until they are done. ;-) |
| If I were in your position,I would without a doubt call Stimpe(twin-screw) and George or Brian at www.ICSPerformance.com |
| My car is for sale and I am somewhat local to you. http://forums.bimmerforums.com/forum...d.php?t=260234 Mike |
| Mike, Check your email, I got yours... I would certainly think that between George, and myself, there is little doubt we can reach your goals, and still with the 2.5 if that is what you want to do. The fundamental question will be whether you want to open up, and freshen, the 2.5, or put that money toward a larger motor. The 2.5 WILL do it for sure, just everyone will probably tell you to "go for the bigger motor". I just picked up a 1997 M3/4 yesterday, so I am going to "screw" that, and use it as my 3.2 car, while I plan to tweak my 2.5 car up to 350+ rwhp with the 2.5, just to do it. You are more than welcome to follow in my footsteps!!! ![]() Steve |
| yes, I definately want to open up the engine and refreshen and upgrade everything. What internals would you guys recommend, as I would have the engine built by a friend of mine? What cams for the twin-screw application also? (assuming, 15psi? 20?) Stimpee, I sent you another email, don't know if you got it yet. |
