Old 01-13-2002, 10:04 PM
Rides:'00 Accord V6 coupe SOLD, Hello E46 coupe!
GPV///M3 is a New Registered Member
Question Turbo Experts
Can anyone with a turbo kit on their car tell me where I could get a BOV, larger injectors, and where to get my ECU programed and tuned so that I can Boost an M3 about 5 psi. I have looked at the staged turbo kits that AA sells, but a local shop that I have come in contact with says that they can make me a custom turbo w/intercooler and piping for a lot less than what AA is charging. So all I would need now is the upgraded fuel system, a BOV, and maybe a new clutch.(with the exception of the turbo timer, boost controller, and other electronics) Also, do you need colder plugs and an AFC like in other cars? Can anyone help me out?? Also, how much will these items cost? I know an external wastegate will cost a Grip! Is there another option? IMPORTANT: What is the compression ratio on the e36 M3, and how high can you boost on stock internals??? Any information will be greatly appreciated. Thanx
-GPV
Old 01-14-2002, 12:07 AM
Rides:'98 BMW M3
There are alot of companies that sell BOV. HKS, Greddy, Etc.
I dont know where one can find proper size fuel injectors. Maybe from a Summit Racing Catalog?
ECU tuned/reprogrammed? Not sure who you will go to for that and you may end up using a air/fuel ratio piggy back computer or rising rate fuel pressure regulator unless you can pay lots of cash to have it dyno tuned properly (this can take days). Note that I have seen A/F ratio charts on SC engines with a rising rate fuel pressure regulator and its just way off so stay away from those.
I use one step colder spark plugs (NGK) on my turbocharged engine.
Having an external wastegate will yield better response and control of the exhaust flow and boost wont be erractic. It wont also interfere with the exhaust flow thats coming out of the turbine which can lead to more exhaust backpressure on the internal wastegate design. The only turbo that I know that doesnt use a wastegate is the Aerodyne turbochargers that MechTech uses.
The static compression ratio on a S50USB30 and S52B32 engine is 10.5:1
I can run 9psi (high) safely on stock internals with 91octane and water injection on. Some guy in Canada is running 10psi on stock internals but I do not know the octane rating in his area. A another member on the board has a MechTech turbo kit on his M3 sedan and is pushing out 11psi (high setting) but on 110 race fuel leaded on stock internals.
All in all, you may end up spending the same amount or more than an Active Autowerke TC kit. What kind of M3 do you have and what stage are you interested in.
Where in SoCA do you live?
Old 01-14-2002, 12:27 AM
yet another black M3
Rides:95 M3 Turbo, 96 M3, 97 M3, 95 Supra, 86 951
Region: USA - Rocky Mountains
Vader M3 is a New Registered Member
Jonny! What happened to you yesterday at the big Irvine meet?
There were other turbocharged cars there, but I didn't want to be the only AA one this time, . Can't leave me hangin' there buddy! Just kiddin'. Too bad you couldn't make it; I thought you were going.
95 BMW M3: T66 turbo, AEM EMS
96 BMW M3: near stock
97 BMW M3 sedan: near stock
95 Toyota Supra 6sp: SP71-GTS turbo, AEM EMS
86 Porsche 951: 60-1 turbo
Old 01-14-2002, 12:30 AM
Rides:'98 BMW M3
I forgot that you were going but I was up in Snow Summit taking snowboarding lessons.
Old 01-14-2002, 01:06 PM
I live in Bakersfield, but I met a guy who lives in Irvine who wants to put a custom T3 turbo kit on my car W/intercooler and piping for hella cheap, but I would still have to buy the upgraded fuel system, BOV, Timers, Boost Controller, wastegate, etc. I thought you had to reprogram your ECU when you put any type of forced induction. I know you have to for a supercharger. In all, the complete kit, with all the electronics, fuel system, and everything else should cost me around $5,000, IF I can get it hooked up the way I think I can, which is a couple thousand less than the AA kit. I don't wanna boost more than 5-6psi, so I would be looking at a Stage 1 if I went with AA. As far as the car that I own...I am currently in the process of looking for/buying an e36 ///M3, 95-99-what ever I can get the best deal on. But right now, I have about $4,500 that I am not putting on a down payment that is going toward either a turbo or a supercharger (turbo prefered) very soon after I get the car.
Old 01-14-2002, 01:19 PM
Rides:98 M3, 03M3
M3RACER is a New Registered Member
I know that you can use the injectors off the svt mustangs (like $350-400), but I don't remeber exactly which ones. For reprograming of the ECU trying getting with the guys at AA or maybe Jim Conforti can help you out if you can get a hold of him.
Old 01-14-2002, 01:50 PM
Rides:'98 BMW M3
Some companies that sell SC or TC kits dont even touch the engine mangement system or fuel injectors and just slap on a rising rate fuel pressure regualtor or an Air/fuel ratio controller. Really a no no to an OBD2 M3 if not tuned correctly.
I think a T3 turbo is way to small for a M3 engine. Are you sure it'll be safe and will not burn up exhaust valves? Who's also gonna make the turbo exhaust manifold and what is it made out of?
I dont think AA will just send you a chip for a custom turbo unless its in their hands on their facility. Same probably goes with Jim Conforti. This will become a liability issue here.
If anything since cost if a factor here, you should get a MechTech kit with the stage 2 upgrade.
Old 01-14-2002, 05:44 PM
How much is a MechTech kit, and where can I check them out??? Thanx
-GPV
Old 01-14-2002, 07:48 PM
Rides:95 Schnitzer 325is
alberto_mg is a New Registered Member
Unless you have more money than you know what to do with, you might consider a properly developed turbo kit like AA or MechTech.
I've turbo charged quite a few cars before with home made stuff and I can tell you that it can suck in the long run. Think of how much money you will spend rebuilding your motor if your turbo guy doesn't get the appropriate fuel mixture and the car detonates. Building a custom chip isn't easy either. Neither is making a custom exhaust manifold or exhaust system. That is why already developed kits cost a lot of $$.
In the end you usually get what you pay for...
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
