Old 10-15-2004, 10:04 PM
Resident homo
Rides:'95 M3
Le Mo de Ho is a New Registered Member
Remote mount turbo
After seeing an article in car-craft magazine, I've been researching the concept of remote mount turbocharging and I have to say the more I read about it the more I like it. Here is what it looks like on an f-body http://ststurbo.com/inc/iview/461?idx=5&p=1581 check out www.ststurbo.com and read it ALL. There are pics, perf. #'s, and videos of all the vehicles they currently have kits for.
One thing they mentioned is that they use some kind of special turbo and claim that it is designed to run in the rear of a vehicle and would perform poorly if mounted in the front, just as a conventional front mount would perform poorly if mounted in the rear. What could be done to these turbo's (Garrett) in order to make it suitable for rear placement? Is that just a crock of sh!t and any turbo would work?
It would be incredibly easy to build one of these kits for our cars, the only thing stopping me from doing it is sourcing the "special" turbo.
Pic from AKA rally 2k4
New York to Los Angeles....6 days 160mph
Old 10-15-2004, 11:17 PM
Yop Yop is offline
hmmm...?
Rides:N/A
Yop is a New Registered Member
all i can say, thats gonna be really REALLY expensive the first time you bottom out
Old 10-19-2004, 03:30 PM
BeRzErKaS's Avatar
Mobile Mammographer
Rides:'94 325is
BeRzErKaS is a New Registered Member
yah, or hit a puddle!
I sure hope they don't plan to end the turbo intake there.
Old 10-20-2004, 12:05 AM
Jessdsm's Avatar
Rides:92 Eclipse Turbo
Jessdsm is a New Registered Member
Would that not cause some boost lag problems?
Old 10-20-2004, 03:30 AM
BGN's Avatar
BGN BGN is offline
1990 E34 535i
Rides:BMW, E34 535i,1990
BGN is a New Registered Member
read the info in the linked site, it answers all of these questions
Old 10-20-2004, 07:57 AM
Yop Yop is offline
hmmm...?
Rides:N/A
i read most of the info, but if you bottom out still, the turbo is gonna get messed up, and especially with how low most bimmers ride, they dont ride as high as the avg domestic car
Old 10-20-2004, 09:38 AM
doesn't seem very practical especially with the intake down there.
Old 10-20-2004, 10:03 AM
BGN's Avatar
BGN BGN is offline
1990 E34 535i
"Ground clearance hasn't been a problem as all of the kit sits higher than the stock equipment. The lowest areas are near the wheels which give it added clearance going over bumps. We've installed the system on several lowered LS1s with no problems."
Copied directly from website.
Also for the other two questions:
"With the turbo so far back, don't you get a lot of turbo lag?
No, our turbochargers are sized to operate at this remote location. Just like any turbocharger, once the turbo is up to temperature and in the rpm range for which it was designed to operate. The boost comes on hard and fast. All of our systems will produce full boost below 3000 rpm.
If you were to take a conventional turbo and place it at the rear, you would have lots of lag and consequently, our turbo wouldn't work properly if mounted up front."
"Doesn't water get into your engine with the filter mounted down low?
No, even under very wet conditions the filter sheds most all water. Every kit includes a K&N PreCharger which is a "sock" that protects the filter under very dusty or wet conditions. The only thing you don't want to do is completely submerge the filter. This would draw water through the filter and into the intake tubing. For most vehicles that would mean you would have water coming in your doors before you'd have a problem with the turbo's air filter."
Old 10-20-2004, 10:06 AM
BGN's Avatar
BGN BGN is offline
1990 E34 535i
Dado, what problems do you see with the intake being low in the back?
I think as long as your not doing any off roading (which I don't think anyone does with a bimmer ) it would be fine. I have a Buick Grand National and my air filter mounts low to the ground and I have never had a problem. Just my opinion.
Old 10-20-2004, 10:08 AM
BGN's Avatar
BGN BGN is offline
1990 E34 535i
Yop, how in the hell did you end up with over 2 billion posts? Been on this board for like 50 years?
Old 10-20-2004, 10:24 AM
is your intake in the front of the car or right behind the tire receiving all the water splash?
Old 10-20-2004, 10:27 AM
BGN's Avatar
BGN BGN is offline
1990 E34 535i
It's right in front of the left front tire. Still gets spray from the tire, but the filter faces straight down so the water just runs right off. Even if it does ingest a minute amount of water, it should not hurt anything as I used to run a water injection kit with no problems.
Old 10-21-2004, 12:46 AM
GodSpd's Avatar
^faster than light
Rides:1992 325i
GodSpd is a New Registered Member
I would like to know more about where I can buy one of these "special" turbos.
I plan on doing a little engine swap in my mini and adding a turbo and this would be an awesome solution for it, the engine bay is so damn small but if I could mount the turbo in the back, even in the trunk with a scoop out the side for the intake and cooling that would be awesome!
Old 10-21-2004, 12:38 PM
BGN's Avatar
BGN BGN is offline
1990 E34 535i
The only thing special about the turbo is the sizing of the exhaust turbine and compressor. That is the only thing possible. I beleive it is just a regular turbo with a more efficient exhaust turbine to compensate for the lack of pressure and heat that far back in the exhaust.
Anyone else have any other possible ideas?
Old 10-21-2004, 12:41 PM
BGN's Avatar
BGN BGN is offline
1990 E34 535i
BTW, GodSpd, where in GE are you?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
