| Did you put anti-seeze on there? It also could be that it just picked it up from your last spark plugs, if I am correct you change them hella late like I did. Khoa
__________________ ![]() Got Brakes? |
| Seedster... did you install the kit yourself or did you have a shop do it? If you had a shop do it which one? I am in LA and have a kit but have not installed it yet. Also did you do a compression test before the install? |
| Seed installed it himself and I can say, it looks really stealth and very clean. When he popped his hood, I couldn't tell where he put everything. Most stuff in his hood looked OEM.khoa
| When I talked to him, he said the install was medium, but then again Seed rips his car apart and puts it back together. Its not no one day job where you can put an intake in. Don't take this the wrong way, he just took about two days or so to do the whole install. How do I know all this info, that foo is in my class. Khoa
| None of our cars are, you might see a white truck in service yard but that's it. Khoa
__________________ ![]() Got Brakes? Last edited by Khoalty : 01-10-2002 at 11:52 PM. |
| Re: Just pulled my spark plus (*post-NOS-install* info) Quote:
How long after the last nitrous pass did you wait till you checked the plugs. Your car could be running rich while on a nitrous pass, but if you drive around then the normal driving could clean the plug off. That would explain why the the plugs are black around the threads. In our mustang, we make a nitrous pass, and once I cross the finish line, I shut the car off, and coast around on the return road to a safe place to stop, then I get out and pull plugs to check them. That way there on contamination from driving around the pits. If you could find a place where you can make a pass, then shut the car off, and then pull over and check the plugs, that would be the best way to tell what the car is doing under a nitrous load. Quote:
I've been running nitrous on different cars for years, so if you have any questions, just ask. Scott
__________________ 94 M-Technic |
| an NOS dry kit of course it will look stealth only things to hide pretty much are the solenoids and where it feeds into the intake...its not a hard isntall to do yourself, and if i had over 80k miles, i would have gotten a compression check to be safe
__________________ Stay tuned for my project car's advancement .... |
| Re: an NOS dry kit Quote:
__________________ saeed ~333 |
| Hey, seedseter, I'm pretty close to campus too. It's about a 10 minute walk down Regents Rd to get to the regent lot bus stop, then 10 more min to the price center!!! -DanB |
