Old 03-10-2004, 05:34 PM
Rides:1992 e36 325i
Stricklybmw is a New Registered Member
how did you blow your motor
i have a 325i e36 and at the monmet i'm running 7psi on stock internals and stock head gasket. i want to know how you guys know your motors where about to blow or how did you blow them.
what are the signs of a blowen headgasket
Old 03-10-2004, 08:22 PM
RAiMA's Avatar
Supercharged Addict
Rides:S/C'd RT 318ti S4
RAiMA is a New Registered Member
Recently blew mine @ 261rwhp on the stock factory gasket from the M44 1.9L while dynoing the car. Looking to uprate the gasket now.
Old 03-11-2004, 04:20 AM
Rides:1992 e36 325i
what happened to the motor dose it have alot of damage. did it start smoking or just spiting coolent out from the head gasket
Old 03-11-2004, 12:40 PM
RAiMA's Avatar
Supercharged Addict
The edge of the gasket blew right out and ripped apart at cylinder 4. 3 of the spark plugs got water on them, 2 of them shattered from thermal shock. Only got one minor scratch mark on one of the bores from the broken porcelin from the spark plug. Nothing serious. Compression tests came up all fine.
There wasn't much of a warning, it all happened too quickly when we were doing fuel corrections @ 7200 rpms.
Old 03-11-2004, 04:04 PM
Rides:1992 e36 325i
what are you going to do. think headgasket or fully built motor.
I want to do a think headgasket on my motor. but where do i get it from????
also if you put a think gasket like the one aa has what happens to the timing belt dosen't it have to be longer or dose it come with different gides. or has anyone replace the stock pistons with low compersion piston but still use stock crank and rods to save money.
Old 03-11-2004, 04:21 PM
RAiMA's Avatar
Supercharged Addict
We've just put another factory HG in to get the car going again and dropped the rpm rev limit down to 6800. Went on the track a few days after and all is fine. We're looking for a stronger HG in the mean time.
As for pistons, we have lowered the stock compression. There was no need to change the crank at all, as we weren't stroking the engine.
Old 03-11-2004, 11:10 PM
Scho's Avatar
Moderator
Rides:1999 White M3
12 gauge Shotgun!
Old 03-12-2004, 04:26 AM
Rides:1992 e36 325i
what motor is in your car now. also what other mods can i do to add power such as bolt on's
Old 03-17-2004, 06:42 AM
Rides:BMW, 318ti, 1996
Touring E36 is a New Registered Member
My rear main oil seal decided to take a hike and use my oil as road decoration. Needless to say no oil makes for one very unhappy main bearing on the crank shaft. Ba Blam!
BMW 318Ti
Split Ten 17" M motorsport wheels
Big plans for the future
Old 03-17-2004, 07:29 PM
RAiMA's Avatar
Supercharged Addict
Not sure if the question was directed to me or Scho.
We're still using the same motor. We had a track day the next week, so we just quickly put it back together with another factory head gasket, lowered the max rpm and lowered the boost a little. Did a compression test and all is good.
We're currently searching for a stronger head gaset.
Old 03-28-2004, 09:11 PM
old school
Rides:E30 325 & ///M
drunknmunky02 is a New Registered Member
BMP Design Makes some headgaskets. Never used them, but they have the stuff you woudl need without going to copper. Kevlar with cutting rings.BMP Design
- Alex Shiroma
E30 M3 [Awaiting S50]
E30 325
Old 03-28-2004, 10:52 PM
RAiMA's Avatar
Supercharged Addict
Thanks for that. We were originally going to try and get something from them, but apparently they have a supply issue or just aren't keen on supplying them anymore.
We've found another solution, just waiting for them to deliver.
in the mean time, here are some pics of my car I took while doing some maintenance on Saturday
and here's one at Bathurst yesterday (Sunday)
Enjoy!
Old 03-29-2004, 06:34 AM
Member
Rides:2004 montero sport
Fire_OpTiKz is a New Registered Member
damn ....
Old 03-31-2004, 12:12 AM
Banned
Rides:modded 95 civic hatchback
mydumpthatch is a New Registered Member
just use a fat bead of silicone
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 5
