Originally posted by poohlvhun Can you please enlighten me on this?
So how does the power curve differ than that of a NA car?
I thought sc gives a linear curve while turbos tend to spike in mid rpms. I have a picture in my mind that has a sc power curve similar to that of a NA but just moved up about 100hp. Is that not correct?
cheers. |
You're somewhat right. The centrifugal SC curve will look virtually identical to the stock motor's until about 4000RPMs, where it gradually rises to about 100HP above the stock motor's peak HP (for a 2.5-3.0 L 6 pot). A screwtype SC and turbo will have completely different power curves, compared to a centrifugal SC. Since the screwtype hits max boost by 2000 RPMs, the entire power curve will shift with torque seeing the largest gains in the lower powerband. A turbo curve will be similiar to a screwtype...depending on what type of compressor is used. Obviously a T-88 will produce nothing below 4000 RPMs, and then see a huge spike in torque/HP afterwards.
Boost Chart of Screwtype SC
