Old 02-16-2004, 06:34 PM
menny30's Avatar
E36 325is Owner
Rides:bmw, e36 325is, 92
menny30 is a New Registered Member
turbo or supercharger
which is better and which produces more power for the price???
Menny
Old 02-16-2004, 06:35 PM
Matthew's Avatar
Rides:'99 M3 '03 S2000
Matthew is a New Registered Member
yes
Old 02-16-2004, 06:36 PM
Chris's Avatar
Rides:2000 BMW M5
Chris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master License
Internal induction
Old 02-16-2004, 06:40 PM
Matthew's Avatar
http://www.dtmpower.net/forum/forumd...?s=&forumid=51
p.s.
Old 02-16-2004, 06:42 PM
DTM Alkoholickz
Rides:1998 Bright Freakin' Red M3.
mitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master Licensemitchelrl has achieved their Master License
http://www.aas.com.sg/features/archive/f11012.htm
read this and enlightenment you shall have!
BBS RC's | TC Kline S/A 500f 600r | Dinan Gen 2 Exhaust | X-Brace | Front/Rear Dinan CF Strut Braces | UUC Black TME's | ZKW's w/ Prolumen 6000k HID's | 3.5" Intake | Alpine 7894 | One good traffic lawyer |
Old 02-16-2004, 09:11 PM
Scho's Avatar
Moderator
Rides:1999 White M3
---> FI
Old 02-16-2004, 10:54 PM
Bad Bimr's Avatar
Custom Bimr
Rides:1995 ///M3 (TS Ready)
Bad Bimr is a New Registered Member
Re: turbo or supercharger
Which produces more power for the price?
Well both can produce more power then your stock motor can take. Both can make your motor a time-bomb.
You can get so-much power out of a stock engine. Both a SC and a Turbo can give you that power.
A turbo makes more torque but has lag. A turbo has very un-linear power delivery. No boost, no power, lag, lag, lag, full boost, full power. It is like an on and off switch with a slight delay. Very hard to control (especialy on a race track or around a corner) but real nice to "show off".
A Centrifigal SC has no lag but produces boost as RPM rises it has less TQ but a more linear power curve. This linear power curve will save you money in the long run. Why because it won't destroy the clutch, diff, tranny, motor mounts, driveshaft, etc.
Now a Positive Displacement SC. This is the "Bad Boy". Full boost at the touch of the throttle. It makes a small engine feel like a bigger engine. It is like adding displacement to your engine. Your 6 cyl will feel like a big V-8. Instant boost, linear power curve, big torque at low low low RPM. Ohh, these are the ones OEM's use in their production cars (Benz, GM, Ford) and also the ones you see at the Drag Strip in those top fuel dragsters. And yes there is a kit out for the BMW.
Bill P
Bill P
CLICK ON A PICTURE TO ENLARGE
Click Here For Stuff For Sale
Old 02-18-2004, 10:00 PM
Douchebag
Rides:97 m3
bigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master License
Dear bill whos sc kit is for bmw and how much?
also i read the posted website and they made supercharger sound really good, although other sources say semi-badthings about them.
Is the main purpose of turbo, major hp? with a uspercharger the website linked above says you only loose 2-5hp, that sound very low, wouldn't you agree?
I am in the Fi market, but told myself to go turbo so that i can always up the boost to gain more and more power, but a supercharger is starting to tempt me
Old 02-18-2004, 10:21 PM
Bad Bimr's Avatar
Custom Bimr
It's very hard to decide. SC or Turbo. With the Centrifigal style SC you install it and forget it. It does it's job.
With a turbo you will have more low end torque but it takes time to get all the bugs out. Once they are out the turbo is good. Most people don't have nor want to take the time to get the bugs out of a system. Also the turbo ties in to the engines oil system and heats the oil up. Engine temps can run higher and under-hood temp is very high.
As for uping the boost on a turbo to make more power. You can do the same with a SC buy changing the pulley size. But a stock BMW engine with 10.5:1 comp ratio will not live long at more then 6-8 psi.
My kit is an ERT Kit designed for the OBDI 6 M50 aqnd S50 engine. It will fit later model cars with minor changes (SC to TB Pipe is diff). If you buy a SC kit stay away from RMS and ESS. Buy either Dinan or ERT.
Bill P
Bill P
Old 02-19-2004, 07:17 AM
menny30's Avatar
E36 325is Owner
thx for the info bill, where did u buy your sc kit from??? and around how much did it cost???
Menny
Old 02-19-2004, 02:11 PM
Bad Bimr's Avatar
Custom Bimr
I bought my kit from ERT directly. They did the install and tuning using Jim C Software and DME Editor.
If memory serves me right, I paid near $6K for it when I bough it.
It is for sale, make me an offer.
Bill P
Bill P
Old 02-24-2004, 07:57 PM
E36 Forever
Rides:bmw 325i 1992
josemg is a New Registered Member
I'll agree with Bill in some points. the SC will looks cleaner and you don't have to mess with fuel management and so forth, but about attaching oil supply an dreturn and heat up, it always get hot. Increasing hp in your engine will heat up the oil, the water and the gas also.
One of the benefits I'll see from turbo is that you can increase your boost in your wastegate without replacing any parts. Also you can change the desired boost if you have a boost controller from the cabin. If you are planning running with stock engine (200's psi of compression), I'll think you should move a to4 easily without any lag. I think you should not cross the 8-9 psi, so the response will be fast, faster than SC.
One of the points of centrifugal SC is the noise that emits during idle time. I have a friend with a mustang sc and it sounds like an old car with blown power steering and water pump. He had a Mustang Race Car also and he said that turbo response better than Supercharger. Another one is that if you want fast response with the supercharger, you have to go full throtle all the time, instead of turbo that response from as near as 1500-200 rpm.
If you want performance go with Supercharger, if you want fast response and high power (torque) go turbo.
Jose
18 " IWC Wheels with Dunlop 225-40's Rubber. 7000K Hilite Head and Foglights. M-3 Armrest. M-Technik Chrome - Leather Shift Knob. Euro M3 Gray Gauge Face. Bilstein Sport + H&R Race Springs. M3 Front Bumper Conversion + Side Moldings + Side Sirts. Dinan Performance Chip.
Projects on Agenda:
TO-3 Garret .60/.63 Stage II AirResearch Turbocharger
Old 02-25-2004, 10:09 AM
Bad Bimr's Avatar
Custom Bimr
Originally posted by josemg
I One of the points of centrifugal SC is the noise that emits during idle time. I have a friend with a mustang sc and it sounds like an old car with blown power steering and water pump. He had a Mustang Race Car also and he said that turbo response better than Supercharger. Another one is that if you want fast response with the supercharger, you have to go full throtle all the time, instead of turbo that response from as near as 1500-200 rpm.
Jose
Noise, what noise? I guess your friend has on of the LOUD Vortech, Pro-Charger, etc.. SC's. Those SC's use gears and are very loud. They sound great at first when they are new (like a loud exhaust) but become a pain after a few weeks. The noise drives you crazy.
That is why I bough a Powerdyne unit, NO NOISE. Granted the Powerdyne is a "STREET" charger and not recomended for track or over 9 psi. Well I drive my car on the streeet 100% of the time. The engine will not take even take 9 psi on stock CR so why get a different SC.
Bill P
Bill P
Old 03-05-2004, 03:54 PM
Rides:foot clan
spoon is a New Registered Member
Not to discount what bad bmr has said, but I would go with turbo over a sc anyday. I have a t03/t04 hybrid drag kit, with all the goodies. I have around 280 at the wheels in a gsr with stock internals. I have had my turbo for about 7 monthes and have had few bugs. I could have spent 5 for a turbo and got 80 at the wheels, or 3 for 30 at the wheels. I beat v8's all day. Its true that you have lag, lag, POWER. but its awesome. I love every minute of it. And then you have that beautifull blow off sound too. im sure you know how fun that is.
mustangs for breakfast,
corvettes for lunch.
Old 03-21-2004, 04:29 AM
DeeDubb's Avatar
Heywood Jablowmey
Rides:A few automobiles
Region: USA - Rocky Mountains
DeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master LicenseDeeDubb has achieved their Master License
There is a BIG difference between Acura's and BMW's my friend
Past Hero
Current Has Been
Future "Who was that guy?"
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
