Old 01-05-2004, 01:56 PM
Rides:BMW M3, Dubbed Pathfnder, Porsche boxter S
ICE90 is a New Registered Member
Supercharger or Turbo system is the question
I've been lookin to add a supercharger or turbo charger to my car but when i got to shops they tell me that its a hell of a lotta work to turbocharge a M3 because it is a high compression engine and has to be converted to low compression............ they gave me the option of supercharging it... And now i can't decide does anyone know the pros and cons of both?
Old 01-05-2004, 03:30 PM
Boost Happy
Rides:2004 WRX
Apex E36 is a New Registered Member
What year is the M3?
2004 World Rally Blue WRX
Old 01-06-2004, 03:32 PM
Scho's Avatar
Moderator
Rides:1999 White M3
AA makes a Stg1 kit that retins stock compression. 400bhp too.
Old 01-14-2004, 08:58 AM
SD bimmer owner
Rides:BMW 528E 1985
cartooner_1337 is a New Registered Member
First you must understand how a turbo's and supercharger's work. Superchargers are belt drivin from right off the engine so you dont need to wait for the turbine to spool up which means that you get boost all the time. On the other hand having any thing run off of your engine will rob it of small amounts of horsepower (AC, heater, supercharger, etc.). Now turbo's are run off of the exhaust comeing out of the car so the amount of boost that you get is directly related to the revs of the engine. Because of the way a turbo works you get this thing called "turbo lag" when you shift up because the engine drops its revs and the turbo stops spooling so you need to wait for it to spool up again which means a small period of little to no boost. All in all the choice is up to you, you can get a little more power from a turbo but its not as consistent as a supercharger.
Most people drive to get from point A to point B. Some people drive to better there lives......... Which one are you??
Old 01-14-2004, 07:48 PM
///AlpinePower's Avatar
yo
Rides:M3 Coupe
///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License///AlpinePower has achieved their Master License
Go with the Turbo. I watched the Discovery Channel Special on Jet engines and Turbos put SCs to shame.
Old 01-14-2004, 09:11 PM
M-freak's Avatar
I'm Ron Burgundy?
Rides:1995 BMW M3
M-freak is a New Registered Member
if your car is OBDII it should have forged internals, which will make it easier to do a turbo set up. mine is OBDI so i am in the process of changing over to forged parts. in my case, i believe that a turbo setup is better because m3s already have enough torque off the line, a supercharger will be too much torque straight off. a turbo will be a good balance between the m3's low end torque and a turbos higher end. you can find plenty of places with forged parts for either the 3.0 or 3.2 if your interested at all, i can send you a list of sites i am using for mine.
plus the sound of that turbo spooling up, then the blow-off valve going.... it just makes you happy in the pants compared to what a supercharger does. the only problem is the price tag for a turbo setup might not make you quiet as happy (i found supercharger for around $3500, turbo runs around 7,000)
Old 01-15-2004, 10:44 AM
I drive a beater....
Rides:A sleeper....
I thought all of the cranks for the S50 and S52 are forged?
Old 01-15-2004, 12:15 PM
Rides:'98 BMW M3
The S50 crankshaft is cast. The S52 crankshaft is forged. Both connection rods are forged. Both the pistons are cast.
Old 01-16-2004, 11:33 AM
Rides:A sleeper....
Is this for both the S52 and S50 or only the S52 Jon?
Old 01-16-2004, 01:03 PM
Rides:'98 BMW M3
Both the S50 and S52 engines have forged rods. Pistons are cast.
Old 01-17-2004, 07:16 PM
esp1976's Avatar
ChicagoDTM
Rides:2007 997 Turbo
esp1976 is a New Registered Member
If it's a daily driver I would gor supercharger. if it's a toy go turbo
Current: 997 07'
My Old M5....
Dinan ECU Stage 5 | Dinan Cold Air Intakes | Dinan Exahust | Dinan Stage 3 Suspension |
Dinan X-Braces Front and Rear | Dinan Headers | Air Flow Meters | Supersprint X-Pipe |
Dinan Stage 2 Flywheel | Rouge Engineering SSK /w WSR | Rouge Engineering Tranny Mounts | Dinan Throttle Bodies | Velocity Stacks | Dinan Diff | Fiske Wheels | Custom Under Drive Pulleys | Brembo Big Brakes
Old 01-23-2004, 02:08 PM
Rides:M3 soon
M3-4-Life310 is a New Registered Member
if your gonna do it once and spend that much money on either a SC or a turbo just go all out man and get the Turbo... that is if you have the funds... just going off gains... Turbo kicks SC's ass
click
AA TURBO
check it out!
M3 Project for me coming soon
Old 01-23-2004, 09:26 PM
Rides:1997 GMC Sierra Z-71 (Drifting God)
x3n0-SDT is a New Registered Member
If you do go with turbo then I would suggest buying a blow off valve which helps get rid of some turbo lag, plus it sounds bad-ass too.
"Oh Shit..."
Last person who drove with me.
Superior Drift Team.
Old 01-27-2004, 10:05 AM
Rides:Everything, Anything
Billj747 is a New Registered Member
It depends on your preference. Turbochargers are like driving a 2-stroke, not too much down low, but mid-range and top end pull is a lot of fun. On the other hand, superchargers are more practical. Personally I like turbos more but I dont know enough about the BMW's motors to know how they handle either. It seems that most people go the superchager route with their BMW's.
"Racing drivers are exactly the same people as fighter pilots - the major difference is that it is easier to become a fighter pilot." -C.S.
Old 01-27-2004, 05:29 PM
RAiMA's Avatar
Supercharged Addict
Rides:S/C'd RT 318ti S4
RAiMA is a New Registered Member
Really comes down to personal preference and application. Both methods are good ways of producing power.
Altho turbos are quite popular, superchargers can also produce some decent power. The car I'm driving at the moment is a detuned (CF) supercharged 318ti at produces 248RWHP from the 1.9L M44 engine. The supercharger was mainly chosen because they're generally smoother to drive than the single turbo counter part. With the car being circuit driven this year, this is important to maximise traction while exiting corners.
BTW, superchargers do use BOVs, as they run all the time and need to vent the excess air when the throttle is closed.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
