Old 11-27-2003, 11:49 AM
Rides:95' Turbo M3, 86' Peterbilt, 08' 335I Coupe, 07' Yamaha R6
wideband o2 sensor
does anyone have prices and links for some good wideband o2 sensors? thanks
I am looking at this one, has anyone used it before?
http://www.fjoracing.com/
Old 11-27-2003, 07:20 PM
Scho's Avatar
Moderator
Rides:1999 White M3
James Derry was going to install one. Did you ask him which one he was going to run?
Old 11-27-2003, 10:08 PM
Rides:Stumpjumper Team Frame
josh@werksgroup is a New Registered Member
I've used the MoTeC PLM quite a bit. They are a little pricey but they are very handy with fully programable outputs for dataloggers etc...
Joshua J Murray
Werksgroup Inc
Portland, OR
www.werksgroup.com
Engine development and racefab
4wd Chassis dyno and engine dyno facility
Old 11-29-2003, 03:56 AM
miafori's Avatar
iX driver
Rides:E46 318i
miafori is a New Registered Member
sorry, I want to know more. Is wide band sensor aftermarket? What are the differences between stock and w/b sensor? all the engines should run in a narrow band, why we need wide band?
'03 318i
Old 11-29-2003, 03:03 PM
themadhatter's Avatar
diffs fear me
Rides:Camel
themadhatter is a New Registered Member
you can use it for an Air/Fuel meter - it's helpful if you know how to read it.
-Ron
Hey man, I'm a professional!
Old 11-30-2003, 02:43 AM
miafori's Avatar
iX driver
Rides:E46 318i
I installed Autometer AFR Gauge onto my stock Bosch O2 sensor. Is this correct? I can read the value, might there be error?
'03 318i
Old 12-01-2003, 04:45 PM
Rides:95 BMW M3, 94 Miata Turbo
bobaliu is a New Registered Member
Stock O2 sensors are narrowband sensors, only accurate near stoich. Wideband O2's are accurate over typically 10:1 to 20:1 AFR. For tuning a FI car, you NEED a wideband O2.
Bob
95 M3 - Euro HFM, JC intake
94 Miata - turbo, 360 rwhp on pump gas
Old 12-01-2003, 06:37 PM
Nico5spd's Avatar
Diffmaster
Rides:97 318I
Nico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master LicenseNico5spd has achieved their Master License
Dado, do a search for wideband VW stuff..
you can buy a 5 wire wideband volkswagen sensor for like $38 retail from the dealer (they were part of a mas air flow/o2 recall therefore the car company forced the manufacture to reduce the price) im not at home so i cant link you directly. the supra guys are using setups like this. i think you can buy a controller box (converts the signal to a nice number or display voltage so its pretty) for cheap
good luck
--npavlo
Old 12-02-2003, 03:05 PM
KENPO1's Avatar
Rides:E36 M3
KENPO1 is a New Registered Member
I use the Motec PLM with the NTK sensor....its a bit pricey but in my opinion it is the best thing out there.
Old 12-04-2003, 12:29 PM
hyboost's Avatar
Rides:98 Supra TT
hyboost is a New Registered Member
Dado,
Yeah, check the supraforums for FJO. There are many guys using it and have been very happy with the results. I especially like the new 2-1/16 gauge display. Makes it much easier than the old boxy display unit they had.
Unbelievable car by the way. Let me know next time you're down here in Miami. I would love to check it out in person...
Good luck
Old 12-08-2003, 09:38 AM
LordofMpower's Avatar
AssoutRedlineJunkie
Rides:89 M50b25 E30
LordofMpower is a New Registered Member
Check up on AEM's new unit on their site www.aempower.com here is a brief rundown
AEM Wideband UEGO Controller
AEM's Wideband UEGO Controller is available in single- and dual-channel modes, and is the most affordable UEGO controller available. The AEM Wideband UEGO controller has a very low current draw, and features both 0-5v calibrated output and 0-1v calibrated output to mimic the factory narrow-band sensor, eliminating the chance of a factory computer issuing a trouble code.
Key Features:
Ideal for use with ANY aftermarket standalone engine managament system
Accurate to 0.1 AFR (Bosch UEGO conditioning)
Available in single- or dual-channel modes
Bosch sensor(s) included
0-5v calibrated output with 0-1v secondary output to eliminate trouble codes
Extruded enclosure features titanium anodizing for enhanced durability
Also they are releasing a really Nice Display that fits in any normal gauge pod for this unit very shortly. it will have a led indicator ring as well as the digital exact A/F readout in the center. I Deal with alot of the AEM EMS units and I think they are excellent!!
'91 M42is (318IS)
-Diamondschwartz
-Turner J-stocks/J-stock Evo Bilsteins
-Apexi S-AFC
-chip, intake, exhaust
-ATE powerdisk/Carbotech pather+
-Cibie CSR's and Fogs
-Smoke lenses all the way round
-GMG CF HOOD
-FACTORY CF Grp A mirrors
-Evo kidney, euro grills, euro trim
-custom ISI lip
-bigass, not to heavy stereo
-V1 hardwired
-20% tint all the way around
-shortshift/clutchstop
STICK IT!!!!!!!!
Old 12-14-2003, 05:09 PM
20valver's Avatar
Rides:MK3 Jetta 20vT
20valver is a New Registered Member
www.eiptuning.com sells the LM-1 wideband for $350 i think with logging capabilities
Old 12-14-2003, 07:07 PM
Rides:'87 E30 M3
HANDBLT is a New Registered Member
I have the FJO WBO2 system on my car (E30 M3 w/ A-N). It is a well built unit that will maximize your tuning efforts. You can view and log with a Palm Pilot so you dont have to have a laptop in the passenger seat all the time. If you want to run this and the OEM for closed loop, you will need to have another sensor bung welded in the header in a good spot to get accurate readings.
T
HANDBLT= Assembled by the hands of Motorsport.....
Old 12-16-2003, 06:44 PM
whoa!I can change it
Rides:big purple intrepid (shiot)
PatTink is a New Registered Member
heh heh heh heh sensor bung heh heh heh (bevis and butthead) man this is a pretty interesting thread.
Old 12-23-2003, 10:42 PM
revo86's Avatar
m3 eater ~ yummy
Rides:e30 s50 turbo
revo86 is a New Registered Member
i run the uego 1000
I bought it from www.lindseyracing.com for $550 and love it
I have seen it as cheap as $350 around the internet but they never have them in stock
eurotuner january 2004 / pbmw august 2006
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446
