Old 12-31-2001, 02:51 AM
Supercharger Owners Attention
ALL SUPERCHARGER OWNERS WITH 11 PSI OR MORE AND 10,5 COMPRESSION RATIO:
I have a European M3 3,2L. It is supercharged. I have a water to air intercooler and aquamist. I spray water metanol 50/50.
My boost was 8 psi and with 95 octane fuel we had no problems. Last week I increased the size of the crank pulley and boost is now 11 psi.
I could not see and feel any detonation at 1st and 2nd gears.
We have no speed regulations.
I tested the car in 5 th and 6 th gear with 11 psi of boost. The engine was reluctant to go up to 170 mph in 5th gear and when I shifted to 6th gear the needle was not moving to 200 mph.
Suddenly the engine started to vibrate and the needle stopped. That is detonation.
All of you drive at speeds lower than 175 mph over there in USA. And that is why all of you can not feel detonation. In 6th gear and 5th gear, it takes longer for the engine to rev. As a result the engine is under boost for a longer time than it may take in lower gears. You guys finish 2nd and 3rd gears up to redline very quick. But try 5th gear up to redline and you ll see detonation.
This is why all serious Australian and German tuners lower compression ration for boost levels of more than 8 psi.
Old 12-31-2001, 03:57 PM
paul e's Avatar
Rides:'99 SC M3
It seems you have your answer...If the higher boost isnt working out for you, then use a different pulley! If your engine is vibrating, and fails to reach redline in any gear, then youd better change things pronto. If its knocking as badly as you said, Id get it to your mechanic and check things out right away...and then go back to a milder pulley. I dont think youll get too many responses from american drivers with much experience at 170 mph, except those on the track.
Whats strange is that with an aftercooler and water injection, american OBDII m3s are able to handle this much boost without their engines coming apart...and without lowering compression ratios..AA used to lower CRs on their OBDIs...but on their OBDIIs, theyre making this much boost without it. So is Dinan on some of his signature hi boost vehicles...
Please get your engine checked out to make sure theres not something else going on.
Paul E
Old 12-31-2001, 06:46 PM
Today I went to my repair shop to install a larger sc pulley. We saw that the o ring of he aquamist's water jet was not in correct position and water was not penetrating the intake system. Water was coming out of the water jet and that may be the reason of my detonation. We have corrected the o ring's position but it is raining so much that my air flow meter is damaged. So, I ll test later whenI get a new air flow meter.
Old 12-31-2001, 07:15 PM
Rides:"The School Bus"
gerry_miranda is a New Registered Member
This scares me. Im thinking of doing 10 psi with winjection. How can i be sure that the winjection is working? Consequences of winjection failure seems hi. Can you have a dual nozzel? is ther any way to bypass boost depending on iat (intake air temp)? maybe a bypass valve triggerd by iat?
97 M3/4: 307+ RWHP SAE
Dinan SC 6 PSI
RMS Aftercooler
AA Turbo Clutch
AA LTW Flywheel
Supersprint Exhaust
AA Track Pipe
Dinan Suspension
E46 M3 RSM
AA Strut bars (F&R)
XBrace
BMP Rear Camber Correcting Arm
IFG A5 Forged LTW wheels on Pilot PS2
CF Hood
And a whole bunch of forgotten and replaced upgraded items.
Old 12-31-2001, 07:28 PM
m3k m3k is offline
Rides:95 M3
m3k is a New Registered Member
detonation
I have a 95 s/c (vortech) with an air to water intercooler. I do all the installs myself and i am boosting about 13-14psi daily. Whether its 1,2,3,4, or 5th gear there is no detonation and no water injection. How are you running your car at 170 mph? Thats a lot of gearing thinking that the euro m3's top out at a supposed 180mph
Old 12-31-2001, 07:37 PM
Whos SC kit and Intercooler kit are you using? How much HP?
Dinan SC 6 PSI
RMS Aftercooler
AA Turbo Clutch
AA LTW Flywheel
Supersprint Exhaust
AA Track Pipe
Dinan Suspension
E46 M3 RSM
AA Strut bars (F&R)
XBrace
CF Hood
Old 12-31-2001, 09:27 PM
paul e's Avatar
Rides:'99 SC M3
Ok Guys, heres the best way to make sure youre water injection is working ok...First, turn your ignition to position II, but dont start the engine...Turn on your water injection arming switch so that it glows. Then go to your manifold pressure switch. Remove the black rubber protective cap, and slowly remove one of the leads from its spade connector on the switch...You will instantly trigger the pump to start spraying....Look closely at where the nozzle enters the supercharger discharge pipe....If you see it dribbling, or can feel any wetness where the nozzle joins the pipe, you have a problem!
Put the wire back as soon as possible, as letting it spray any longer than 5 seconds will cause you a little difficulty starting the car...
What you can do is contact aquamist, and get yourself a 'quick disconnect'. This is a little plastic part that fits in line with the water hose...I cut the 4mm water hose 3" behind the nozzle, and put in the quick disconnect...That way, I can easily remove the hose to check spray patterns, without either having to unscrew the nozzle, or pulling the hose off...What you will find is each time you pull the hose off, it develops a bulbous shape where it fits over the nozzle end, and you can no longer get a real tight fit the next time you put it on...Meaning you need to cut off a quarter inch each time you examine it..Which means before long, your hose is too short!
Order yourself a disconnect, and some extra hose, and youll be in good shape..goto the aquamist web site, and they will refer you to a local distributor..In the states, theres a guy in the mid west who is great.
Anyway, when you tighten the nozzle, it will squish the O-ring..However, you do not need to replace it...I like using thin teflon tape even better, as it makes an excellent connection, and removes any slop in the threads, if you have it. Just make sure not to drape the teflon over any part of the opening, of course!
Gerry,
>>Can you have a dual nozzel? is ther any way to bypass boost depending on iat (intake air temp)? maybe a bypass valve triggerd by iat<<
You can have 2 nozzles, but its absolutely not necessary for our system..Your clearly thinking of redundancy, however,you can make yourself foolproof without it. For instance, I always wondered, how can I be sure its spraying? Well, to that end, I ran a parallel connection with the manifold pressure switch, to a little green LEd mounted in my A pillar pod right next to my boost gauge...Now, every time I hit 3.5 psi, the trigger point for mine, I see the little green LEd start glowing, right next to my boost gauge..Its very cool, and gives you all kinds of security. Then, every so often, I will unscrew the nozzle, and test it, using the method above, by removing one of the leads from the pressure swtich. Then, if your very careful about making sure you have teflon wrapped threads, and your hole is cut and threaded properly, your 99.5% sure to be making good cooling...And, the Low Level LED warns you when low..IT comes on when you still have about 20% of the tank left, so you have good lead time. Just take a little common sense care, and you should have no problems. Oh, I have another device to help me...I have an EGT gauge, so I know what my EGTs usually run..If they shoot up, its another sign Id better check my water system.
Hope this helps.
Paul E
Old 01-01-2002, 12:07 AM
m3k m3k is offline
Rides:95 M3
boosting
Havent got the numbers on the dyno yet- but im using rms stage II supercharger with custom chip and upgraded boost-
Old 01-01-2002, 08:41 AM
Rides:BmwE36, M3 motor swap
M3Turboca is a New Registered Member
M3K
The 13-14 psi boost that you must have lowered your compression ? If you did what are you running now and did you notice any drop with the lower compression ?
Mark
AA Stage 1 Gen III, 11.5 psi on stock compression, Custom 3.0" Exhaust no cats, AA Muffler, Bored Throttle Body, UUC Pulleys, HID 4500'K, water injection, AA 3.5"HFM, cyl & manifold porting
Old 01-01-2002, 10:23 AM
m3k m3k is offline
Rides:95 M3
lovin the boost
Nope- all stock head gasket. No lowered compression with stock pistons!
Old 01-01-2002, 03:52 PM
I bought my sc kitfrom G Power in germany. They do not allow more than 6,9 psi with 10,5:1 compression ratio.
Today I changed my sc pulley and decreased the boost to 9 psi. There was heavy rain on the highway and could not test well. But I tried to accelerate from 50 mph in 4 th gear to 125 mph. I could go up to 115 mph in WOT because the rear wheels were spinning and it became dangerous. However, my needle was still revving reluctantly up to 5500 rpm and I could not drive in 5th and 6th gears to see detonation.
ONE THING IS ESSENTIAL. My air flow meter is located behind the left fof light and it got wet all this week. Today I had to tow my car to the repair shop because of the air flow meter failure. It was wet and we dried it. Can it be that my air flow meter is damaged and that is why the engine does not want to revv freely to 5500 rpm and then shakes at 5 th and 6 th gears at 185 mph. I could not get to 200 mph because of the engine's vibration.
Euro 3,2L, G-Power SC kit, 10,5 :1 cr,boost varies from 8 to 11psi but 11 psi was not good water air intercooler, aquamist...
Old 01-01-2002, 04:06 PM
Hellred's Avatar
Rides:2003 BMW M3
Hellred is a New Registered Member
From everyone I have spoken to on the topic of boost, it is unsafe, and mostly unreliable to boost past 7.5lbs without dropping compression. I may do the water (hokey) injection, and bring boost to 7.5 from 6. I guess I am very conservative!
G
Old 01-01-2002, 06:20 PM
mertdastan
Hopefully all you would need is the air flow meter. If water got on the film and dried out it could affect the performance. Would the check light not come on if the air flow meter was reading the wrong values ?
I have a few suggestions hopefully one will work on the top end pull. The fuel filter has it been serviced within the last 2 years.
Check your spark plugs my car would sometimes miss under full load when it was cold outside below 50'F and I found out that 3 of them were loose. When I changed them myself I did not want to over thighten them I guess I did not tighten them enough I thought I did.
A few weeks ago I went and bought a snap on torque wrench. My car drive well now.
Old 01-01-2002, 08:17 PM
rhl rhl is offline
Rides:E30, E34, E36
rhl is a New Registered Member
Sorry if this is a bit OT. Paul, we've already talked about this buddy Yes you and others here run 10+psi on US motors but how many of you do regular 150+mph or top speed runs?. Not just once or twice a year but once or twice an hour while flying down the Autobahn on the way to the Nurburgring, where you'll be at WOT for ~9mins and hit over 130mph many times?!?. US cars don't see the same kind of use as the Euro ones and can therefore be 'tuned' closer to the ragged edge.
RHL
Old 01-01-2002, 08:22 PM
rhl rhl is offline
Rides:E30, E34, E36
Re: detonation
Originally posted by m3k
... How are you running your car at 170 mph? Thats a lot of gearing thinking that the euro m3's top out at a supposed 180mph
Again this is a bit OT, well maybe not since the thread was pretty vague. The Euro 3.2's hit the computer limited top speed of ~155mph in both 5th and 6th gears. I don't have the #'s in front of me but a stock Euro 3.2L (all were 6spds w/3.23) will do just over 185mph in 6th at 7600rpm *if* you have the power to push it or a BIG downhill.
RHL
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
