Old 11-16-2003, 10:39 AM
freshstart's Avatar
Mid-life crisis
Rides:'95 M3
freshstart is a New Registered Member
Angry turbo car blowing smoke dammit
What a sick feeling huh? Last week after I left work I noticed a sudden and significant James Bond style blue smoke screen out my rear view mirror. UGH The temp gauge also went into the red pretty quickly so I did shut it down fast.
I fired it up this morning for the first time since just to evaluate and sure enough the smoke is still there... damn it didn't heal itself.
I suspect the turbo unit because I noticed a small amount of oil leaking into my intercooler piping a few months ago. I am confused about the overheating though. There is no coolant leaking or any other external signs of problems either... in fact it seems to run fine and smooth. Dare I say blown head gasket EEK! Of course I'm not getting on it or anything, just a one mile drive to my shop so I can get it up on my lift and check things out.
If I do need a turbo rebuild what do you guys recommend? Ship it to Turbonetics or is there someone in Portland, OR that can do the same? Is there an advantage to having AA rebuild it? They just outsource anyways don't they?
Also you AA guys, this is a stage 1 kit, if I'm already spending the cabbage, is now a good time to upgrade that turbo unit? I'd gladly spend a few hundred bucks more now for something better.
www.FreshStartDetail.com
Old 11-16-2003, 12:00 PM
Black n' Tan
Rides:90' 325i, 92' Porsche 968, 2007 Audi RS4
single is a New Registered Member
Upgrading your turbo setup is going to be quite a bit more than rebuilding your turbo, but with that said you will have more power. What generation is your turbo setup? Internally or externally wastegated? There are several places I can highly reccomend rebuild you turbo, but its not going to be cheap.
Just to give you an idea about the overheating issue...I was all the way down to 0, yes I said 0 ounces of coolant and my car ran just fine on 60 degree days, and trust me, I don't drive my car easy. I just found I have an oil leak myself, and it did a lot more damage than I dare think about.
What color is the smoke exactly? If it is thick white, I would look at your headgasket or your turbo's oil-return line. If its any other color, post back.
Wes
1992 325is, Black n' Black. Modded
Old 11-16-2003, 01:21 PM
freshstart's Avatar
Mid-life crisis
Rides:'95 M3
god forsaken BLUE smoke
The smoke is blue (god I hate saying that) and there is plenty of coolant, it lost none.
I believe it's a gen 2 (stage 1) AA turbo. I'm not 100% sure because I'm the 3rd owner since it was installed by AA and at this point I'm not taking anything for granted.
So to rebuild the turbo we're looking at what... $1000? I think I can yank it out and reinstall it myself to try to save some $$.
Rides:'98 BMW M3
You're going to have to do a better diagnosis on your vehicle.
Do a compression and cylinder leakdown test first.
Does your heater work? If not then the water pump is shot.
How low is your engine oil? Can the cause of the leak be the turbo seal?
Old 11-16-2003, 05:53 PM
Rides:93 E36 turbo/95 M3/73 Camaro/96 Chevy Dually
forrest is a New Registered Member
if the turbo is the problem. I have one i could sell you from my stage 1 gen 2 kit. I am upgrading. i live pretty close to you as well you could come look at it in person. mine has been changed over to external wastegate tho.
Old 11-16-2003, 11:17 PM
jonsibal's Avatar
Art N Motion
Rides:wide hoooptie
jonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master Licensejonsibal has achieved their Master License
it could possibly that the seals in your turbo went bad. The worst case scenario from what you have posted is that you would need to replace your piston rings. Check your plugs to see if theres any oil in it.
The overheating part, that Im not sure..
"If you want to see misery, give people more than what they need." -C.S. Lewis
Parts For Sale
Old 11-17-2003, 09:01 AM
freshstart's Avatar
Mid-life crisis
Rides:'95 M3
Thanks forrest, I'll consider your turbo if it comes to that.
I suspect the turbo because the smoke problem happened fast... it didn't slowly start smoking over time. I know rings piston rings or head valves don't just suddenly wear out like that, especially with this motor having less than 50k miles.
I don't drive this car in the cold much but now that you mention it Jon C., the heater did seem to be not very effective.
After work tonight I'll get it up on the lift and remove the turbo outlet pipe and see what kind of oil volume I have there. Then maybe I'll remove the thermostat housing and see if I can see the water pump impeller. I read in here somewhere that you should be able to see it that way.
Old 11-17-2003, 07:13 PM
Rides:volvo 740
volvoperson is a New Registered Member
just wondering how much boost are you running and are you letting your car warm up before driving and cool done after driving?
Old 11-17-2003, 07:45 PM
RAiMA's Avatar
Supercharged Addict
Rides:S/C'd RT 318ti S4
RAiMA is a New Registered Member
Yep, I would say the same. If the car was shut down pretty quickly he should be ok.
This probably wasn't the best idea, especially without checking the oil levels. If the seal was broken, it could have drained the oil sufficiently overnight to cause damage to the engine on restart.
Hope it's as simple as replacing the seal. Good luck
Old 11-18-2003, 08:00 AM
freshstart's Avatar
Mid-life crisis
Rides:'95 M3
All my fluids were fine, I did check that first... I'm not THAT much of a rookie.
Anyway... the turbo does have a small leak of oil that needs to be addressed but that is not the smoke problem. The outlet pipe only had a small amount of oil residue, not enough to produce the kind of smoke I'm seeing.
I'm pretty sure it's a trip to the repair shop and let them diagnose it from here.
Old 11-18-2003, 09:20 AM
Rides:1993.5 Supra Twin Turbo
MKIVTurbo is a New Registered Member
...I hate to say this but signs point to internal damage** Being around highly modded turbo cars all my life I can tell you that a mere blown turbo will not cause a motor to overheat as seriously as yours. *It might not be the turbo at all * I think you've either cracked a piston, or more likely, the piston rings are shot. If it were just a head gasket issue you'd have clearly white smoke along with some condensation (being that coolant is being burnt). I can even smell the anti-freeze in some cases on cars with blown head gaskets. But if your saying that your getting clear and honest blue smoke in large doses WITH overheating as well...thats a clear internal issue. I guess after all the years of boost on the stock motor its finally started to let go...
If thats the case rebuild with forged pistons with a beefy turbo friendly head gasket and bolts too...you might as well fortify it for higher boost
Old 11-18-2003, 10:22 AM
freshstart's Avatar
Mid-life crisis
Rides:'95 M3
...now you didn't have to go and say that!!! I knew that possibility all along. Now you've scared my wallet BAD!
I'm just HOPING these other things could be the culprit, but I've owned enough cars and yes, even blew one (scattered parts all over I-205) to know that blue smoke is death smoke.
Seriously though, I appreciate your input and if it is more than a head gasket or leaking valves, ie it is in the basement, then I will prolly be here banging for more advice...
... to be continued.
Old 11-18-2003, 10:43 AM
...I can completely understand your feelings and emotions right now...especially if your M3 is your daily driver/primary transportation* And I'm glad to help anyway I can...
...but don't be TOO saddend by this. IMHO your turbo system itself is probably all fine. And a simple swap to lower compression forged pistons with a better head gasket isn't extremely expensive. If you find a decent shop you can probably have the whole thing done for you under 3-to-4K (for everything, part & labor). But what you'll THEN have is a bullet proof motor ready for 15psi all day long reliably
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545
