Go Back   DTM Power BMW Message Board Forum > Technical Discussions > Other BMWs > Early BMWs
Old 02-28-2006, 09:32 PM
Douchebag
Rides:97 m3
bigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master Licensebigmansm has achieved their Master License
2002 Head flaws
Why does everyone complain about the flow in the 2002 head?
I really want to pick up one of these cars and turbo it, but everyone is telling me to swap an m20 because the 2002 head is junk.
What's the deal? Get technical...
Old 03-03-2006, 12:37 PM
Villanuevas_BMW's Avatar
Rides:95 M3 , 74 2002 , EURO M6
Villanuevas_BMW is a New Registered Member
Whats up Todd how ya been
Not really too confident in my knowledge of the heads, but I'll give you what I got. There are really three heads for the M10, the difference is really in valve size and the domeage which is a variable for the compression. The real problem with the heads is the camshaft drive system, not sure if the flow is the real problem here because a good camshaft can solve some problems. The problem with the cam drive is that it cant use roller rocker setup, some people have tried but the way it works with the distibutor is the limiting agent and wont work. Many people try to get the most from the cam drive with a better cam and lighter parts like titanium valves and rockers. Most people go with the M20 route because there is more of an aftermarket for it and parts can be cheaper since the M20 is the engine from the E30 which is more "mainstream" in the BMW world. A turbo setup a with fuel injection is more common than a carb setup. The M20 is already setup with EFI so complications maybe less than an M10. I guess what it really comes down to is "Bang for the buck". Im sure you already know that it would probably take more money to get power from an M10 than an M20. M20's are pretty strong, Ive been in a car with just a chip and was impressed. Hope this helps somewhat, try to contact Kris (oldskoolbmw) , or try www.2002faq.com ,a lot of real tech info there, if you dont mind the forum setup there.
A dragstrip is only one part of a track.
Old 03-04-2006, 11:17 AM
Douchebag
Rides:97 m3
so 1 vote for the m20 setup
Old 03-04-2006, 09:33 PM
CleanAzzE30z's Avatar
Rides:86 E30 eta, + 90 2.5L M3
CleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master LicenseCleanAzzE30z has achieved their Master License
Due to the low state of tune from the factory and the durability-friendly single cam configuration is my guess.
Mariano
1990 Diamond Black-Metallic ///M3 (Alpha N 2.5L stroker and much more)
1986 Alpine White 325e (many goodies also)
"Dont do drugs, that way you'll have more time to drink."
"Great Minds Discuss Ideas, Medium Minds Discuss Events, Small Minds Discuss People."
DTMPower Member no. 37
Argentina stays top of FIFA world rankings for eighth straight month:
http://www.fifa.com/worldfootball/ra...llranking.html
Old 03-17-2006, 12:51 PM
OldSkoolBmw's Avatar
My Car is Slow :)
Rides:1969 Alpina 2002ti
Well it's not that the 2002 head flows bad. It's actually quite good. Metric mechanic has a list of stock head flows available on their website if you want the breakdown. You have to dig a little but it's there. I have the pics of them if you can't find them. The problem with the 2002 like a few have discovered is the rear end and the stub axles. The rear end is about a 280-300HP worthy unit and the stub axels are good to somewhere around there. Take for instance TEP's Old Turbo 02. I ran into one of the mechanics who built it (small world eh?) and at a brief 340HP on the dyno if it caught traction the diff was in pieces. Another with a turbo m20 at 280 and he's on his 5th unit. If you want 240Hp then you might get away with stock parts but anything more you're pushing the envelope. So before getting one of these sleds and turbo'ing it I'd make sure what your HP goals are. 2L and 7000 rpm and a turbo... easily more than what the diff can. I'm busy trying to put 4wd and a sr20det from a pulsar into mine. Did I mention after 200hp traction is horrible. Back on topic. The heads are fine and can flow. I've got a 15+% gain over stock with creative porting. I've also made a set of 1.5mm oversized titanium valves and had plans for what was gonna be a desmodromic conversion for these heads for really high RPM. 9500+ Roller's never worked because the rocker arm ratio varies during lift due to the width of the pad. This creates an issue with the roller having a fixed contact point (rather mostly fixed) vs the rocker pad's width. Needless it was just time to quit trying to fix a dead horse and go with new. a 75 shot of nitrous will get you a 13 second quarter with one of these cars and sidedrafts.
1969 2002ti Alpina
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729
