Go Back   DTM Power BMW Message Board Forum > Technical Discussions > E46 M3
  #16 (permalink)
Old 07-13-2002, 09:49 PM
BLOWN3's Avatar
Boost
Rides:Turbo E36 318iS '99
BLOWN3 is a New Registered Member
Exclamation Just checked the website
What you have i.e. the "GT Splitter" is $1099 (USD I presume). Yikes! My non-adjustable one is $690 AUD. I think I'll have to go with the non-adjustable one!
Is the "adjustment" on your spoiler basic sliding action? Or is it more complicated than that?
Thanks for the prompt reply!
Turbo E36 318iS Coupe
  #17 (permalink)
Old 07-14-2002, 09:26 AM
Josh's Avatar
Rides:in a car
Here are some pics of it with the bumper cover removed. The two outer posts are spring loaded sliders and the center posts are used to lock the splitter in place.
http://www.motorsportpower.com/splitter/DSCN0684.jpg
http://www.motorsportpower.com/splitter/DSCN0685.jpg
http://www.motorsportpower.com/splitter/DSCN0686.jpg
http://www.motorsportpower.com/splitter/DSCN0687.jpg
http://www.motorsportpower.com/splitter/DSCN0688.jpg
http://www.motorsportpower.com/splitter/DSCN0689.jpg
http://www.motorsportpower.com/splitter/DSCN0690.jpg
http://www.motorsportpower.com/splitter/DSCN0691.jpg
  #18 (permalink)
Old 07-14-2002, 10:28 AM
Paddy Mack's Avatar
Rides:MMMGood 95 M3
Paddy Mack is a New Registered Member
Originally posted by RacingDynamcs
KS made a supercharger for the e46 M3 goes from 333hp tooo... 525HP totaly insane...
you have a link?
love to come up to speed on this. Like most on this board, I've heard of nothing but engine failure on any FI for the E46.
Active...they definitely can blow
  #19 (permalink)
Old 07-14-2002, 09:13 PM
BLOWN3's Avatar
Boost
[/url]
Cool! Thanks for the pics! But I think I'll just go for the fixed splitter that is available locally!
Your wheels are hot!
  #20 (permalink)
Old 07-14-2002, 09:34 PM
Rides:1997 M3, A Camaro, and a Truck
FaRTaLOTTT is a New Registered Member
Forced Induction will be possible. Look at the S2000. Isn't compression lke 12:1?? I might be wrong, it might be closer to 11.x:1 or something like that, but look at all the blowers available for that car and look at how many are advertised through shows and magazines. Weren't there many SC's available for the E36 Euro Spec motor as well too? There aren't many differences from the euro spec E36 motor and now current E46 M3 motor right? Compression should at least be....CLOSE to the same.....Just my o2 cents.....
- Derek 1997 BMW Lux M3 Coupe 5 spd (RE Exh, ECIS Intake, Sharked, M50 Manifold) SC61 On the way!
- 68 Camaro, 05 Tacoma, 02 Honda CRF .50
  #21 (permalink)
Old 07-14-2002, 10:16 PM
2002 turbo's Avatar
Hangin @ Bojangles
Rides:Turbocharged BMW 2002
2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License2002 turbo has achieved their Master License
S50:
Do you really think after doing so much work, constant testing and development work that anyone would let the whole world know what their exact engine specs are!
Do you see Champ car teams advertising what turbo sizes and compressor trims they use, or camshaft profiles, don't thinks so!
If you consider the M12 motors racing history its no suprise that such a small motor can make so much power. Hell over 20 years ago BMW North America were running E21 320i turbos with this exact engine in IMSA and were producing over 600 bhp, with mechanical injection and older turbo technology! Do I have to mention the F1 power outputs too, you got to know about that!
  #22 (permalink)
Old 07-14-2002, 10:28 PM
BLOWN3's Avatar
Boost
Just confirming! It's 11.0:1 according to my S2000 Brochure (Australia Spec... maybe different for you guys?) whereas E46 M3 runs 11.5:1.
Some may say 0.5 isn't much different but imagine if the M3 ran 0.5 more? 12.0:1! Have to run on aviation fuel all the time!
  #23 (permalink)
Old 07-15-2002, 10:09 AM
S50 S50 is offline
Rides:An M
S50 is a New Registered Member
Originally posted by 2002 turbo
S50:
2002,
Easy mate.
IIRC I didn't ask for exact engine specs. I was simply curious to see what CR you are running, which grade of fuel, and what size turbo(T61, T66, etc....).
I did not ask what your cam profiles are, which valve springs you are running, the dome shape of your pistons, what headwork you have done, the a/r of the turbo, what trim wheels you're running, nor if it's a tangential or on-center turbine.
Again, just amazed as to how much power you're putting out and curious about some GENERAL questions.
Thanks anyways.
  #24 (permalink)
Old 07-15-2002, 08:59 PM
BLOWN3's Avatar
Boost
Originally posted by S50
2002,
Easy mate.
Thanks anyways.
DOn't worry - 2002 turbo is just annoyed at non-believers. Don't take it personally
Just to clarify what 2002 turbo said, that same engine could deliver over 1000bhp in qualifying trim (using only 1.5L but a lot of boost) with old technology! Go BMW!
  #25 (permalink)
Old 07-17-2002, 01:55 AM
2002 turbo's Avatar
Hangin @ Bojangles
2002,
Easy mate.
Thanks anyways.
Its all good mate, I am a bit short fused in that regard, if you knew how competitive our racing category you'd understand why I am quite guarded on the info. Hope you didn't take offence to the comments, they were a bit blunt.
I won't reveal the CR but the fuel we use is BP100 avaiation fuel,
we would like to use VP C16 but the cost is nearly 3 times as much as the stuff we use and its not as readily avaliable.
I must say I am suprised that you think its a heap of power, well ok it is heaps but what they did in F1 was plain crazy! With 1500cc they made 1350 bhp in qualifying trim, in 1986!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632
