Go Back   DTMPower BMW Forum > Technical Discussions > E46 M3
Old 05-05-2002, 11:24 AM
Alex Mc's Avatar
NC Rep.
Rides:E30 Evo Schwiiing
Couple thoughts on E46 M3 engine failure
Just thought i'd drop some expertise/speculation on the bottom end failure problem. Anyone very familiar with the E46 M3 internals please comment.
The problem with S54 motors burning up rod bearings, and occasionally tossing a rod is not really all that new to the design. Although it is an entirely different motor, the bottom end is very similar- almost identical- to the predecessor E36 S50/S52 Euro motors, which were also notorious for bottom end problems with rod bearings.
I personally read all 25 accounts on bimmerforums, and found it quite surprising, but at the same time i didn't. One thing i did want to say, is that when i rod bearing goes, it doesn't always go right now. One day your charging through an on-ramp and the oil pressure drops in the block for just a moment and there goes the skin off of a rod bearing. This doesn't mean that it's going to go right away though.. several people claimed they weren't driving the car hard or fast when they heard the ticking noise, then all the sudden she went. That would be the rod bearing slowly wearing through it's shell.. then, several engine hours later when you're cruising on the highway the bearing finally mills down through the copper, seizes, and spins. You would have a much more violent shutdown (throwing a rod) if this were to happen instantaneously like on the track (ask me how i know ).
Now, the exact reason why this has been happening is not known, but our best guess is the lubrication design in the block. The S50/S52 Euro motors have a dual-gallery layout in the block- one feeds rod bearings, and everything else, while another feeds the pistons sprayers. This design troubles to keep OP constant and the first area that gets robbed in the event of a pressure loss is the feed to the rod bearings (#3 in particular.. kinda like how S14's always lose #2 first) All other BMW inline 6's use a single gallery system, and spinning rods happens once in a blue moon on those engines. So, maybe it's the lube design, maybe not.. i guess BMW may or may not fess up to the real problem in the future.
Old 05-05-2002, 12:45 PM
Camel's Avatar
Lawnmower Bimmer
Rides:E36, E46 and E39
Camel is a New Registered Member
oil
The E46 M3 engine uses thicker oil now.... problem solved... they say.
At the end of the straight, there's always a curve.......
Old 05-05-2002, 01:11 PM
Alex Mc's Avatar
NC Rep.
Re: oil
Yes, i've read that. But i doubt that will burry the problem entirely..
I also noticed that someone saw there have been 2 revisions to the crankshaft in the E46 M3, it'd be interesting to find out what those revisions were.
Old 05-05-2002, 02:55 PM
Rides:BMW, M3, 2002
napalm.one is a New Registered Member
Is this a Problem In all M3's??
I've been reading posts from several forums concerning the E46 M3 engine failures for some time now, and I have yet to find answers to my question. IS THIS engine failure issue a potential problem in ALL M3's? Or is it a rare poduction/material defect that are found in a limited percent of cares produced? Finally, has BMW found a way (whether material or design) to prevent these problems from occuring in newer production cars? PLEASE if anyone knows answers to any of these questions, please reply!
Old 05-05-2002, 05:32 PM
Boozin
Rides:E30 M3 (89)
Kevin is a New Registered Member
I remember reading about the problem a while ago when the E46 M3s were first comin out. I think there was a delay in shipping the cars to make revisions to the bottom end. I remember that they were mainly having problems with the #3 rod bearing.
I didn't realize that they have oil sprayers. Do all the BMW I6s have oil sprayers?
Old 05-06-2002, 06:13 AM
Alex Mc's Avatar
NC Rep.
Yes, they all have sprayers.
The thicker oil supposedly fixes the problem, but not only is that a half-ass way to fix such a serious problem, it's also power-robbing. Going to an oil weight that heavy is probably a 5hp loss or so..
Anyone know what the crankshaft revisions were?? That'd tell us a lot.
Old 05-06-2002, 07:01 AM
Rides:'98 BMW M3
Not much I can say about the S54 crankshaft.
The S54 crankshaft is forged steel with 12 counterweights and a 91mm stroke. The crankshaft is supported by 7 (60mm diameter) main bearings with 49mm diameter connecting rod journals.
The "thrust" bearing is a multipiece shell assembled as a unit and is located on the number 6 main journal of the crank.
Old 05-06-2002, 08:53 AM
Utah Rep
Rides:pinto
hey alex... you know, an aftermarket company could probably make a dry sump kit that would help curtail any issues of oil starvation...
is it oil starvation because of pan design or is the pump underrated?
Old 05-06-2002, 11:29 AM
Rides:'98 BMW M3
I dont believe its the pump or sump design. The S54 uses a semi-dry sump system very similar to the S62.
I think its the materials used on the con rod bearing or design feature.
Basically the tolerances are so tight, there is no room for error. KNOCK KNOCK.
Old 05-06-2002, 11:32 AM
Rides:c32
roozy is a New Registered Member
someone said on bimmerforums
that bmw changed the oil and the problem got worse...here are 2 links that go in depth about the problem and a some owners with blown engines talkin.
-Owner with blown engine
-3 E46 M3 engine failures at Road America/ Windy City DE
Old 05-10-2002, 09:12 AM
Alex Mc's Avatar
NC Rep.
Is the sump in the rear of the motor on the new S54 M3 engine? Can someone please confirm this? I'm almost certain it is, it has to be..
Also, i think the switching to a heavier weight oil is a hell of a cheap fix, and probably not even a good one. First off, if the pressure is going to drop and #3 is starved, a thicker weight oil might buy you a few milliseconds, but hardly a true fix. Also, i'd be willing to be there's a 5-10hp loss with that thick as hell 60W oil.
Open for Mothers Day Dinner
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737
