| Yes and no. Some parts will fit but it won't be good for it. The suspension on the M3 is designed specific to the weight and balance of the M3. The subframes are different and won't be a straight bolt-on. The shocks and springs can be used interchangeably but doubt the non-M will actually benefit any due to the valve and spring rates. You can bolt the M front strut brace right on however without issue.
__________________ still around |
| How close can I make a 330Ci (with proper suspension mods) to an M3 is kind of what I'm looking for. I know the 325 and 330 are around 150lbs lighter than the M3 (mostly enging I'm sure). But with the use of a CF hood, lighweight seats, etc I think the basic 3 series could be even lighter...and not to mention possible engine swaps... -Prince |
| It could be much, MUCH lighter, but you would have to sacrafice many comforts or extra features, or looks. (especially with unpainted carbon fiber and especially on hoods) Lighter rims, carbon fiber body, removing the back seat, spare tires, CD changer/radio, floor mats it all depends on how far you want to take it. |
| The M3 is wider. The fenders are flared out to accomodate large tires. Therefore, many of the suspension components are different. However there are numerous good upgrades to the 330Ci. Equal out the tire stagger. Maybe leave 10 mm, but this will be the BEST improvement you can make to the e46. Then look into coilovers. After these, it starts to make sence to look into weight reduction. Before you start replacing panels however, you will get much more bang for the buck by following my above mentioned upgrades. To go farther, get camber plates, and to lighten the front, remove the A/C. Foglamps are also useless weight... Good luck with the project. ![]()
__________________ ![]() 2007 GT3 2007 530XiT 2008 Titan |
| I'm only 180lbs and have no friends (actually the only person that usually ever drives with me, esp on the track, is my gf and she's quite svelte)Thanks for the input though... -Prince |
funny shit.. i actually Laughed Out Loud. dank p.s. spare tires are easy to take out.. ![]()
__________________ IMisha7: damn u'r a gangsta with that comp of yours EVOIIIM3: It's worse then crack because I can put it on my credit card! (talking about mod fever) Nick: HOLY GAY RIMS BATMAN...chrome 16s!! hahaha ![]() www.bimmerfest.net -- the real deal holyfield.. |
| Though the body is wider due to external body pannels (arches) being different...is there any inherent difference in the structure (save lighter materials) of frames and sub-frames of the basic E46? (this much better describes what i want to know) I know some of the E46 parts are different because of suspension geometry and such, but is the basic and overall car the same thing? like trunk dimenions are the same. interior. firewalls. etc. -Prince |
| oh, wow... well, when someone on a car site has the nick "tdc" it makes me think of "top dead center" (as in, lining up the crank and cams when you mess with the timing belts and chains). guess i was looking too much into it! in any case...thanks for all the help! -Prince |
