Old 12-22-2002, 12:11 PM
Tom330idriver's Avatar
MAX!!!
Rides:330i (mine) M3 (dad's)
Tom330idriver is a New Registered Member
Couple things wrong with my 330i HELP!
In the past few days, there have been a couple of problems coming up with my '01 330i.
1. Whenever I turn the steering wheel I hear a grinding/knocking sound. I was thinking it could be low on power steering fluid. I can't even find where it is in the engine bay
2. Every once in a while my front-left blinker goes out. I take out the indicator lense and try to jiggle the bulb a little. I can't even get the bulb out with all my might, it seems like it's stuck in there. I tried the other front blinker and I couldn't get the bulb out either. Anyway, after jiggling it around for a second, I turn the car on again and all is fine.
3. This last one is kind of a thing I just have to get fixed but I wanted to know if anyone else has had this problem with their E46...My sunroof all of a sudden went mental. I tried to open it but the thing under the glass that you can slide up in and out (leave that one alone u perverts ) got stuck where I couldnt reach it. It went all the way back instead of stopping by the little handle thing. I had to take pliers out pull it out.
I'm getting a little pissed with this car. I know I know, it's a car and its a machine and machines do have problems sometimes, but I'm an elitest and I just get aggrivated. Oh well, if you have any ideas on what the problems could be, please post and thoughts. Thanks guys!
Tom
Until the 20th century, reality was everything humans could touch, smell, see, and hear. Since the initial publication of the charted electromagnetic spectrum, humans have learned that what they can touch, smell, see, and hear is less than one millionth of reality.
Old 12-22-2002, 12:42 PM
tdc's Avatar
tdc tdc is offline
Rides:a white car
1. The power steering fluid reservoir is located right by the fan shroud on the right side (if you are looking at the engine). It has ATF markings on it and is next to the oil filter.
The noise could also be a result of your front bushings being shot. I know on earlier E46's they would prematurely get worn out.
2. The bulb is removed by turning it to unlock it. There are two nubs that slide into a canal and get locked in so it can't fall out. It sounds as if the connection is not being completed fully. Simple fix would be to try to pry up the connectors a tiny bit so it's a tighter fit on the bulb.
3. A bit confused by this. The slide panel does completely slide out of sight and reach when you open the moonroof all the way. Or are you saying you were just trying to slide the panel open and it went all the way back?
stockWERKZ
Old 12-22-2002, 04:18 PM
MAX!!!
When I try opening it all the way, the thing goes all the way back, even farther back than it's supposed to. Then when I try closing it again, it's just stuck back there...so I have to pull it out with pliers. The thing is off the sliding racks when I pull it back into place. Then I put it back on the tracks, but it still feels loose. I don't even touch the sunroof anymore... My brother screwed it up again when he was driving it and felt like opening the sunroof up, I forgot to tell him it was messed up.....I'm gonna take it to the dealer soon.
Old 12-22-2002, 04:48 PM
tdc's Avatar
tdc tdc is offline
Rides:a white car
Yeah, for that it's best to just have your dealer fix it. Good luck with it. It's the first time I've ever heard of that happenning.
stockWERKZ
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732
