Old 08-11-2009, 05:32 PM
Registered User
Rides:BMW 323i 1999
puffinpuffer is a New Registered Member
Unhappy ATTN: BMW Specialists - I need help with my 1999 323i E46!!!!
Okay, this is another "My car wont start posting", hopefully someone here can help me out and point me to the right direction, because I went to a local european shop and they said it's going to cost around 800$ to do, and that made my jaw drop lol.
1999 E46 323i Sedan - Automatic - Stock everything.
Heres the story...
I just got off work, it was pretty hot outside, my key fob buttons never really worked, the only button that works right is the trunk button. I usually just use my key to lock/unlock my car. So I go to my car, try to unlock it with the key, and it had resistance, and became no resistance. Great, I think I just broke my lock cylinder.
Now, I did leave my windows open with about a inch gap. I took a metal rod, and opened the latch in the drivers side door, it opened up, now the alarm went on. Had to open up my key fob to play around the buttons then it finally disarmed im guessing. I also accidently took the battery out of the fob because my key fob's casing is just messed up.
I try to start the car, all the dash lights work normally, but the engine wont crank over at all, no sound really. So I went to the trunk, disconnected the battery for 5-10 mins, and put it back in, still wouldn't start. Tried the fob again, arming, disarming, blah blah, but still no start... So I had it towed back to my house.
We even jumped the car just incase its the battery, I even check the battery through the dash to see voltage, its showing around 12V.
What could cause this car from not starting? It never had a problem starting at all before, so I doubt its the starter?... Im leaning towards its a alarm problem of some sort. But damn, I really dont have 800$ for a shop to fix this, and im fine with having no lock cylinder, I just want to keep driving this car to work so I have transportation.
Theres no check engine lights or anything with this car, it was running great and everything, any help or tips would be greatly appreciated!!! And if your in the bay area, nor cal, i'd love for someone to take a look in person, and i'll hook you up with a little somethin' somethin'. Thanks!!
Old 08-11-2009, 06:42 PM
Registered User
Rides:1999 323i E46
millerbmw323 is a New Registered Member
Your problem is the ews, or the anti theift system, and or the key it self. Do you have a different key. Try that, or if you take it to the dealer you can have them align the ews and the dme, that may work, or at the least give you an idea if its the ews or the key.
Old 08-12-2009, 04:17 AM
Registered User
Rides:BMW 323i 1999
thanks for the help, anyone else, im thinking its the ews definitley.. i mean what else could it be...
Old 08-12-2009, 01:24 PM
Registered User
Rides:1999 323i E46
Well it could be the key, it could be the sensor ring thats around your ignition, or it could be that a mouse has chewed through some wires.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
