Old 02-08-2009, 08:17 PM
Leaking temperature sensor on 330?
This appears to be the source of the water leak.
Anyone else had one of these fail and start leaking?
How does it come off the radiator?
I gotta finish the water pump job on the 328 so I can use the ramps to get the 330 up so I can see how it goes together.
Old 02-08-2009, 09:48 PM
On further inspection, no ramps are necessary. It just pulls out with a thumb release. If I leave the radiator cap on, no water comes out when I remove it.
It is solid metal up to the O-ring, so the O-ring must be leaking. It seems a bit too easy to slide it in, so the O-ring is not a very tight fit. I will see if I can find a fatter O-ring for it. If I do, I will post the part # of the O-ring that fits so others can correct this problem.
Old 02-10-2009, 06:31 PM
Rides:BMW 318i 1985
fourdoorfanatic is a New Registered Member
super super common. i'm not sure why they put the fan temp sensor in the hose now rather than the side of the radiator, those almost never leaked.
Old 02-10-2009, 07:12 PM
The O-ring from a fuel injector is almost perfect. Same ID, slightly larger cross-section. Just a bit too tight. If I were willing to tap it down in the hole with a stick, I could probably have forced it in.
I would have wrapped some teflon tape around the original O-ring and put it back in, but I tore it getting it off to try the fuel injector O-ring, so I was screwed.
I looked all over town for an O-ring to fit it. No luck.
Finally ended up at the BMW dealer. The parts man is a comedian. "I can sell you that O-ring for $40, and it comes with a free temperature sensor!"
Original O-ring
Cross Section (radial) 2.6mm
Cross Section (vertical) 3.2mm
OD: 13.4mm
This is 5 years old, so it has flattened a little, and cross section may have shrunk a bit, ID may have stretched when I removed it.
Fuel Injector O-ring
Cross Section 3.5mm
OD 15.1 mm
This is just a bit too fat to fit.
Groove where O-ring rests is about 8.5mm DIA and 3.8 mm wide.
If I find an O-ring that fits. I will post the source and part #. It has to be cheaper than $40 for a new sensor ($16 on line for FAE brand).
Old 02-11-2009, 07:16 PM
Rides:BMW 318i 1985
any luck yet? i went through every o ring in the shop i work for and couldn't find one to fit. injector o rings were the closest i could get, and like you said they were a little too fat. let us know!
Old 02-11-2009, 10:05 PM
I just ordered a five-pack of silicon rubber O-rings from SmallParts.com
Will put one on the old sensor and put it in when they arrive, and will report back after a few days.
I suspect that it may not fit because on other sites, O-rings that list as being 1/8" cross section are actually bigger than 1/8" if you look at the listed size in mm. SmallParts.com just lists it as 1/8" and does not list the size in mm. I thought about calling them to ask, but decided to roll the dice.
Old 02-16-2009, 10:32 PM
Nope, too big. Part of problem is that I mis-read my caliper originally. I just went back up and corrected the O-ring measurements in post above. Also, 1/8" thickness O-rings are actually bigger than 1/8" as I suspected. I will keep trying.
Old 02-17-2009, 08:37 PM
Rides:04 BMW 330i Sport
caleb27 is a New Registered Member
coolant temp sensor
I don't think its too hard to get to. May be an o-ring as well.
Old 02-20-2009, 07:11 PM
Rides:BMW 318i 1985
...uh huh. any luck yet manolito?
Old 02-21-2009, 11:48 AM
I think have searched every size chart on the web. Standard inch-unit sizes will not fit, not even the military or aerospace specs.
That leaves us with metric O-rings.
I think that the original was a M3x8
The Bosch fuel injector O-ring is an M3.5x8
So the choice is -
1) Buy M3x8 and replace it if/when it shrinks like the original did.
2) Find a very soft (softer than #70) M3.5x8 and force it in.
I have not yet found anyone who sells O-rings in small numbers retail who stocks either of the above sizes.
O-ring selections that are available in kits don't include either if these sizes.
I have sent out a few emails, but for a small lot like I would be buying, I doubt that any vendors will respond.
Old 02-22-2009, 08:52 AM
Rides:BMW 318i 1985
yeah, we (the shop i work at) have been having to sell the entire sensor. its just stupid they use such oddball sizes for things. its like the ecm i had in my m3, it had a bad resistor or something, i can't remember what now, but for the life of me the specs were so weird on the peice that i had to give up on finding one and get a remanned unit.
Old 02-23-2009, 09:54 PM
The only response I got from vendors was:
Allied Metrics Seals & Fasteners, Inc [alliedmetrics@nac.net]
Says they will sell M3x8 Viton O-rings
Pack of 100 for $85
I am not willing to spend $85 to try one out. If I was sure they would work well, I might try buying 100 and then post an ad offering to sell them to other e46 owners who sent me stamped self-addressed envelopes so I could recover my $$.
Old 02-24-2009, 08:00 PM
Rides:BMW 318i 1985
no joke, thats double the list on the sensor. i couldn't even make that up in labor if i bought the lot of em at the shop. bump that.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
