Old 06-21-2008, 11:59 AM
Rides:BMW 318i 2002
Region: Asia
leon_s is a New Registered Member
Help...humming noise and slight shudder from the rear
Hi guys, I'm a newbie here. I picked up my E46 about 3 months ago. It's a 2002 318i with M43 engine. Not powerful, but since I live in a country with extremely heavy traffic, I'm pretty happy with the engine performance. However, there are 2 major problem that are really bothering me..hope you guys can help my in finding the solution.
I've been having this problem since 2 months ago and still looking for answers. Here's the problem. When I drive at around 45-55 mph I can hear a faint humming noise (sounds like "woo woo") coming from the middle rear area. No vibration yet. Just the noise. It only appears at this range of speed. Any faster or slower, it's gone.
The second problem I've been having is a slight shudder at around 65 mph and above. Again, not really sure where it's originated, but if I have to guess it's coming from the middle rear again. I don't think it's the tyres, though. The shudder doesn't amplify as I drive faster. But if I slow the car down to somewhere below 65 mph, it's gone.
I though at first that wheel bearings were the culprit, so I changed them. It didn't solve the problem.
Can anyone here please shed some lights on this matter? I'd appreciate your help...
cheers
Old 06-22-2008, 02:34 AM
gixerdave1983's Avatar
Rides:E36 M3 3.2 97
sounds like both the noise and the vibration is coming from your differential, sometimes changing the oil can make a difference but failing that it will need a new diff
Old 06-22-2008, 09:34 AM
Rides:BMW 318i 2002
Region: Asia
Thanks mate, I'll most probably start from here
Old 06-22-2008, 11:01 PM
I presume that when you did the rear wheel bearings you carefully examined all the CV joints? I don't think that the joints are available as separate parts. I think you have to buy the whole axle. The worst part of that would be that you just had it apart doing the wheel bearings and you would have to tear it apart again to do an axle. A speed-related noise or vibration makes me think more of a joint than a differential.
Tires can be quirky as well, so jack it up and examine them carefully while spinning them. Check all sidewalls for cord separations.
The original Continentals on our '04 330 made a terrible rumble sound at highway speed once they got down to the treadwear indicators. With a new set of Michelins, it sounded and rode like a different car.
Old 06-23-2008, 01:59 AM
Rides:BMW 318i 2002
Region: Asia
The whole suspension system has been professionally checked but I didn't receive any reports about broken CV joints. Can anyone post a pic what a CV joint looks like and where it's located? Sorry for the stupid question..noobie
Old 06-23-2008, 06:09 AM
Go to Bimmerparts.com and look up the rear axle for your car. You will see that it comes with two accordion-shaped rubber boots on it. The CV (constant velocity) joints are inside those boots. It is not easy to tell if a CV is noisy because a little bit of rotational "play" in the joint is normal. It is the amount and direction of the play that you have to watch for. It should not have any lateral play in it.
Old 06-23-2008, 03:31 PM
Rides:E36 M3 3.2 97
a CV joint wont wont generally make the whole car vibrate....a diff will.....nor will a CV joint hum...a diff will........CV joints click loudly like your running a stick down some metal railings
Old 06-30-2008, 10:51 PM
The e36 has a hanger bearing in the driveshaft that can make noise and vibration when it fails. It is a bit of a pain to replace. If the e46 is the same design, that is another possiblity.
Old 07-03-2008, 06:58 PM
RacerJames666's Avatar
Or guibo......
But your no vibration part.....stifling!
Maybe subframe bushings along with a failing support bearing?
Old 08-10-2008, 08:56 AM
mpower318i's Avatar
beemer Vic
Rides:1984 Bmw 318i
mpower318i is a New Registered Member
it could also be a drive shaft that is out of balance due to improper instalation that would take care of you shuttering but the humming noise could be the differential bearings where the driveshaft enters at the front of the Diff. Now you said the it only shutters at about 65 right?...check the differential and make shure that it is not bent or has a dent in it. Also remove and spin the drive shaft in any direction re-install and then drive it to see of the problem still persists. I've come across the same problem on an 2005 f-150 there is a special TSB on it on the Ford dealer website let me see if I can find it to see if there is a better description on how to fix it. nope sorry the only whay I can do it is to get the Tsb from work I can't pull it up from home I don't have a vin number...but there was a special service bulletin on certain model F-150 trucks that had an in-balanced drive shaft and at about 45-55 the whole truck would shake really bad...(you could see the passenger seat move) but it only happens when you are going up-hill and accelarating it said to " raod force the tires and replace if needed" or if the problem still persists then check drive shaft for uncentered mounting or "improper blancing" maybee I can scan the TSB and post it somewhere where you can read it...It will be on monday though.
Old 08-12-2008, 07:34 PM
mpower318i's Avatar
beemer Vic
Rides:1984 Bmw 318i
did you figure it out?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633
