| need more power for my 330ci i got an 04 330ci and i was wondering if anyone new where to get a chip from. i cant find them anywhere for this car. what else should i do to it besides the chip any suggestions???
__________________ ///MPower |
| The only way I can see you getting some real power is with a SC... Everything else only seems so ad a few hp here and there ![]()
__________________ ![]() CURRENT MODS - 19" BBS CH Rims, Vorsteiner Vented VRS Race Hood, Front 355mm Brembo BBK, Rear 295mm Brembo BBK, Eibach Pro Swaybars, Bilstein Coilovers, GruppeM Intake, AC Schnitzer Front Splitters, AC Schnitzer Rear Diffuser, AC Schnitzer 1 Piece Spolier, Radenergie CF Engine cover and Strut Brace, Chrome Exhaust Tips |
Check out diffsonline.com - Custom Geared BMW LSD Differentials if you want a full blown LSD. You can find used setups that might fit your car from Car-Part.com--Used Auto Parts Market
| well you COULD do a active autowerke chip reflash and get your limiter removed...lol... but yea its not anymore HP really...a few from the chip mods but thats it...a really easy way to get a bit more power would be to change how your motor breaths...larger intake/exhaust would tack some decent power on...a high flow cat. also helps...compleatly removing a cat adds around 20-30 hp...but im not recomending that...high flows usualy cut only 50% as much hp as a standard cat....so theres another 10-15 hp...combined with larger intake w/ a cold air could do another 10-15...and then a better exhaust would be like 5...so another 35-40 HP gain...and if you want to you can lighten the load on your car some...start taking out things you dont use...every pound helps... have you thought about getting ligher and better breaks? brembos or M3 euro specs are very nice...alot of the time when people say that they want more power...thats not really what their after...their after quicker preformance...power isisnt what you need...you need better useage of the power you already have...a lighter flywheel, lighter rims and brakes...the less weight your motor has to fight with in the drive train the quicker the responce and preformance is going to be...just be careful with the flywheel...to light of a flywheel will make the car very touchy |
