| 318i throttle response Hi everyone, i'm having a throttle response problem on my 318i. Well i'm not sure if it is a problem or just the way the car is. There is a lag between when you move the pedal, and when the engine responds to the command. Prehaps half a second. And if you blip the throttle fast enough (for example, when downshifting) then it will totaly ignore your input. If the car is coasting along with closed throttle, you can rapidly tap the throttle to the floor and back without any reaction from the motor. Anyone know if this is normal or not? |
