Old 01-18-2004, 10:43 PM
Kaisake's Avatar
Rides:E46 Coupe
Kaisake is a New Registered Member
Lightbulb DIY: Instructions on How To Paint Your Engine Covers! | By: Alan
By: Alan
Posted By: RichP
*** This originates from http://e46.dtmpower.net/showthread.php?s=&threadid=4257 by Alan ***
This should cover everything i did to paint my engine covers. Hope this helps everyone
***How to paint your engine covers***
Parts needed:
1200 grit wet sand paper
2-3 cans of heat resistant paint
1-2 can of heat resistant clear coat
1 can of paint thinner
1 roll of pin stripe tape (your color choice)
1 Paint marker (your color choice)
1) Start by taking off the panels you want to paint. For the valve covers, there are 2 round plastic covers that hides a 10mm bolt. 2 valve cover = 4 bolts total. Every other panel should be pretty self explanatory on how it comes off.
2) After taking them off, clean them thoroughly with soap and water. After it is 100% clean, free of dirt, oil etc……. use the 1200 grit wet sand paper and sand it down. Use a lot of water to help you do this process (hence wet sanding). Lightly sand it down until the surface feels nice and smooth. All your doing in this process is 1) cleaning the surface and getting rid of any imperfections and 2) taking off any clear coat/waxy substance that will cause the paint to not stick properly so take you time!! 3) your microscopically “scratching” up the surface giving the paint more surface area to bite. I can’t say enough how important prepping the surface is. If you take short cuts then risk the whole job coming out like crap. Oil, dirt, etc….don’t mix well with paint.
3) Ok, after your completely done cleaning all the parts you need to make sure they are 100% dry. Shake it, use a blow dryer etc… whatever it takes. The main idea here is 1) Zero water on the panels and 2) keeping the surface clean. Obviously if your hands is all greased up and dirty, you shouldn’t touch the parts to be painted. Word of advice, although you may not see the water it doesn’t mean its not there. It maybe trapped in some corner and when you use the compressed spray can to paint, BOOM! Water comes out of nowhere ruining it. If that’s the case. You’ll have to start all over with that piece so make sure its COMPLETELY DRY!!!
4) As a added precaution, I even used a clean cloth and wiped it down with paint thinner to make sure it’s clean and completely dry (paint thinner dries quick!) After that, I used a hair dryer to blow off any lint that maybe stuck on the surface.
5) Now all your parts should be ready to be painted. On the valve covers, the “BMW” and the stripes, you can either use the roll of pin stripe tape to mask it off or just paint it, then use the pin stripe tape to color it back after your done. I painted all my covers silver and then it was dry, I used black pin stripe tape for the stripes and a black paint marker to color it back in for the contrast. This part I leave up to your own imagination as to what you want.
6) Things that needs to be masked is masked so now painting. Find a nice open area to place all your panel at. You can either do one at a time, all at a time, the choice is yours. I did mines in two “sessions” Make sure the area isn’t dirty, dusty or has anything that might fall on the wet paint.
7) Shake the can following the manufactures directions. Now your ready for the fun part! Spray the color paint about 6-10 inches away from the panel in a fluid back and forth sweeping motion with a VERY LIGHT MIST COAT!!!. If your really new at this, buy an extra can of paint and spray it even further way like 10-12 inches. The key is the first coat is a very very very light coat of paint. It should only cover the panel like a light mist of color. Let that first base coat dry for 10 mins. Now for the second coat. Keep the same fluid back and forth motion and gradually add more coats leaving about 5mins in-between coats. You figure to break it up into 15% at a time while gradually covering 100% of the panel. Remember, its a lot safer and better to do a lot of coats so don’t be too aggressive and try to cover the panel all up in paint one shot. I don’t work that way. The paint will drip and look like a mess if you apply too thick of a coat. You hand should NEVER stay at one spot!!! Always should be moving back and forth. If you notice the paint looks a little thick and wants to drip, HIT the BRAKES and stop! Give it a 10-15min wait and be very careful with that particular area. Uniform light coats is the key here.
8) After all your panels are painted, give it about 20-30mins to dry then apply the clear coat. 2-3 coats of the clear coat is enough. Its not as hard as spraying the paint. Again, allow about 10mins in-between coats and as always with painting, light fluid side-to-side movements at all time or it will drip.
9) Allow it to dry for a few hours and when its completely dry to touch, use some car polish and buff it up real good and it will look all nice and shiny =)
Disclaimer: The Authors and Contributors of this website are not responsible for any problems you encounter from any of the information provided. These are only general guidelines, and not meant to be a comprehensive guide.
(http://e46.dtmpower.net/showthread.php?s=&threadid=9694) 12-24-2002 06:42 AM
Sig courtesy of: Vintage JojO SIGS, Inc. ©
Vishal: Have faith
BMWCCA#: 282841
Bay Area Meets/Events
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732
