Old 01-09-2004, 06:13 AM
Rides:328 Ci, 2000
wilkr1 is a New Registered Member
Angry 328 Ci problem
Ok, i have a 2000 328 Ci,5 spd manual. 39,400 miles
On cold winter mornings i start my car and the car begins to rev, up to about 1100-1500 rpm and 2 times it just cut out, i took it to the dealer(3 times) before the warranty expired and 2 times they said they found no problem, the third time they said " Because in the winter there is more Oxygen in the gas that cause this problem, so us a lower octane (87) will correct the problem, but i still have the same problem.
My question is has anyone experienced this and will i have to pay(Should i bitch, if i do??) for this when i go back to dealer to have problem corrected now that warranty is up??
Just feel like selling the damn car, also had clucth problems, first time i paid $1200 to replace the clutch, started having trouble again, they replace the clutch again saying i had a bad clucth assemble. Car is a money pit, i had a '96 maxima befor and had only to take it to the dealer to have the oil changed. This car i have been to the dealer at least 6times for various problems since buying this car.
Old 01-09-2004, 12:54 PM
Member
Rides:some japanese POS
3erdriver is a New Registered Member
I have similar issues with my '01 325i. the only difference is that i've never had my car cut out. it just idles rough for a second or two and then goes normal after i give it some gas to warm up the engine. (as with you this happens only in cold weather) if you figre out exactly what that is or how to fix it let me know i'm out of warranty as well so i am interested
My BMW is no more...so sad...i miss it.
'05 Corolla XRS
It's a corolla with balls...I love seing the face of someone thinking...oh i'll go beat that corolla and boost my ego...who then gets smoked.
'03 Silverstone Nissan 350Z
Bone Stock
"Of all the things I've lost, I miss my mind the most."
-Ozzy
Old 01-09-2004, 02:59 PM
tdc's Avatar
tdc tdc is offline
Rides:a white car
Sounds like a problem with the secondary air pump and/or secondary air valve.
Mind if I ask who your dealer is?
stockWERKZ
Old 01-10-2004, 03:46 AM
Rides:328Ci
AnZero is a New Registered Member
I had the same problem with my 328Ci. Problem was fixed after the idle control valve was replaced and the DME was reprogrammed.
Old 01-10-2004, 06:22 AM
Rides:328 Ci, 2000
My dealer is PACE BMW, in Mamaroneck.
If it is idle control valve, and it has to be replaced will i have to pay for this since my warranty is up, and i have had this problem before the warranty expired??
Old 01-10-2004, 06:46 AM
tdc's Avatar
tdc tdc is offline
Rides:a white car
If it is on record that you've had this issue prior to your warranty being expired, you need to press that fact.
They should perform the service under warranty. Or at least goodwill it.
stockWERKZ
Old 01-10-2004, 08:57 PM
Laxtastic
Rides:00 328ci, 00 CLK430, 99 Expedition (TV!)
Kassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered MemberKassel is a New Registered Member
i have a 328ci and i hear that happen but it never cuts out, sometimes it gets close and sounds like it will, but never has yet
Old 01-11-2004, 01:48 AM
brewdistributing.com
Rides:BMW 328Ci 2000
Mpower619 is a New Registered Member
I have the same problem and it also cuts out but after the car warms up it goes away so I really dont worry to much about it..I think it is the secondary pump........
Take it to the Track..
Old 01-12-2004, 08:45 AM
POTHOLE DODGER
Rides:03-330I STERLING GREY CUSTOM ORDER COLOR
TG328TG is a New Registered Member
IT CAN BE YOUR IDLE CONTROL VALVE BUT MORE LIKELY IT IS YOUR VANOS UNIT...I HAD THIS ISSUE AND I WORK FOR A DEALER SO IT WAS RECTIFIED FOR ME QUICKLY.....IF IT IS ON RECORD BEFORE YOUR WARRANTY EXPIRED AND THEY ARE A "REPUTABLE" DEALER YOU SHOULD BE FINE......IF YOUR CAR "ALMOST" DIES OUT...IT WILL PROGRESSIVELY GET WORSE AS TIME GOES ON AND IT WILL ONLY HAPPEN ON THE COLD STARTS...ONCE THE ENGINE HAS BEEN WARMED UP, IT WILL NOT HAPPEN
"you want it i'll get it"
TGILLESPIE@JMKBMWSAAB.COM
http://members.aol.com/_ht_a/tg328tg...mtbrand=AOL_US
http://www.jmkbmw.com/body_shop.htm
Old 01-12-2004, 03:11 PM
Rides:1987 BMW 330is, 2005 X5 3.0i
kvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master Licensekvcicca has achieved their Master License
I would LOVE to hear how the HELL this could cause a poor running/stalling condition when this has NO effect on how the car runs at all.
TG328TG's diag sounds more like it. It is either the VANOS sticking in the wrong postion (do you still use BMW 5W-30 oil)? Or it could be a cam sensor, (but almost always sets a fault code), or a software issue. Good luck.
-Kvcicca
www.euromelee.com
www.rimpro.com
www.diffsonline.com
Old 01-12-2004, 03:43 PM
tdc's Avatar
tdc tdc is offline
Rides:a white car
Well, if he were asking about poor running or rough running during normal operation then I could see how you don't see how it has an affect.
However, he stated the problem is during COLD STARTS and more often than not it's due to the secondary air valve (non-return valve) becoming contaminated.
Might want to check SIB 12 04 00.
stockWERKZ
Old 01-12-2004, 06:58 PM
huh?
12 04 00 is talking about a cust complaint of a check engine light. It does NOT mention stalling or high RPM, or rough run............
I change a secondary air pump once a week, and have never had a complaint of anything except a check engine light.
-Kvcicca
www.euromelee.com
www.rimpro.com
www.diffsonline.com
Old 01-12-2004, 07:03 PM
tdc's Avatar
tdc tdc is offline
Rides:a white car
Re: 328 Ci problem
I still don't see where he says it's running rough.
And we've had about a dozen cars come in with stalling issues on cold starts and it's been the the valve every time - regardless of a check engine light being illuminated or not.
stockWERKZ
Old 01-13-2004, 06:57 PM
He states: " and 2 times it just cut out" .
I understood cut out to mean stall.
I still am confused as to how this valve would cause any driveabilty issue. If you know a way, it would be helpful to me of you told me how, and I would maybe consider checking this valve on a stalling condition. I have thought about it and cannot see any way this valve would make a car stall (even if it wasn't on the engine).
-Kvcicca
www.euromelee.com
www.rimpro.com
www.diffsonline.com
Old 01-27-2004, 10:25 PM
Rides:BMW, 328i, 2000
peeweeherman is a New Registered Member
Yeah I got the same exact problem when it is really cold also. My car works just fine, sometimes it cuts out and the idle bounces up and down when the car starts to warm up. Once the car gets running and warm it doesn't do it anymore. If the car had a choke than I would say that it was just confused as to what to adjust to from the cold weather to when it gets warm. It's like the car realizes it's getting warmer and than goes to normal idle, but it's too low while the car is too low so it jumps back up and sometimes it can cut out and die. Although it doesn't do this when it's warm, and runs perfect no matter what temp while driving and also just idle when the car is warmed up. So I have no clue what is doing it to my car. I just go along with it unless it is going to trip some sensors (which it hasn't).
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331
