Old 06-04-2002, 10:19 AM
The Pikey
Rides:1993 325i
E30GoDz is a New Registered Member
what makes the M3 engine...
so powerful (relatively speaking) in stock form?? for its time it was crazy, a 2.3 4 banger with close to 200 hp?? what gives it the edge??
Ian
1990 325i
Now featuring camoflauge white
Old 06-04-2002, 10:46 AM
Alex Mc's Avatar
NC Rep.
Rides:E30 Evo Schwiiing
many reasons..
high-flow cylinder head design, 4-throttle bodies pulling from a large plenum that is also fed by a large AFM. the compression ratio is relatively high, rod length is advantageous.. factory header is a full-length stainless piece.. aggressive setup, etc.
the S14 evolved from BMW Motorsport's race motors.. it's a track motor, turned street.
Old 06-04-2002, 11:05 AM
M3 Ryan's Avatar
Gangemi Spec
Rides:'88 E30 M3, '92 325iC Turbo
M3 Ryan is a New Registered Member
dual over head cams, 16 valves.
high revving capabilities, balanced beyond belief.
this motor was made to breathe and it does. It has a header instead of the typical exhause manifold. The intake is very advanced with tuned horns in the plenum to get the air right how it should. There are 4 throttle bodies which made for good solid air/fuel delievery which makes more power.
hope this helps!
Ryan Gangemi
'88 M3 2.5L Lachssilber/Black
'87 535iS 3.5L Lachssilber/Black
Old 06-04-2002, 11:32 AM
Rides:2002, BMW M3 (SMG II)
dallasbboy is a New Registered Member
Not to mention a legacy of high performance automotive engineering skills that is simply something other car makers can not f.u.c.k. with.
The E30 M3 is a legend.
Brian
Old 06-04-2002, 01:15 PM
M3Pilot's Avatar
Rides:1989 Euro Late Spec M3
M3Pilot is a New Registered Member
Brian
Hell yeah!!!!!!!!
I love the S14, it's not easiest car to drive in traffic, but this is not it's home. It needs something open were you can use the revs.
I guess it was pretty powerful engine of the time, as there are still many a car today that has F/I that doesn't put out the same amount of power as the S14.
The M power boys know how to build an engine, and when you think about is there is still a far amount of power to get out of the engine and still be realiable.
It's just the amount of $$$$$ it cost to get it.
1989 Euro Late Spec E30 ///M3
Brilliant Red
"If it all seems under control, your just not going fast enough!"
Old 06-04-2002, 01:50 PM
Banned
Rides:BMW 3
BimmerSteven is a New Registered Member
What do you mean by this?
Old 06-04-2002, 04:09 PM
Cracker Quack!
Rides:94 Honda Accord
vtecinside is a New Registered Member
Originally posted by BimmerSteven
Balanced?
It means all of the motors parts are made within tight tolerances (very small margin of error/variation. This is hard to do on mass produced cars because mass productions needs more room for error.
The advantage everything is as close to the exact levels and specs that the engineers designed the motor with, so it performs perfectly. This allows the motor to be a smooth as possible with minimal vibrations and quite often the ability to rev higher and faster....
the downside it takes a real detail (read:anal) oriented person to do this well.$$$$
noel
94 Accord EX
I/H/E, pullies and tons of suspension mods.
Dreaming of an S14
mod at www.honda-acura.net
Old 06-04-2002, 04:21 PM
Matt's Avatar
matt
Rides:1990 325i
*tips hat*
good explanation. This is true of all bmws.
Old 06-04-2002, 06:17 PM
Banned
Rides:BMW 3
Originally posted by vtecinside
*text snipped*
noel
This is what I took the comment to mean, and I disagree with it. I find the M3 engine to be rather buzzy and the polar opposite of my inherently smooth I6 (325i) motor.
Compared to a friend's Honda S2000 motor (similar to the M3 in that they're both rev-happy 4 cylinders, DOHC, with high volumetric efficiency, close tolerances, and a sporting edge) the M3 is very edgy and anything but smooth. The same goes when comparing it to an Integra Type R motor (again, similar to the M3 in that it's a peaky, sporty 4 cylinder).
That said, all things are relative. Hopefully you understand where I'm coming from.
Old 06-04-2002, 06:38 PM
You're forgetting that it took Honda about 12 years to get 200+ HP out a 4 cylinder engine in a mass production car.
In 1988 M3 was king like no other. Internally the E30 M3 engine has an amazingly complex network of engineering grace. You can't compare it to the S2000 or Type R. Go get an 88 Inetgra or Accord now thats fair, and it will be clear how ahead of its time it was.
Brian
Old 06-04-2002, 06:43 PM
PrinceE30's Avatar
Stick Shift Cowboy
Rides:1991 BMW 318is
PrinceE30 is a New Registered Member
From what I've heard...(with respect to balancing)
The S14 is a highly balanced engine for a 4 cylinder. However, it still can't compare to the BMW inline 6. The company was build off of the great 4 cylinders, but once the engineers got the chance, it continued and grew with the power and smoothness of the BMW inline 6 (see E28 M5, E34 M5, E36 M50).
However, the inline 6 produces more power and torque down low (than the inline 4), which makes it an easier car to drive. EASIER. The "edginess" of the M3 comes from that Motorsport divisions strive to get maximum power out of the engine, without worring about how easy it is for Joe Smith to drive daily.
For an example, the intake of the E30 325 is meant to alow for a slow buildup of intake air. This makes the accelleration smoother and "easier" to drive, but reduces the amount of peak power that could be produced. The M3's intake, on the other hand, is huge and lets air in as the engine needs it. Thus the "edginess", as you say.
And as said before, high compression, big intake, big exhaust, etc make the 2.3L really give you lots of power up at high revs.
anyone?
-Prince
Randall Prince
http://www.rp1.us/ Used Cars
Old 06-04-2002, 06:46 PM
Matt's Avatar
matt
Rides:1990 325i
it took honda 12 years, variable valve timing AND lift, and a MUCH more advanced engine control system.
The M3 does have a higher displacement than either of those motors, though, which probably contributes to the vibration.
oh, and the s14 was derived from a racing motor, while the s2k motor (dunno the ##) was built for a street car, so i'm sure there are design differences because of that.
Prince: i think the high-RPM power comes from the high duration of the cams and the high flow through the throttles and the cylinder head.
Old 06-04-2002, 06:53 PM
Banned
Rides:BMW 3
dallasboy - I wasn't comparing the technological advancements of the different car manufacturers. I was merely using two other platforms that I am personally familiar with to show differences & similarities for the sake of comparison. Ease off.
Prince - I think you summed it up nicely. The M3 motor is balanced for a 4 cylinder given it's performance quotient.
Matt - displacement has nothing to do with how smooth an engine feels or performs. The 3.2l M3 motor in my friend's car is much smoother than my M20. This is due to numerous reasons, one of which is that the state of tune our motors are in vary greatly.
Old 06-04-2002, 07:22 PM
Matt's Avatar
matt
Rides:1990 325i
I guess that's true, i was really referring to the way displacement is arrived at... like a motor with a short stroke and long bore will probably be smoother than a motor with a long stroke and small bore (at the same displacement), because piston speeds will be lower, sometimes considerably.
I didnt want to just say that, though, because i dont know the bore and stroke of the motor in question.
the whole point of all of this was that a well-balanced motor will perform better than a normal one, and i think we are all in agreement on that.
Old 06-04-2002, 08:22 PM
Rides:88 325is
e30 Jeremy is a New Registered Member
what does it take to convert the s14 into a non e30 m3 engine bay? will it interfere with the ECU settings?
Open for Mothers Day Dinner
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737
