Old 07-08-2011, 05:51 PM
Rides:'99 Estoril/M-Cross/ '02 Cummins 5spd 4x4
BadGTho has achieved their Master LicenseBadGTho has achieved their Master LicenseBadGTho has achieved their Master LicenseBadGTho has achieved their Master LicenseBadGTho has achieved their Master LicenseBadGTho has achieved their Master License
DIY: Rear window shade retrofit using existing rear deck
As the title states this DIY retrofits the E36 manual read window shade into the original rear deck. previously BMW sold a rear deck made to fit the shade but it's now NLA.
I'm installing the kit which is also NLA. The kit includes the shade, 2 clips, 2 end caps. all of those parts can be currently ordered.
RealOEM.com BMW E36 M3 REAR WINDOW SHELF/SUN BLIND
The first step is to remove the rear deck.
1. the first step is to fold down the rear seat or remove the rear seat back if you have a non-folding seat.
when you do this you'll expose the black plastic trim piece. it's held in with 4 push christmas trees. if you have headrests you'll need to remove them at this point.
2. the next step is to pull off the rear bolsters (pull the top straight out) and then pull off the opera panels.
3. Once this is done you can lift up the rear deck and slide it out. (you may find it easier to remove the rear door panels to get the deck out but it's not neccessary)
4. Now that the rear deck is out you need to locate the center. it's pretty clear where the sunshade will mount. there is an angled portion of the shelf. i used some blue tape to protect the deck.
5. Next you need to measure the length of the shade and mark both ends
6. This is the tricky part. you now need to cut 2 parallel slits in the deck about 1.5cm apart. i used a straight edge and sharp mat knife. i went very very slowly.
7. connect the 2 slits and remove the small section you've just cut.
8. now pop the new shade into the deck from the bottom. you'll notice that the shade's frame is contoured to grasp the cut edges you've just created. this requires some patience and the shade must be partially extended.
9. lastly you'll need to pop in the 2 little end caps. these dress up the edges
of your cut.
and it works...
10. now you'll need to install the 2 little cleats/clips that go onto the inside of the roof between the headliner and the metal. if you look along the edge of your rear window you'll see 2 little male tabs that are made to accept these cleats. they just press in. make sure that you identify the right and left.
this picture shows how the cleat looks when it's installed.
11. reinstall the deck. i needed to remove these tar-covered cardboard supports from the rear deck. the shade will now take up some room that's filled with these forms and some foam.
12. reinstall the seats and you're done.
i'm happy with it.
95s are
Old 07-08-2011, 06:08 PM
das borgen's Avatar
OT King
Rides:E74, fast bike
das borgen is a Permit Holder
how did you source the parts that are NLA?
your secrets must be shared dear moderator!
Old 07-08-2011, 06:12 PM
a trusted member
the parts are still for sale, it's the kit as one part that's NLA
95s are
Old 07-08-2011, 06:14 PM
das borgen's Avatar
OT King
tres cool! merci beaucoup
Old 07-08-2011, 06:45 PM
eatsleeplax's Avatar
Rides:1997 Hellrot m3
eatsleeplax is a New Registered Member
How much did it all cost?
I disagree with you my friend.. i'll side with the kid.
Old 07-08-2011, 06:48 PM
it all depends on what you pay for the kit.. it's about $250.
95s are
Old 07-08-2011, 07:12 PM
Rides:99 M3, 335d, X5d
Jim E. is a New Registered Member
a trusted member
Nice kit and very nice install!
Old 07-08-2011, 07:15 PM
thank you!
95s are
Old 07-08-2011, 09:57 PM
SG_M3's Avatar
Rides:#56 IP M3
SG_M3 has achieved their Master LicenseSG_M3 has achieved their Master LicenseSG_M3 has achieved their Master LicenseSG_M3 has achieved their Master LicenseSG_M3 has achieved their Master LicenseSG_M3 has achieved their Master LicenseSG_M3 has achieved their Master License
Ben, did you measure the rear shade?
Sean
Old 07-08-2011, 10:13 PM
Modena License
Rides:1997 M3/4/5
MMMGP is a New Registered Member
Very nice! I may just do this instead of the crappy armrest. Thanks for the info!
Old 07-09-2011, 12:24 AM
Registered User
Rides:BMW E36 M3 95'
roare36m3 is a New Registered Member
nicely done. i guess i will have to bite the bullet and get this at the dealer.
Old 07-09-2011, 01:56 AM
AStandridge's Avatar
Rides:1997 BMW M3 Sedan
AStandridge is a New Registered Member
Cool, but my rear window is supa-tinted lol
Get Bent
Old 07-09-2011, 02:22 AM
Modena License
Rides:1997 M3/4/5
So the shade base is just press fit into the rear deck?
Old 07-09-2011, 08:35 AM
that it did.. to mark the deck.. do you want me to post the measurements?
correct. you cut the rectangular opening and the shade clips into it. no fasteners or glue or anything.
95s are
Old 07-11-2011, 09:29 AM
ultamte's Avatar
Rides:BMW:E36 M3 Vert (Estoril/Blk), E39 540/6
ultamte is a New Registered Member
Very Nice, excellent writeup! Another great mod I would do if I didn't have a convertible
ultamte
Thread Tools
Display Modes
Copyright ©2000 - 2012, vBulletin Solutions, Inc.
