| My Techno-Violet Dinan M has a persistent internal (!) coolant loss, about 1 liter every 400 miles. Multiple checkouts found no leaks... must be going out the tailpipe. ouch. Only 111k miles. In all other respects, performance is top notch. Now I hear that K-Seal by Solv-Tec can provide a quick permanent fix. My Bimmer-specialist mechanic say 'Why not give it a try?' First -- anyone out there used this already? Thanks! FreDad |
| have you pressure tested the cooling system? have you performed a compression test? i think you may be jumping the gun. i have yet to see one of those block sealing products work without clogging the heatercore. not worth it. i can give you that as the first "why not."
