Old 08-13-2009, 12:32 PM
droeck's Avatar
Rides:95 M3
droeck is a New Registered Member
Clutch Slave Installation...
Okay, so I've done plenty of research now on m3f, bfc, dtm, etc and still have one remaining question about the proper installation of the clutch slave cylinder. I know that you have to be careful when lining it up to make sure the piston hits the fork, but how do you know if it's lined up correctly?
All of the posts I've read mention that the piston could potentially pop out and into the bellhousing if not lined up properly. I feel that removing the transmission will surpass my mechanical ability, so I don't want to screw this up.
Cliff notes: How do you ensure the slave piston is lined up correctly thereby avoiding the transmission removal debacle I've read about.
Thanks in advance for your help / insights.
Daniel
Old 08-13-2009, 04:15 PM
hey,
it's pretty easy... you can use a tiny amount of grease to help the piston stay in place.
to line up the piston in the hole to ensure that it contacts the clutch fork correctly, start both nuts about 1-2 threads and just make sure that it's centered... that's all there is too it!
Old 08-13-2009, 05:28 PM
droeck's Avatar
Rides:95 M3
hey,
Cool....thanks for the info. Seems like it's not as bad as some make it out to be if you just take your time and do it right.
I'll get it done in the next day or so.
Daniel
Old 08-13-2009, 05:33 PM
Daniel
it's quite easy.. access to the bolts is what's tough.. use a 1/4" drive with a wobble and extension.
the don't depress the pedal until you're sure it's all bolted in correctly.
i've never had an issue with this.
Old 08-14-2009, 07:43 AM
droeck's Avatar
Rides:95 M3
Seems simple enough. Thanks again for the replies.
I need to go and pick up a wobble extension tonight so I can get to this. Also, have a few more goodies to go on the car, including x-brace, mm underpanel, new nosepanel and bumper, and few misc odds and ends.
Thanks again!
Daniel
Old 08-14-2009, 10:28 AM
Rides:BMW M3 1999
99MPower is a New Registered Member
Daniel....
while the 1/4" and wobble will work, I've found that a 12" - 3/8" extension with the socket on the end is perfect... it allows you to come from behind the slave cylinder with no interference, and being larger around, easy to use with no ratchet wrench on the end until the very last little bit...
similar concept to when you need to pull the transmission, and need like 30"+ of extensions..
-Calvin-
..in fact i am really andrew.. i wear Badgtho lamin-x
Old 09-01-2009, 10:25 AM
update...
my slave felt vague and my clutch was dragging slightly at a stop.. i pulled the slave to inspect it and BANG, the pushrod shot into the bellhousing.
my karma sucks, but i had just enough luck to find the rod in the bellhousing, sitting on a ledge and get it out with the help of Fiveightandten as well as a small screwdriver and some magnets.
i was really not excited about pulling the tranny... that's been avoided for now.
i went with a new FTE slave and a stainless UUC line. the problem is slightly improved but the clutch feel is phenomenal. for anyone who goes under the car to bleed the clutch, do the CDV delete etc.. get that UUC line.
it's like 30 bucks and improves pedal feel. the before and after view was amazing.. before the UUC line, the hose would move quite a bit when the clutch was depressed. the UUC line is solid as a rock and does not move AT ALL.
moral of the story.. be safe with slaves.. it can happen to anyone.
Old 09-01-2009, 11:03 AM
droeck's Avatar
Rides:95 M3
Hmmm...nice update on the thread. Glad to hear you got the pushrod out okay....that would be a biatch otherwise!
I also went with an FTE slave (formerly known as FAG!) and it feels fine along with fresh ATE super blue. Only thing different is the engagement. It now picks up only an inch or so from the floor whereas before it seemed to be somewhere in the middle. Oh well...
Old 09-01-2009, 05:27 PM
yeh.. FTE and FAG are the same...
if your clutch is catching that low.. it needs to be bled.
bleed it with the slave out of the tranny so the bleeder points up. use a power bleeder.
Old 09-01-2009, 06:19 PM
droeck's Avatar
Rides:95 M3
I just took the car around the block a little while ago for the first time since new slave install. I guess the clutch engagement isn't as bad as I thought originally, but it's definitely closer to the floor than the top of the travel. Is there an OEM spec for clutch engagement? Any negative consequences of the clutch engaging closer to the floor than not?
I did use a power bleeder, but I did not bleed the slave off the tranny. Frankly, I'm not all that keen on getting back under the car for a while as it seems I've spent too many late nights under there already, replacing all vital fluids, installing x-brace, new fender liners, fogs, nose panel, bumper, and MM underpanel. I still can't seem to get that damn diff fluid smell out of my head.
Oh well, I'll probably re-bleed it here sometime soon. Thanks for the info!
Old 09-04-2009, 07:42 AM
i'm not aware of the spec.. the clutch engaging too low could mean it does not fully engage.
park the car, put it in neutral, shut if off and pump the clutch rapicly about 100 times.
that should bring the pedal up a bit.
Old 09-05-2009, 07:08 AM
droeck's Avatar
Rides:95 M3
Yeah, I was afraid that it might mean it's not engaging fully.
I'll get in there and work the clutch tonight when I get home.
Thanks for the advice!
Daniel
Old 09-05-2009, 02:16 PM
they way to tell and what we did with my car... get all 4 wheels in the air.. run the car, shift into first and see if the tires spin in first with the clutch to the floor.
Old 09-05-2009, 04:40 PM
droeck's Avatar
Rides:95 M3
I did this when I had it on jacks last week. The wheels did not spin in first with the clutch engaged. Actually, I had the wheels off, so just the hubs. However, I did notice that when I depressed the clutch and shifted into 1st, that the hubs did spin slightly for just a moment and then stopped. Is this a symptom of the clutch not fully engaging?
Thanks again!
Old 09-06-2009, 03:30 AM
Thanks again!
mine did the exact same thing.. that is a symptom of a slightly dragging clutch.
after the new slave, the UUC line and bleed mine is significantly improved.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
