Old 07-27-2009, 08:00 AM
Rides:1999 BMW M3 Coupe
PrivateDonut is a New Registered Member
M50 manifold installation - 56k grab a snickers
Morning all
I spent all of Saturday (11 am - 11pm) working in the M50 mani - HUGE thanks to Eric for writing up such a thorough and detailed install guide WITH PICTURES! Those were amazing when it came time to assemble everything back together. I did it with a couple friends (who aren't E36 guys), but who were both majorly helpful and without whom I wouldn't have been able to pull it off in one day.
All in all, I think it went very smoothly. This was the most technically demanding install I have ever done on a car, but thankfully nothing went horribly wrong. We did have fits trying to get that 7th nut on the stud (just like everyone else). We ended up pulling all the injectors to spread the fuel rail apart from its wiring harness, and using a small 1/4" socket driver we were able to get that damn 7th nut in place and tightened. When putting the injectors back in afterward, we found it to be a total pain in the ass to put all the little clips back in, especially those of the wiring harness, and especially those of the 6th injector - they really make it impossible to work in that area. On the upside, I was very pleased to find that all bolts, except those nuts holding the manifold to the head, were 10 mm, so we did not waste time hunting for sockets and swapping them around.
On to the pics:
Before - took pics of the engine bay and all of the components I could see relating to the IM:
Found these guys chillin in the yard twitching their noses at me as I was taking my before pics.
During the teardown: S52 mani is out
Everything was meticulously labeled:
Comparison shot of the two manifolds:
Obligatory hairy arm shot while modifying the mounting bracket
My friend doing his thing
...and goofing off
Everything in place and ready for the test fit
While test fitting:
It fits:
After everything was back in and put back together
Like I said, everything was carefully labeled
(That's still taped on there, btw)
At the end, when it came time to bleed the fuel rail, we took off the screw cap on the front, thinking that was the bleed valve. Little did we know that the bleed valve was actually inside of that little space inside the screw. I spent 10 minutes turning the key on/off trying to bleed the fuel rail, with myf riend standing there with a catch container. Eventually I got out of the car, suspecting there was more to this - so he grabbed a screwdriver and poked the valve we discovered inside of the screw and got blasted with ~.10 or more liter of fuel (sorry, no pics). Luckily I was spared.
Then came the moment of truth - starting the car for the first time. It started on the first attempt! We celebrated a moment of triumph, cleaned up the garage, then took it out for a drive cycle. I didn't have a scan tool to check the tests afterward, but I picked one up from "GEt in the Zone" Auto Zone on Sunday and ran the test - everything checked out OK.
So ...on to the review.
Prior to the Manifold, I could always feel a definite peak between 3500 and 5500, with a definite drop off after that. Going up to redline, the car would make more noise but wouldn't move much faster.
After the new manifold went in, I can feel that the "peak" that was previously there has been smoothed out - instead of that midrange "push", there is now a smooth pull all the way to redline with NO drop-off like there was before. Definitely worth it, and probably the best bang-for buck engine mod you can do for this car. I think with Eric's instruction guide and install kit anyone can pull this off, even if they have never done it before.
Unfortunately, this marks the limit of what I can do for reasonable money on this car - no more performance can be had without spending large sums that I can't currently justify. At the same time, I think I now have the car in its ideal form as I see it. Next up is a full detail in the next couple weeks...will poast pics when that happens
Thanks for reading!
Old 07-27-2009, 01:14 PM
Rides:BMW M3 1999
99MPower is a New Registered Member
good stuff... Eric's instructions are INCREDIBLE....
congrats
-Calvin-
..in fact i am really andrew.. i wear Badgtho lamin-x
Old 07-27-2009, 02:48 PM
Banned
Rides:99 M3, 99 323i
KnudsonM3 is a New Registered Member
how do you like the gains?
and it took you 12 hours, with help?
Old 07-27-2009, 05:17 PM
Thanks guys - took about 12 hours, including time we spent eating lunch and dinner (probably ~1 hr total)
Old 07-27-2009, 06:26 PM
Banned
11 hours is still a long time.
Old 07-27-2009, 06:49 PM
Rides:BMW M3 1999
no kidding.. I'm down to the 6 hour range I think for the M50 conversion
I think my first time with beer breaks and dinner was around 8ish
-Calvin-
Old 07-28-2009, 12:02 PM
Banned
too me 6hrs wen i did it alone
Old 07-28-2009, 01:04 PM
We spent alot of time on annoying lttle things like re-assembling the fuel rail (damn clips). That 11 hrs also includes time spend running the drive cycle and some amount of dicking around
Old 07-28-2009, 04:38 PM
don't let leif (aka teh blockbuster bandit) or anyone else give you crap about the time it took
it's a complex and complicated job. you completed is successfully. that's what counts.
Old 07-28-2009, 07:02 PM
Rides:BMW M3 1999
100% correct.. I was just giving him a reference point
and congrats on finishing it, with ZERO issues afterwords
-Calvin-
Old 07-28-2009, 08:07 PM
AlpinweissM3's Avatar
Rides:06 M3, 01 2.5RS
Region: USA - Rocky Mountains
AlpinweissM3 is a New Registered Member
Nice writeup. M50 is probably one of the best performance mods. 12 hours is a bit long but as BadGTho said you did it yourself that's all that counts.
Supersprint Race | Streamline Filter | Streamline Air Duct | Autosolutions SSK | OEM ZCP 245/275 RE-11
06 M3 (Track Toy)
01 2.5 RS (Snowmobile/Daily)
99 M3 (sold)
98 323is (sold)
Old 07-28-2009, 08:36 PM
Rides:1975 BMW 2002
Roland H is a New Registered Member
The M50 is awesome without a doubt, but you're truly missing out on it's potential without appropriate software/custom tune.
Old 07-29-2009, 05:50 AM
It's on the "possible (distant) future mods" list - not something I can really do right now. Not to mention there is a marked lack of BMW specialty shops and tuning shops in my area. I already have a Shark Injector, so that will do for now, I think.
Thx mate . The sheer number of "installed M50, now car wont start" threads on M3F had me a little worried.
Old 08-02-2009, 05:21 PM
jwbavalon's Avatar
Rides:BMW,M3,1997
jwbavalon is a New Registered Member
M50 Manifold Installation
Way to go. Great pictures and hints.
Old 08-02-2009, 06:25 PM
Registered User
Rides:2002 M5, 1995 M3, 1998 5.9 Ltd.
mikem is a New Registered Member
Well, I think about all that can be said here has. You've done a fine job. Just one more thing to add, in the spirit of your handle: Mmmmmmm.... Hellrot.... *drool*
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
