| This is complicated. I'm not an electronics expert. But I just took a look at the schematic for a little while and I don't see any way of doing it without hacking up the wiring a good bit. Even then, i'm not sure how to source you the parts you'd need. I don't know enough about relay pinouts to determine if you would have to add multiple relays in there, or if you could get away with most of the existing wiring and just adding a relay that's a catch-all for what you want to do. I'd have to look it all up.
It would be much easier if I had access to schematics for a car that has this setup stock. Your car is a '97? I don't see rear head rests. '97 Has some connections between the light switch and the high beam relay that aren't there...supposedly they are in the '96 cars. '98s are wired different. I'm trying to figure out what the difference is. They don't differ in operation, do they? Do your low beams turn off when you turn your high beams on?
__________________ -Nick |
