Old 12-22-2007, 05:19 PM
Track License
Rides:Dakar, m3 97
Dakar M3 97 is a New Registered Member
lifter tick problems
Has anyone ever used seafoam in the oil?
I have noticed that from 2k to 3k my engine sounds like the lifters are really sticking badly (alot of ticking), also there is a little bit of oil gunk on the oil cap and on the metal piece that you can see when you open it up and there is a little bit of smoke coming out of there too. I think that if I put seafoam in there for like a day, that all of the oil gunk will get eaten away and I will lose the lifter tick. Any ideas?
Thanks
Peter
if you dont know what seafoam is here is a link Sea Foam--products
Old 12-22-2007, 07:22 PM
fairweatherpunk's Avatar
Rides:E36 325
Whoa before you start sea-foaming it up it is very normal for E36 lifters to click a little especialy in colder climates. It also normal to see smoke coming out of where you put your oil into. Your engine is hot when it's running, and when you turn it off and intoduce cooler air into the camber you will see a little steam. For the most part everything your experiencing is normal. Enjoy your car.
Old 12-22-2007, 07:42 PM
Track License
Rides:Dakar, m3 97
It also made the lifter tick during the summer so idk. When I first bought the car I looked under the oil cap and there was brown gunk on it. I am assuming that there is this same gunk all through out the engine. It has 88k on it, I use 10w30 mobil 1.
Old 12-23-2007, 12:24 AM
Rides:e36 318is
mrdoof is a New Registered Member
im pretty sure mine does the same, it does have the lifter noise on hot days
Old 12-23-2007, 03:45 PM
Rides:E36 325
If you have a small flashlight look inside the motor, where the oil cap is. Typically sludge isn't brown it's closer to black. I've seen a few BMW's with the motor pretty sludged up, so it's possible. But brown gunk is pretty typical on most oil caps. It the ticking noise gets worse or is worrying you take it to a shop and see what they say. It's hard to give good advice if I can't here or see it. Hope it goes well.
Old 12-23-2007, 03:55 PM
belgian love
Rides:1994 318i
Region: USA - Rocky Mountains
I second that..... I've seen people go through a lot to get rid of that ticking. Mine does the same thing on extremely cold and hot days, and has been ok with the noise. it's best to ignore it unless it gets louder (like he said ^^), or a check light comes on.
normally the valve cover housing will have some oil gunk too, but that doesn't mean that your moving parts (cams, etc) are all gunked up too, so sticking a flashlight in there wont give you much. you would want to pull off the valve cover if you're trying to check out how grimy it is.
Old 12-24-2007, 12:03 PM
RacerJames666's Avatar
Ill second that. I have some brownness in my cap as well...I think most engines i've ever seen have it.. My car actually made little to no noise this morning after a week under the cover in negative temps...strange. but yeah a little noise is normal. If your vanos lets go tho, drvanos.com has better units than stock, which they claim with much merit is far less noisy than a new stocker, so check that one out when the time comes...fuckin vanos is so noisy even new! Its like bmws trademark or something....
"famous for growling, buzzing, rattling, high performance six cylinders since 1973"
Old 01-30-2008, 05:24 PM
itsabimmerthing's Avatar
Anti-bandwagon
Rides:Soon a bimmer
Correct me if I am wrong, but arent S52 valves supposed to be adjusted every 60k miles? Either way tick is normal.
Old 01-31-2008, 04:04 PM
I think you are right! Its the little valve adjustment shims right?
Oh well at least its not like the S54 15k religous valve tune
Old 01-31-2008, 04:16 PM
Anti-bandwagon
Rides:Soon a bimmer
I think so, James. And BTW, is this Dakar from Buschur forums?
Old 02-26-2008, 08:25 AM
Rides:BMW 328 i, 1995
pat.zet is a New Registered Member
Hallo,
S52 egine got no solid Valve caps !!! like the S50 b32 EURO M 3 or S54,
If the valve ticking is only by new starting theres is no Problem, is the Ticking more than 5 seconds the Hydro lifts are worn, also you can`t adjust hydrolifts.
Hydros are runnig a life time till they are broken, no service at any miles.
The also in every M52 engine.
Best regards pat
Old 02-26-2008, 08:40 AM
Track License
Rides:Dakar, m3 97
yeah from Buschur talon91tsiawd. whats up?
Track License
Rides:Dakar, m3 97
Originally Posted by pat.zet View Post
Hallo,
Best regards pat
yes the ticking is more the 5 seconds and what are Hydro Lifts?
Old 02-26-2008, 08:55 AM
These are valve caps that adjust the Valvespace automatic by Oil pressure, if your oil level isn`t all right, this could be a reason for the ticking too, but that`s a loud tacking not ticking.
A low ticking nois is normal if the engine is very hot ( the oil is thin)
Which engine is Yours ??
I haven`t read It.
S52 B32, or S50 B32 EURO?,
I dont want tell you something wrong.
The S50 B32 EUro got solid Lifter`s you have to check, the s52 got the "Hydro lifter"
I have to check the Word Hydro lifter if it `s correct in English.
b. r . pat
Old 02-26-2008, 08:59 AM
it`s part no 10 in the sheet:
Hydraulic valve lifter.
RealOEM.COM BMW E36 M3 VALVE TIMING GEAR - CAM SHAFT
I think it s better to look, cause my english vocabular isn`t complete.
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510
