Old 09-08-2007, 07:21 PM
Chris's Avatar
Rides:the AKA Rally
Chris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master LicenseChris has achieved their Master License
e36 m3 Vader Seat cushion/leather swap and side bolster mod!
I created this howto years ago, and figured I'd post it up here. Should be a nice improvement for some aging e36s.
After 60k miles, I got fed up noticing the huge difference in wear between my driver and passenger vader. I knew the seat leather/cushions could be swapped, I just couldn't find any concise information on it. Here you go!
Tools and supplies:
3/8" Ratchet with torx sockets
Medium sized standard screwdriver
Vacuum cleaner (optional)
Simple Green wipes, or similar (optional)
Leather Cleaner and Conditioner - I used 3m with much success
Read through all of these before starting!
I did this project with the seats in the car. You will read in a little while why this may not have been the best idea. You may want to remove the seats first. If you do, disconnect your battery and wait 10 minutes to allow the SRS system to discharge. If you don't do this, your SRS light will come on, and the dealer needs to clear it (unless you have a nifty SRS reset light) You also risk airbags popping out. As I said before, I did this with the seats in the car, and I am happy.
1. Remove the headrest. You may need to angle it near the top to get it all the way out.
2. This is the hardest part. Pull reeealllly hard on the seat back lever. It will come out, I promise! I started with the passenger seat. Don't forget, there are two levers on the passenger's seat, and one on the driver's seat. Again, pull hard.
3. Remove the seat back lever surround. I used a standard screwdriver, and pried the bottom out first. There is a small opening on each side of the bottom that a standard screwdriver tip fits neatly into. I then pulled the top out gently. Use some cardboard to protect the top of the surround.
4. Take out your ratchet and t51 torx socket. there are 4 torx screws that you need to remove. Two are on the seat back, all the way in the bottom corners. Two are under the seat bottom, in the front corners (right below the thigh bolsters). Use the seat controls to give yourself the most possible room to work. You may need to feel around for the front two screws. Keep them in a safe place.
5. The seatback will now pull off. Mine had melded itself with the cushion, just pull gently around the edges.
6. You can now see how the leather attaches. You will need to pull all of these off. Just pull the edge of the leather away from the clasp.
7. Once you get them all off, you can maneuver the entire seat back cushion and leather off of the seat itself.
Is this some kind of m cloth inside my seat?
8. Now comes the part where it might have been a good idea to remove the seat. There are two fasteners near the hinge of the seat that hold the seat bottom on. I've read that these are similar to the "pushpin" type fasteners used on the front bumper lip and other locations, but I could not get them off. I ended up giving them a sharp yank, and they pulled out. I could not get them back in. This does not appear to pose a problem, but do this at your own risk.
9. The seat bottom will now pull up from the rear. Do this slowly, as you still have to remote 4 bolts that hold the extendable thigh support to the seat bottom. You need another Torx socket, I think a T21. After you remove these 4 bolts, the seat bottom will pull free. Take a moment to restock your change holder with your newfound slew of coins.
10. I Did this to both seats first. I then thoroughly vacuumed everywhere, wiped the seat frame down with simple green, and cleaned and conditioned the leather.
11. Now if you choose to do so, you can bend the side bolsters in for more support. I did this, and I am very pleased with the results. It takes a lot of effort to bend this metal, I put my full body weight into it. Do this gradually, and place the cushion back on the frame periodically to make sure you don't bend too far.
12. Once it is to your liking, line the seat cushion up correctly, make sure you pull the white padding over the headrest holes, and start reattaching the leather to the frame.
13. Now place the seat bottom on the frame, and reattach the 4 torx bolts. Then place the cushion on the frame, making sure to cover the bottom flap of the seat back.
14. Screw in the front torx screws to the seat bottom.
15. Place the seat back on the frame, lining up the seat back lever holes, and the headrest holes. Make sure no leather is sticking out
16. Screw the seat back screws back in. It can be a little tricky to line up, there is no easy way. Play around with it until you get it.
17. Pop the seat back lever surrounds in. Follow the marks to make sure you have the right surround, and that it is going the right way.
18. Pop the levers back in.
11. Enjoy newfound sense of accomplishment. Call a fellow e36 m3 enthusiast to complain that you're "stuck" in your vader. This mod put off my need for Recaros for at least a few months!
Edit - I ended up with SRDs years later anyway, but the vaders are still great!
Old 09-20-2007, 09:53 AM
J.A.F.O
Rides:98 ///M3
BaNzAi RaCeR-91 is a New Registered Member
Awsome write up! How long did this process take you? Also, what made you want to leave the seats bolted in prior to starting?
I'd like to do this as well, but I'm a bit timid in doing so. I also know the seats have some kind of locking mechanism that is triggerd by a cable attached to the bottom, which is why I'm unsure of removing the seats. What was the most difficult part with the swap process with the seats bolted in?
Old 09-21-2007, 09:07 PM
Chris's Avatar
Rides:the AKA Rally
I didn't feel like dealing with potential SRS light issues after removing the seats...
I don't remember running into too many issues leaving the seats in the car. Overall it was a fairly straightforward mod.
Chris
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734
