| Usually if it's something in the timing it will effect all the cylinders. I would start with the basics. Try swapping the spark plugs, coils and injectors around to different cylinders and see if the misfires follow. If you don't have any results then you may have to tear into the engine. A cylinder with 56psi is pretty low but I wouldn't go tearing into an engine without checking the above mentioned stuff first. Also what happens if you clear the faults? Does it run better? It may have just been sporadic faults caused by bad gas or something like that.
__________________ 1998 Arctic Silver M3 Sedan Mods: Full AA exhaust, CAI, 3.5" MAF, BB throttle, M50 manifold, 24# injectors, AA ltw flywheel/clutch, TMS pullies and some suspension mods. |
| When my friend used his peak tool to reset it the problem seemed to get better for a second and then the engine light and prob came right back 5 sec later...so maybe im just losin it and it really never sounded better, haha. I'll keep an update, but so far I have not heard anything back from my mechanic=( Thanks |
| you might have a problem with a coil pack harness, ground strap or plug connector... and just thought i'd add that there is no way to manually time that car.
| So it is all electronically timed in this vehicle? I'm on a learning course with this car so bare with me...To check the coil pack harness, ground strap or plug connector...ext that would mean opening up the engine and divin' in correct? If I have my engine open once I would like to do a few things while im at it cause it just makes sense but let me know. I have 99k on my engine and trans. and would like to install a AA turbo in a short while. Not trying to get ahead of myself, but would you recommend forged pistons and rods while I have the engine open. Or is all that just not necessary? New Cams? Anything else you would recommend? Thank you for your help Last edited by ///M3* : 03-23-2007 at 11:14 AM. Reason: cause i can't spell=0 |
| I had the same probs and it turned out to be a bad exhaust cam...FYI I did buy a head and had it taken to a machine shop to have them check the valves and to refresh it. I do not need it now and I can sell it to you if you want to built up a head or just to have as a spare. |
| The car is not in my control at the moment........My mechanic has had it a week this money. I mentioned all the above suggestions to him...I have heard no answer from him yet, but thank you for help and ill keep an update |
Has your mechanic done a compression test? |
| incorrect. remove the plastic "M power" cover.. and its all right there.
| sweet deal......im gonna mention a leak down test to my mechanic and have him check the coil pack harness, ground strap or plug connector as well.....im kinda having to push him along here and it makes me wonder why he has had it a week and no answer. Thanks for the help guys |
