  #16 (permalink)
Old 03-26-2007, 12:24 PM
Originally Posted by Paradigm_Guy View Post
Might want to try a different mechanic.
Totally.
If you are a member of the BMW CCA i would email your chapter's member at large and get a recomendation.
if you are not a member of the CCA i would post in the regional forum, then go join the CCA
  #17 (permalink)
Old 03-28-2007, 05:33 PM
///M3*'s Avatar
Track License
Rides:BMW M3 1998
///M3* is a New Registered Member
Sounds like it may be a bad exhaust valve. A leak down test can confirm it.
My mechanic called today and it was indeed a bad exhaust valve. Bad news is one of them is bent and hit a piston heads being sent out to a shop right now....could be worse but damn! Thanks for all your help and posts guys
  #18 (permalink)
Old 03-28-2007, 06:06 PM
Paradigm_Guy's Avatar
Rides:1997 BMW M3/4 Turbo
Paradigm_Guy has obtained their Street LicenseParadigm_Guy has obtained their Street License
Sorry to hear that I was right, but glad that he figured it out.
Extreme MotorSports SD - THE WEST COAST EURO EXPERTS
  #19 (permalink)
Old 11-02-2007, 05:33 PM
LUCIDDREAM's Avatar
CommTech2
Rides:1998 M3 Convertible
Region: USA - Rocky Mountains
LUCIDDREAM is a New Registered Member
How much did that cost you?
  #20 (permalink)
Old 11-04-2007, 07:10 PM
goob_os101's Avatar
Rides:BMW, M3, 99
goob_os101 is a New Registered Member
We ended up replacing the cams, all valves, springs, water pump, switched to a metal t-stat housing, replaced all hoses and lines, and cleaned the t-body. Total was $4,000... mostly preventative maintenance.
what happened to yours?
I do have a spare head that has already been through a machine shop.
  #21 (permalink)
Old 11-05-2007, 09:27 AM
get a new mechanic or learn to DIY.
  #22 (permalink)
Old 11-09-2007, 03:49 PM
LUCIDDREAM's Avatar
CommTech2
I was going to say, that cost you an arm. Hey BadGTho, My friend is a mechanic and he charges me next to nothing. He is pretty good, do you think he will be able to perform this type of job on my car that goob_os101 had done.
How much do you want for that spare head? Is it stock M3? And do I really need to change my head?
  #23 (permalink)
Old 11-12-2007, 06:35 PM
goob_os101's Avatar
Rides:BMW, M3, 99
it is from a 98 328 i, which will work in all 3 series 96-99. All you need to do is put your cam in (or sunbelt race cams). I would suggest checking your cams out 1st. That was the problem with mine. I had a bad exhaust cam. I can do $600 for the head. I can give you the contact info of the shop that did the work.
  #24 (permalink)
Old 12-02-2007, 09:15 PM
LUCIDDREAM's Avatar
CommTech2
What makes a cam go bad, do the lobes wear out?
And will that head give me more hp?
  #25 (permalink)
Old 12-04-2007, 03:56 PM
Rides:bmw e36 m3
e28m30 is a New Registered Member
Ok, listen I have been managing a small BMW repair shop for the last 10 years. The only way you bend exhaust valves is the MONEY SHIFT!! Got fourth gear beating against the rev limiter go for 5th, but get 3rd. I have clients that track e36 s52 year after year. Any motor will wear out eventually, but your s52 should be good for longer than 99k. MY 98 did not want to run to save it life this morning & ran on 5 the hole way to work... Replace the ignition coil($78.00) & spark plug connector($13.00). Fixed! If I did not have a front strut brace could have fixed it in under 10 min! Never seen an injector go bad yet on one of these engines, their is a first for every thing. Run a good heavy syn oil 20w50 red lion or 15w50 mobil one, change it every 3k or after each DE. DON'T OVERHEAT the engine & you will be just fine. Not saying you mechanics wrong, but my question would be. How do I bend just one exhaust valve??? Connection rod break??? Let me know & good luck!
  #26 (permalink)
Old 12-04-2007, 04:18 PM
Rides:bmw e36 m3
Just reread you post & I am afraid that you did the money shift. Did the tires chirp & the car jerk when you down shifted? Was the motor making a TACKING noise, not a ticking noise? The cylinder head should be ok. But you gotta pull it off & fix it. It's about 12hr labor, + parts & machine shop. Your not the first, nor the last. Drive any car long enough & hard enough & it will happen. It's just a question of weather or not the flywheel bolts give or the motor over revs.
  #27 (permalink)
Old 12-12-2007, 12:03 PM
LUCIDDREAM's Avatar
CommTech2
I really want that cam. But is it going to work in my M3? And will the machine shop guarantee the head?
  #28 (permalink)
Old 12-28-2007, 11:33 AM
goob_os101's Avatar
Rides:BMW, M3, 99
I bought the head originally from the Euro Depot and it came with a warranty. If there was anything wrong with it I would have sent it back. I can give you the shops contact info...
I do another person interested so please let me know asap
  #29 (permalink)
Old 01-13-2008, 07:29 AM
MMTuning's Avatar
BMW Motorsport Gmbh
Rides:1995 BMW M3 w LS6 swap and ;01 LS7powered E46 M3;E39 M5
MMTuning is a New Registered Member
A. you have bent valves
B. your pistons detonated
C. your rings broke and are allowing blow by.
A cyl pressure reading that is supposed to be 195-210psi reading 0, means the cylinder is not sealing, and the above is the possible problems. Good luck, start by removing the head. This will allow you to determine if the head is bad, the cylinder is failed or both.
Have a good one,
MMTuning
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477
