Old 04-17-2003, 12:52 PM
Rides:95 BMW 325is
tatawaki is a New Registered Member
Question cams are in, car running sluggish.. what's up?
I have a 325is
installed M3 cams with the JC Chip and my car has lost a lot of low end, and the top doesn't feel as fast as It was before. it idles close enough to what stock did, so I think they are installed correctly.
I'm going to go get it dyno'd and see what how the car is running, however I suspect it is running too rich or lean. how do I correct this without getting another chip reprogrammed.
errr... argh...
Thanks for your time.
Jeremy
http://www.bmwpower.ca
Old 04-17-2003, 02:37 PM
Rides:95 BMW 325is
bump.
Old 04-17-2003, 04:23 PM
E30mademepoor's Avatar
Faster than You
Rides:'97 Techno M3 Coupe
E30mademepoor is a New Registered Member
Bizzump... I dunno man, maybe one of the mods could move this to E36 Tech and help ya out?? Good luck
Techno ///M3
Old 04-17-2003, 05:03 PM
Rides:95 BMW 325is
a little insight on the problem: the techs who installed my cams, adjusted the timing to the stock spec for the 95 325is. is this right?
occasionally the car stalls from idle. when I tried the stock chip the car stalled pretty much every time I let go of the gas peddle.
when installing the cams, do they have to adjust the timing to an M3 spec?
There is no power from idle to 3.5k and after I floored it I smelled something burning???
PLEASE HELP.
Thank you for your effort and time.
Old 04-17-2003, 06:21 PM
scottycs's Avatar
Custom Turbo 328
Rides:e28, e30, e36, e39
Looks like the techs didn't align your cams properly. I would have it checked ASAP. Your car should run NOTHING like that.
You have the right chip? I don't think this would cause the problems you are having though.
-Chris
Old 04-17-2003, 08:59 PM
Arman's Avatar
Persian Baller
Rides:04 Jet Black M3
Arman is a New Registered Member
I had the same exact problem with my car when I had my Schrick cams installed, here is my thread on it from BF:
http://bimmerforums.com/forum/showth...ighlight=spark
The problem was the timing on them was wrong and also the vanos was not setup correctly. You should have it checked out by someone who knows cams well.
Good Luck
Old 04-18-2003, 12:00 PM
Rides:95 BMW 325is
any body know if you set the cam timing to the stock 325 spec? ( this is what the shop told me)
if so, then could it be the VANOS not installed properly? how do you check this?
what do I tell the shop, they say the timing is aligned 100% ( they double checked) can some one explain the process of how to set timing for the cams and how it relates to the VANOS unit?
unfortunatley these guys supposedly are the best for euro cars...
I have two weeks, until my driving school and I need to get this resolved asap.
Old 04-18-2003, 01:54 PM
scottycs's Avatar
Custom Turbo 328
THey could have aligned the vanos wrong. Yes, you set it to stock spec, which is the same as any other e36 6cyl.
-Chris
Old 04-18-2003, 01:58 PM
Rides:95 BMW 325is
Thanks, for the input.. Hopefully it will be just the VANOS not aligned, and that will fix it.
so to what I understand,
1) align the CAMS
2) align the VANOS
any other catchs that might cause problems?
Thanks everybody.
Old 04-21-2003, 07:27 AM
Rides:95 BMW 325is
I double checked, and they said they had aligned the VANOS and the TIMING (and they double checked.) what else could the problem be?
Old 04-21-2003, 08:41 AM
Chick Magnet
Rides:1993 325iA (Triple Black
JinXed is a New Registered Member
... off hand possibility - but it could be somethign wrong wit hthe VANOS - like a oil return line plugged or something. That would cause the timing to be off. I'm assuming you do regular maintenece on your car -so it wouldnt be something like fouled plugs. But they are worth a check too. -JinX
European... The only real Import.
"Dude, stop thinking police and start thinking Playstation - Blow shit up!"
Looking for: 5Spd Conversion - M3 engine(3.0 or 3.2 OBDI)/5spd tranny - 18" wheels
Old 04-21-2003, 08:48 AM
Rides:95 BMW 325is
car is regularly maintained. the techs who did my car check my plugs ( and it would most likley missfire then if plugs were going? ) I have never had any problems with the VANOS prior to installation of cams, either way I'm taking it back in on wednesday, and hopefully it will be resolved by then.
Old 04-21-2003, 06:11 PM
Hornswoggler's Avatar
Rides:'97 BMW M3
Region: USA - Great Plains
Hornswoggler is a New Registered Member
You should definately read all of Arman's threads on the topic... sounds like the same symptoms.
Old 04-22-2003, 06:58 AM
Rides:95 BMW 325is
well It's going in tomorrow, I will keep you posted on the situation...
Old 04-23-2003, 07:38 AM
Rides:95 BMW 325is
well went and dropped it off this morning, I mentioned it might be the VANOS not aligned properly. I asked them if they adjusted the VANOS, and they veered from the question... " we've done cars like these before and worked 100%" so I asked them if they had a VANOS adjusting tool, and they said no. I asked them "how can you do a cam job if you can't adjust the vanos, well they replied " you don't need every BMW tool to do a cam job. so I figure the VANOS is off, as they double checked the Timing.
so now I'm getting a quote from BMW to do the CAM and VANOS adjustment.
what a waste of money...
another thing: is it normal to tick REALLY Loud from 2k-3k rpm? sounds like the chain is loose or something... or I guess it could be the VANOS not aligned?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
