| 325is hp question what does a 1993 325is have for stock HP numbers at the crank? and what about at the wheels?...thanks guys. i was thinking 175 at the crank..am i close?
__________________ 1995 Avus Blue M3 - Lux. package, B&B Tri-Flo exhaust system, Dinan Euro HFM, Dinan Cold Air Intake, Jim Conforti Euro HFM Chip, UUC Motorwerks Short Shifter, Cross-Drilled Rotors. Stainless Steel Brake Lines best 1/4 mile - 14.003 @ 98.98 mph |
| yes, i got 192ps. but i think, "hp" is not the same as "ps", or? the euro-version has 141kW (kilowatt)=192ps. and the us-m3 is only a blasted 325 on 3l, less ps than the euro-version and much slower (220kmh), that means, that i would be faster in my euro325 (233kmh) than all the us-m3's (surly only in highspeed, not in accelleration). but someday, i will visit the states, to drive a bimmer on highways. cu HAN Oli |
| The US M3 (E36) has the same engine block as the Euro M3 but a different cylinder head. This was done by BMW NA to reduce cost. The US M3 has a much higher (or is it lower?) final drive ratio to give it comparable acceleration to the Euro M3. As for the 325is, the US spec vehicles have 189hp and 181lb/ft both at the crank. The Euro spec 325 has 192hp at the crank. I believe torque is the same. Remember from 1993 onwards the 325 has VANOS which just lowers the torque curve down the rev range. I have a 92 pre-VANOS 325is - has anyone driven both to compare them? Ive heard that the pre-93 cars have a more fiery top end. Mine certainly goes after 4000rpm!
__________________ "Golf - The best way to spoil a good walk" ~~Winston Churchill Sorry, image size exceeds maximum width of 400. |
| The reason why U.S. M3 only goes 220km is that BMW placed a speed limitor on all U.S. version cars. But keep in mind that the rev limitors can be overridden with either chips or software upgrades. Which means that without speed limitor, the U.S. M3s can easily hit 150MPH. That should beat the European 325's 145MPH top speed. ![]() By the way, the U.S. 325s have been reported hitting in the 140MPHs without speed limitor as well. Jon Quote:
| I've driven both pre and post 92 325s. To be honest they felt pretty much the same when you drive them around. ![]() But yeah you're right, the non vanos do seem to pull a bit harder in the high RPM range. Jon Quote:
| hi, i drive both versions to of the 325. i got (only) the version without vanos (i think so). by 4000rpm he goes like the hell, there is a really fat punch, which press you in the seat (yeah, sorry for my englisch, school is long away). the newer version is torque-optimized, he goes earlier, but softer i mean. the same you got with the e36 m3's: the older 3l/286ps is much more aggressive than the 3.2l version. cu HAN Oli |
| Hi HAN Oli, wo man sich so alles wiedertrifft... Hast Du mal die Fotos hier durchgestöbert, sind interessante Sachen dabei (hab mir jede Menge Anregungen geholt ).Viele Grüße, Marcel (der beim bmw-treff "Dresches" heißt) ![]()
__________________ Aus Freude am Fahren ![]() |
Maybe I will have to give a post-92 car a race. Anyone in the Detroit area wanna prove this one out...? ![]()
| Actually, even though the Pre 93 325s pulled harder in the top end, the 0-60mph acceleration between all E36 325s should be pretty close. The inconsistencies can be due to driver's skills, weather/road conditions, and the car itself. By the way, Car Stats is never really too accurate in my opinion. ![]() Jon Quote:
I'll still have to get a ride in a VANOS car tho - just to see the difference. Mind you - ive heard enough horror stories about VANOS getting rattly (read: expensive)
Why go to the expense of building an engine and then competely changing its internals for another market? From a manufacturing/supplier standpoint, that would be a very expensive and time consuming modification to something that is fundamentally the same. Curious...
Now let me explain why both the Euro 3.0L and 3.2L are different from their US counterparts. First off they are both hand assembled motors. The US is not as it is machine assembled. The Euros have different compression ratios than their US siblings. Both the US 3.0L and 3.2L have a 10.5:1 compression ratio, Euro 3.0L has a 10.8:1 and the 3.2L has 11.3:1. Then the pistons are different because of the compression and the difference in valves from the Euro head. Then we have the difference in the bolts on the head and the way the heads mount. Okay and the rods are different rods to hold up to the higher revving Euro motor. But you are right in that the Euro stroke and bore is the same as the US motor but that is all they have in common. And if you want the answer to your second question then think about why we didn't get the Euro motor. It never was because of emissions but cost. |
