  #16 (permalink)
Old 02-08-2002, 08:26 AM
Granty ('92 325's Avatar
Rides:A right and a left leg!
Granty ('92 325 is a New Registered Member
Originally posted by Seth Thomas
Why don't you tell me why you think they are the same?
Now let me explain why both the Euro 3.0L and 3.2L are different from their US counterparts. First off they are both hand assembled motors. The US is not as it is machine assembled. The Euros have different compression ratios than their US siblings. Both the US 3.0L and 3.2L have a 10.5:1 compression ratio, Euro 3.0L has a 10.8:1 and the 3.2L has 11.3:1. Then the pistons are different because of the compression and the difference in valves from the Euro head. Then we have the difference in the bolts on the head and the way the heads mount. Okay and the rods are different rods to hold up to the higher revving Euro motor. But you are right in that the Euro stroke and bore is the same as the US motor but that is all they have in common.
And if you want the answer to your second question then think about why we didn't get the Euro motor. It never was because of emissions but cost.
Interesting. If the US M engines are machine assembled, where are they assembled? I was always under the impression that all M engines were hand built in Germany.
I would understand the use of different shaped/sized pistons to alter the compession ratio due to the fact a different cylinder head was used. I didnt realise that the conrods were different. I presume dimensionally they are identical, but of a lesser grade material and therefore most probably weight more.
If you look at my first post in this thread I state that the reason why you have the different motor is due to cost and not emissions. I was just curious as to changes within the block. But as I said before, the main changes were to the cylinder head. OK i missed the pistons and conrods. my mistake. As for the bolts - thats the cylinder head. Yeah they mount into the block, but they would still be considered part of the head.
I see you have a lightweight. What is the differences with that? Is it purely body panels/interior trim??
"Golf - The best way to spoil a good walk" ~~Winston Churchill
Sorry, image size exceeds maximum width of 400.
  #17 (permalink)
Old 02-08-2002, 08:46 AM
Rides:1995 BMW M3 Lightweight, 1988 E30 M3 w/E36 M3 driv
Seth Thomas is a New Registered Member
I shouldn't say they are machine assembled but they are more of an assembly line assembly process than the Euro motor. But they are still built in Germany. I guess I missed your first post about the cost and emissions. What I caught was that it did not make sense to produce two different motors. But that is what BMW did and cost is why we did not get a Euro version. Plus the Euro motor needs more maintenance and is more costly to maintain. BMW did not feel this is what the US wanted.
The LTW is a little more than body panels. They came with handpicked 3.0L US motors, GT dual pickup oil pan, GT rear spoiler with spacers, adjustable front splitter, xbrace, front strut tower bar, cloth interior, less sound deadening, no a/c, no radio, 3.23 diff, staggered wheels, stiffer suspension, aluminum doors and a few other goodies. Only 125 were made and they all came in white with the checkered flag stickers.
Seth Thomas
M3LTW Homepage (Click image to go)
1988 E30 M3 with 3.0L power
1995 M3LTW with individual TB
2000 Chevy Dually
2002 Ducati 748S
  #18 (permalink)
Old 02-08-2002, 10:18 AM
Wow I like the lightweight. Have you tried it against a "normal" M3? Hey a quick (stupid) question. Did the US get both the 3.0 and the 3.2L??
  #19 (permalink)
Old 02-08-2002, 01:42 PM
Banned by Warnings
Rides:i use to drive 325 is
PerriBMW is a New Registered Member
i can verify 138
I GOT MY 94 325 IS UP TO 138 ONCE , IT SOUNDED PRETTY CLOSE TO THE LIMITER AND I WASNT GOING TO FIND OUT HOW CLOSE.
PERRI
  #20 (permalink)
Old 02-08-2002, 09:44 PM
I have tried the car against other Ms and nothing compares. The car rocks them all. Never had anyone in another M3 compete.
The US did get both the 3.0L and 3.2 US motors. Both were rated at 240hp but the 3.2 was rated at 236ft lbs of torque vs the 225ft lbs of the 3.0.
Seth Thomas
2000 Chevy Dually
2002 Ducati 748S
  #21 (permalink)
Old 10-11-2009, 10:32 AM
Registered User
Rides:bmw's
bavarianimports is a New Registered Member
uhmm to correct i have a 93 325is with vanos and i pull harder than 92's and yes i will prove it if anyone wants to try.
  #22 (permalink)
Old 10-11-2009, 10:33 AM
Registered User
Rides:bmw's
and yes i know bringing back a old thread, haha
  #23 (permalink)
Old 10-14-2009, 06:08 PM
Registered User
Rides:BWM
liuhan is a New Registered Member
welcome to my website
Wholesale Nike Shoes,Wholesale Jordan,Wholesale handbags,Wholesale t-shirts,Cheap Jordan,Air Max,Shox,Prada Shoes,LV,Chanel,Coach,handbags,wallets/purses,Hoodies,Jeans,Shirts,T-shirts. - Home Page
here you can find your favourite products ! don't miss the good chace ! !
  #24 (permalink)
Old 10-29-2009, 07:32 PM
Registered User
Rides:BMW 328is 1997
Qc.Vision is a New Registered Member
Originally Posted by liuhan View Post
spam???
  #25 (permalink)
Old 11-04-2009, 10:46 AM
Jaffa_007's Avatar
Club President
Rides:Bmw,325i,95
Jaffa_007 is a New Registered Member
Taken from BMW FastFacts books (which is an internal book)
2.5L 6 Cylinder 189 hp Gas Engine
Specifications
Type Gas
Number of Cylinders 6
Cylinder Configuration In-line
Number of Valves 24
Displacement 1000.0L (999,990 cc)
Fuel Capacity 21 Gallons
Compression Ratio 10:5:1
Camshaft Configuration Variable Timing
Horsepower 189 @ 5900 rpm
Torque 181 @ 4200 rpm
Fuel Delivery Name Sequential Port Fuel Injection
Bore x Stroke 3.31 x 2.95
BMW stellt das beste Auto her
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
