  #46 (permalink)
Old 03-03-2009, 03:11 PM
Rides:BMW 318i 1985
fourdoorfanatic is a New Registered Member
i have done an m3 swap into a 98 318ti. the car is a little monster. it was expensive for the customer. if you can do it yourself and have a decent donor its really not all that expensive. i mean, people say an m50 into an e30 is expensive and mine turn key (i had a single cam 4 cylinder before, so i had to replace everything from the radiator back to the differential with 6 cylinder stuff) was around 800-900 dollars out the door, engine and all. but i did all the work myself.
  #47 (permalink)
Old 03-11-2009, 07:54 PM
Marlin_318i's Avatar
Rides:BMW 318i 1998
Region: USA - Great Plains
Marlin_318i is a New Registered Member
ok
  #48 (permalink)
Old 03-11-2009, 08:46 PM
Diablo13's Avatar
Rides:BMW 325is 1994
Diablo13 is a New Registered Member
Don't forget about camshafts. Look into the Schrick cams. They provide a hefty amount of power.
  #49 (permalink)
Old 03-24-2009, 07:55 PM
blacklove7777's Avatar
Rides:bmw,325is,95
blacklove7777 is a New Registered Member
yea for the four cylinders you have intake and exhaust, but its not the greatest power achievement, but the 318 was built as an economical alternative most race 318's have turbos when this is done it can produce some serious numbers but i looked over a few of the other post that a few of the members have posted and for the most part there right you sound like you love the way your car drives so keep it and add intake and ex.concentrate on improving handling can make your car feel like it has more power but for the most part , two options turbo and boost like crazy cause your tiny four cylinders are only four -but its strong very strong. Two start thinking m50, s50 upgrade not hard at all anythings possible 4cyl's can beat an m3 let the force be your guide. PEEAEEEEEEEE.
  #50 (permalink)
Old 03-25-2009, 09:38 AM
Rides:BMW 318i 1998
thanks alot...how much would it cost to swap in an m50
  #51 (permalink)
Old 03-25-2009, 10:07 AM
frank1975's Avatar
94 318i
Rides:94 318i
Swaps are not worth it since E36s are so inexpensive. The only swap I'd consider if I were into them is an I6 in a TI.
E36 Parts For Sale
  #52 (permalink)
Old 03-30-2009, 02:35 PM
Gio-MTW's Avatar
Rides:1998 E36 323 M-Tech.
Gio-MTW is a New Registered Member
Originally Posted by Marlin_318i View Post
yea thats it in my avatar...i need to tint my windows tho.
hello there....
dude i complain about the power too so i clearly understand you
first of all, you not even got those 140 HP,only is gots 140...you must have a 116 and its damn low...
so listen up,give you some advice....
intake and exhaust,after that chiping would be a great idea...
  #53 (permalink)
Old 03-30-2009, 06:04 PM
iferro's Avatar
Rides:94 325i
iferro is a New Registered Member
Originally Posted by Gio-MTW View Post
hello there....
i dont think any of that makes sense...
  #54 (permalink)
Old 03-30-2009, 06:46 PM
Rides:BMW 318i 1993
mugen08 is a New Registered Member
hey no ones suggested it for a reason but its always an option you could go nitro get some 50 hp i have a zex system right now but not for long gonna do an m3 swap if all goes according to plan
  #55 (permalink)
Old 03-30-2009, 07:27 PM
frank1975's Avatar
94 318i
Rides:94 318i
Maybe for track, but It's not cheap for daily driving at $4 a lb. My friend had it in a Z28 and went through a 20lb bottle a week.
E36 Parts For Sale
  #56 (permalink)
Old 03-31-2009, 08:29 AM
Rides:BMW M3 1995
Xear0 is a New Registered Member
$4/lb? the stuff here is like $7/lb...
95 Schrick'd ///M3 Auto
Schrick Cams, 3.91 LSD, 24# inj., Euro MAF, K&N CAI, Performance Cyl Head, Turner Cam Chip, high flow cats, Supersport Exhaust, Hella Celis Angel Eyes, Rondell 63 Wheels, Bilstien Sports, H&R Sports, Stillen X-Drilled Rotors, Brembo Pads
  #57 (permalink)
Old 03-31-2009, 03:35 PM
Gio-MTW's Avatar
wrong
so let me tell your wrong....
if intake and exhaust + chiping wont help than waht will...can you tell us?
(i mean the easy modifications coz engine swap and turbo charging isn't hard to figure)
with this mods i gain 40 hp out of my 323 and now it has 210hp instead of 170...
it was way easy and cheap and i think 40 hp makes some difference dont you?...after this increase car is rolling 255kmh in 5th gear and become 325,328 killa !!!
this are the basic mods for ANY car in a world so think before say something ok man...
  #58 (permalink)
Old 03-31-2009, 05:51 PM
sergi037's Avatar
Rides:BMW 325is 1993
sergi037 is a New Registered Member
The best thing to do is not overshoot the capabilities of your car. It may never beat out an m3 without serious engine reworking. (i.e a port and polish job, lightweight pistons and rods, titanium valves, etc.) so dont expect to be able to without some serious cash (unfortunately because it would be awesome to see a 318 kick an m3). Running a turbo will help but considering your mileage i would just go with a good intake and exhaust setup. Probly cat back because dropping $900 on headers doesnt make alot of sense unless you want to rebuild the whole engine. Face it..with those miles you may or may not have alot of life in the car so I would decide first if you want to stick with building this engine or swap it when this on dies for a bigger one...and go from there. Hope that helped.
  #59 (permalink)
Old 04-01-2009, 06:43 PM
Rides:BMW 3 Series
BimmerKidE36 is a New Registered Member
Another inexpensive mod is the Dinan ECU replacement chip
~~~~EaZyE36~~~~>
  #60 (permalink)
Old 04-03-2009, 11:51 AM
Rides:BMW, 318i, 1994
asoccerdude113 is a New Registered Member
your car looks fresh...the tint would help it alot...
But check this out
Performance
that site has intakes, exhaust and computer chips which can help you out
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
