| i just installed asa 18x8's in the front an 18x9's in the rear no problem.... but with full race suspension you will need wheel spaces tho an depending on the ride hight you set it at possible rolling up the inside of the fenders or fender flares! ps without the wheel spacers even on stock suspension turning to the extreme right or left with cause the tire to rub on the inside of the rocker panel!!! |
| cmoubell, i have this same exact problem. Im running 18 x 8.5's on 235/45 tyres and when i give more than 2 full locks either directions scrubbing happens. Im planning to put in the Bilstein/Hr Shock/Spring combo giving a 2inch drop on the front. My question is, how many mm spacers am i going to need?? any tips to make this all fit? |
| should do the trick! you'll need at the very least 12 mm spacers! that should work alright with most aftermarket suspensions! as long as u dont have fiber glass drift fenders like me, modifying your metal fenders isn't too hard of a fix if they rubb! fender flares or a widebody kit will look even better if you have the scrilla for it tho ! ![]() PS make sure you get proper wheel spacers, if you need hub-centric or non-hub centric ones! it will depend on the rim you have! good luck!
__________________ '92 BMW 325i -ASA 18x8 inch rims with the optional 9 inch wide rear rims. (12 mm front wheel spacers) -Bridgestone Potenza Sport Tires. -Drilled/slotted rotors. -Fully adjustable suspension; ride hight and 4 way dampening. -Fiberglass Slotted Drift Fenders. -LED Blacked Taillights. -Blacked Halo Headlights. -35% Window Tint. -True Cold Air Intake. -Aztek stainless steel headers -3" Custom Magnaflow Exaust and new O2 Sensor. -100 wet shot NOS, 10 lb tank -Poineer Deck and Three 10” inch Concept subs & Amp in custom box with capacitor. "chic's digg the beemers" -cmo |
| i just lowered my car, i put bilstein strut&shock and h&r spring. but the right side on my car is more lower than the left side of the car. the ride height is not even on each side. could someone help me out with this? |
| Before i lowered my car, I just found that my right front and rear wheels are more lowered than the left front and rear wheels. That's why i put H&R Race spring 2.0 inches on the front and 1.3 inches on rear. All springs are brand new and the Struts & shocks are brand new and i replace my strut mount too. I thought if i replace everything my wheel gap from left to right will get even, but its still the same, nothing change, still uneven gap. Could you help me out with this, THANKS A LOT |
