Old 05-26-2008, 01:56 PM
Rides:1993 BMW 325I
Stevens 325I is a New Registered Member
Cool Running Rich/ Weird Exhaust Noise
the noise sounds like a ticking noise when the engine is idleing...im new to these cars so it might be normal but i wanted to see what is up with it....i also seem to be running rich (no check engine light though) it smells really strong out of the exhaust...i changed the plugs with bosch platinum plus 4's and put new coil packs in and its still the same and i pulled them out today and they all look the exact same...none wet etc...
heres a video of the above mentioned noise
100_2736.flv - Video - Photobucket - Video and Image Hosting
Old 05-26-2008, 03:13 PM
I could not hear anything from the engine, but that exhaust is very odd and sounds scary. It sounds like you have an exhaust valve that is badly burnt or bent. You seem to be idling on 5 cylinders. One plug should look bad.
If the sound you hear under the hood is a mechanical ticking, the problem could be at the cam rather than at the exhaust valve.
If the sound you hear at the engine is an exhaust leak from the exhaust manifold or manifold gasket, then it could be a bent exhaust valve. Big leaks near exhaust valves can bend them due to sucking in cold air when you take your foot off the gas. The cold air comes in and hits one side of a red hot valve stem, and it's all over.
I would get hold of a compression tester and get some readings. If you have really bad compression on one cylinder, and you have a way to pressurize it through the compression tester hose, you might be able to figure out where the leak is. In a quiet garage, bring the cyl up to TDC compression stroke, pump in a few psi of air, and listen at the oil fill, the throttle body, and the exhaust pipe for the sound of escaping air. Remember that the compression tester hose has a one-way check valve in it somewhere. You may have to remove it in order to pressurize the cylinder through that hose.
It is probably not a good idea to drive this car until you track down the problem. If it is one of the things it sounds like it is, driving it will only make things worse.
Is this engine stock? Some have suffered from cracked exhaust manifolds, but not bad enough to damage anything. Bent/burnt/broken exhaust valves don't often happen on stock 6 cyl BMWs, and cam problems are rare on stock engines with less than 200k miles, unless they are run low on oil.
Old 05-26-2008, 06:41 PM
Rides:1993 BMW 325I
the ticking noise can be only heard from under the car and at the exhaust pipe...the engine is stock..the exhaust is not cracked anywhere from what i can tell...why does it run rich then?
Old 05-26-2008, 07:58 PM
What is the symptom of rich running? Are those exhaust tips as black inside as they look in the video? If so, yup, its way rich.
A ticking sound under the car is usually an exhaust leak. You generally need to put it on ramps and run your hand along the pipe to find the leak. However, if you can't hear it in the engine compartment, then it is not right up at the exhaust port, so that leak can't have hurt an exhaust valve. Exhaust leaks down lower but ahead of the cat can confuse the oxygen sensors and can set a code, (and cause the engine to run rich as it tries to get rid of the excess oxygen that the second sensor is detecting) but do no real harm.
You see, with only three cylinders on a pipe, at idle, there is a distinct low pressure area between exhaust pulses, so a leak will leak both inward and outward at idle. The in-leak introduces oxygen to that exhaust, which the car interprets as very lean operation on three cylinders, and it tries to correct.
The noise I was hearing at the exhaust sounded a lot scarier then just a rich idle, but hope springs eternal.
Old 05-26-2008, 08:04 PM
Rides:1993 BMW 325I
when i say rich im talking eye watering rich...it has a strong smell to it. my buddy was riding behind me and he said its strong as hell and couldn't stand riding behind my car..the ticking noise is not really loud but is noticeable you cant hear it in the car but once outside you can hear it ..i opened the hood and listened around and could barely hear the ticking noise once i got my ear near the passenger side of the motor but when i get under the car it really sounds like a leak bu i cant find any leaks anywhere downstream but near the motor i cant get close enough because its hot..lol
Old 05-27-2008, 05:56 AM
Looking for a leak with your hand works best if you do it in the first few seconds after you start the car - unless you have asbestos hands ;-)
The rich smell could also be the result of running on 5 cyl and dumping the raw fuel from the 6th cyl back to the cat to be burned there. This can heat your cat up to red hot and destroy it.
Old 05-27-2008, 03:52 PM
Rides:1993 BMW 325I
if its running on 5 cyl then what would cause it? ive replaced the plugs and coil packs and hasn't changed anything
Old 05-27-2008, 09:23 PM
Next step is a compression test, and then a leak test on any cylinder with bad compression to see where the leak is.
Another way to see if you are running on 5 and find the culprit cylinder is to check the temperature of each exhaust pipe at the head. An infra-red non-contact thermometer is great for this job. I have to use my hand, so I have to do it in the first few seconds after the car starts.
Old 05-29-2008, 02:36 PM
Check the o2 sensor
The Tuner Source
Old 05-29-2008, 07:45 PM
Rides:1993 BMW 325I
alright i pulled off the muffler where it unbolts after the cats and you can hear the ticking sound alot better....here is a video of the noise...everyone says misfire but i replaced the plugs and coil packs to no avail...help please!
Old 06-01-2008, 12:33 PM
Rides:1993 BMW 325I
ok i pulled the valve cover and all the springs look good none collapsed or broken it also seems really clean in there and springs look newer...
Old 06-01-2008, 02:33 PM
Rides:1993 BMW 325I
upon futher inspection...everything is moving like it should from what i can tell so.....guess im going to be swapping motors...tired of it feeling like its running on 5 cylinders
Old 06-02-2008, 07:57 AM
Did you ever check compression?
If I were thinking of swapping motors, I would pull the head and have a look before going to all that work, and I would not pull the head unless the compression tester told me there was something fishy going on in one cylinder.
Old 06-09-2008, 07:49 AM
Permit Holder
Rides:1993 BMW 325I
PKJai is a New Registered Member
I've got a very similar situation - "puffy" exhaust sound, leaky exhaust smell, ticking sound, but add to it a lack of torque.
I noticed the ticking sound stopped when I stopped the physical movement of the exhaust by applying pressure to the tailpipe with my foot - so the ticking could be from added vibration?
Have you checked for holes in your exhaust system?
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456
