Old 04-14-2008, 06:18 PM
Track License
Rides:1995 325i
NewYorksbmwe36 is a New Registered Member
brake light circut??
my computer says brake light circut? but both brake lights work..sometimes it goes on and then i wont see it for a day or two.anyone have this problem?n what can i do to fix it?thanks
Old 04-14-2008, 10:34 PM
RacerJames666's Avatar
Check for moisture in the connectors at the taillights.
Do you have aftermarket tails installed by chance?
Old 04-15-2008, 05:49 AM
Rides:BMW 328i 1996
Tassie_328i is a New Registered Member
Brake Light Circuit failure is generally a failure of the sensor/switch behind the brake pedal.
Must be on the way out.
Old 04-15-2008, 06:56 AM
Back up to a wall and watch the rear-view mirror as you press the brake 15-20 times. Make sure that the lights light up EVERY time you press the brake. If they fail to light even once, get a new brake light switch that fits behind the pedal arm.
The switch is inexpensive, but it is a bit of a PITA to get at. Replacing it involves standing on your head, and small hands and small tools are helpful. You have to crush the old switch to get it out, which tends to bend the bracket, so be sure to straighten the bracket to center the switch on the brake pedal arm after you snap in the new switch.
On one of my e36s, I had some trouble with continuity in the tail lights, so I removed the assemblies (you have to stick a pry bar in through the bulb holes in the body and pry to break the rubber seal loose from the body). I then ground off the tips of the plastic pins that hold the sockets in place on the tail light assembly, and then soldered the pins to the metal traces. The pins are just dry-crimped to the traces, so loosness and corrosion are possible. After soldering the pin connections, I used JB Weld to epoxy the plugs back on over the pins. I also buffed up the traces around the bulb sockets with steel wool. The whole job took about an hour, plus time for the epoxy to dry before reassembly. With that and a new brake light switch, I eliminated brake light warnings for the past several years.
Old 04-15-2008, 11:02 AM
gixerdave1983's Avatar
Rides:E36 M3 3.2 97
yeah on most e36 brake light switches they have 4 wires goin to them where most only have 2, a positive and a negative as such, on e36s they have to circuits, one for the actual brake lights themselves and the 2nd circuit is to tell the abs when the brakes are on, the abs circuit needs to be a much lower resistance which is why they have 2, this is why you can have a warning but still have brake lights
Old 04-16-2008, 02:49 PM
Track License
Rides:1995 325i
allright thanks guys ill try some of those ideas over the weekend and tell you how they worked out.
Old 04-23-2008, 12:10 PM
Jaffa_007's Avatar
FasterThen You Think
Rides:Bmw,325i,95
Jaffa_007 is a New Registered Member
i had that problem with my car, i replaced the brake sensor and it still happened, turns out that is was the bulb holder itself.. the contacts had huge hole in them simple 10$ fix
Gotta Love Mischief.......All Kinds
Speed is very much like a narcotic, it's mostly illegal and you always want more.
Old 04-23-2008, 01:26 PM
moonpie_murders's Avatar
Rides:bmw, 325i, 1992
moonpie_murders is a New Registered Member
mine does the same thing. i haven't found out what it is yet. everything works. it had HID's installed by a previous owner and i know they are on different circuits but that's the only thing i can think of. nothing is wrong with my break lights.
Old 04-23-2008, 03:04 PM
Track License
Rides:BMW, 328i, 1996
nousablenames13 is a New Registered Member
There's another switch in the tail lights somewhere. I didn't do it cause I didn't feel like electronics hunting. It's about $20. If you see the brake light circuit failure it's either the switch by the pedal or more likely the switch by the lights. I got my light switch replaced and the error went away.
Old 04-23-2008, 05:00 PM
Aftermarket tails by chance?
Or improper bulb wattage?
Old 04-26-2008, 06:12 AM
Track License
Rides:1995 325i
no they are stock taillights.i just changed the brake light buld like maybe a month ago and now that just went out.i dont know what is going on with my left tailight.
Old 04-26-2008, 09:30 AM
Get a friend, a bentley (wiring diagram) and a multimeter.....and maybe a brew for you and your "pedal pushin" friend.
EDIT: Do your bulbs look funny when they burn out? I had a problem with water running down into my taillights, and with hot bulb and cold water they went POP, and looked kindof blackish brown(sometimes exploding)....its little more rare than brake switch, but it can happen
Old 04-26-2008, 05:27 PM
Track License
Rides:1999 BMW M3
ballin_e36m3 is a New Registered Member
i had the same problem and the same symptoms it was just the brake switch behind the pedal
Old 04-28-2008, 09:59 AM
Track License
Rides:1997 3.28is
tciambotti1 is a New Registered Member
clean off any rust or anything that might have gotten on to the holders for the brake lights themselves. Mine did it till i got fed up enough to rid both taillights out and clean everything. No more problems and sqeakky clean taillight housings!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566
