Old 02-25-2006, 08:57 AM
Registered User
Rides:92 325i
chinamaneggroll is a New Registered Member
HELP!!!
DAMNIT...i replaced my daym starter two weeks ago because it was bad. now, my starter is bad again. don't worry guys...i have warranty on it but does anybody have any idea what may have caused the starter going bad? please let me know asap. i'm on my way right now to pick up the new starter. thanks a lot you guys.
[ bim ///M3 rb0y ]
Old 02-25-2006, 09:31 AM
danny522's Avatar
More O.G. than ELMO!
Rides:92 318is SOLD, 03 WRX
danny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master Licensedanny522 has achieved their Master License
Are you sure your starters bad? i replaced my starter over a year ago and then a couple months ago it started messing up and when id try to start it the starter would just make one click then do nothing. Well i assumed it was the starter so i took it back where i got it done at cuz it was under warranty and it turned out to be just curroded +/- wires behind the firewall making it not get a good connection.
H&R Cup Kit | Depo 5000k HID's w/angels | Hamann Kit | Clear Tails/Corners | 17" e46 Rims | Reiger Roof Spoiler
Old 02-25-2006, 11:21 AM
Registered User
Rides:92 325i
my stepdad [bmw mechanic] says its the starter for sure. but do you think its really the starter or something else? he says its not the wires. everything is good. so i dont know now...
[ bim ///M3 rb0y ]
Old 02-25-2006, 02:28 PM
high roll'a
Rides:bmw, 325i, 1995
tophermack is a Permit Holder
was the fly wheel/ring gear ever replaced?
Old 02-25-2006, 05:57 PM
Registered User
Rides:92 325i
its not the fly wheel or ring gear. we also have a head gasket leak and that could also be a problem. basically...water going into the engine...?
Old 02-25-2006, 09:17 PM
Rides:99 M3, 05 R6
dcmetro240 is a New Registered Member
I don't think a head gasket leak would cause what your explaining. Sound more like batter starter or connection somewhere. Check all your connections, espically to the battery I have seen corrision on the wires to the battery cause the same problem. Good Luck..
Old 02-25-2006, 10:45 PM
danny522's Avatar
well if your step dad is a bmw mechanic then why are you asking us?
Old 02-26-2006, 06:36 PM
White318i's Avatar
All show, no Go!
Rides:June 91 318i
White318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master LicenseWhite318i has achieved their Master License
Check the starter relay. Check for corrosion and that it clicks when the igintion is turned. Give the relay a good hit if it doesn't click and try again.
Swap it out with a known good relay if there is another of the same kind in the fuse panel and if it all works sweet then buy a new one!
If the Relay, Connections and Wiring are all good then it's most probably the starter. Check everything don't assume it's ok or you'll be chasing your tail trying to find the cause.
Luke.
I can't think of anything Witty or Smart to put here...
Open for Mothers Day Dinner
