| help e36 325 i swap m3 95 what engine harness do i use or can i use i need help i am installing a 95 m3 engine in my 4dr 325i . i received the motor without a engine harness. this is the problem i know that i can't use my stock engine harness off my stock motor because vanos did not come out until 93 n my 325i motor did not have vanos. since finding a real m3 motor harness is so difficult i was wondering could i use a 325i engine harness that has vanos on my m3 motor n will everythong plug right up because i have a m3 ecu but no engine harness .has anyone done this swap and use a vanos e36 325i 0r 328 harness obd1 on a m3 motor obd1 would reall appreciate the help n the right info |
