Old 03-01-2005, 07:53 PM
DuskShatters's Avatar
My mom bought my car
Rides:93 bmw 325is(na) & 86 mazda rx7(na)
DuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master LicenseDuskShatters has achieved their Master License
HELP! tierod replacement
ok im stuck. i cant fit my wrench in to loosen the end of the tierod because i think this gold plate is in my way. i got pictures. please help.
future plans: fix it...
Old 03-01-2005, 08:19 PM
Rides:'98 M3
reavisM3 is a New Registered Member
That gold plate is a lock to keep the tie rod from backing off. Just bend it out of the way and use a real skinny wrench or a set of big channel locks(adjustable pliers) to break the tie rod loose. Yes, you should replace the lock but some people reuse them. Make sure to get a four wheel alignment after the repair.
1998 Arctic Silver M3 Sedan
Mods: Full AA exhaust, CAI, 3.5" MAF, BB throttle, M50 manifold, 24# injectors, AA ltw flywheel/clutch, TMS pullies and some suspension mods.
Old 03-01-2005, 09:04 PM
Rides:BMW 325is 1992
kinghawk is a New Registered Member
The hell happen to your tie rod? That happen from your accident?
Old 03-01-2005, 10:03 PM
werd when the truck fucked my car up it yanked on my wheel i gues.. im not sure how that would work but thats what happened
Old 03-01-2005, 10:05 PM
how far are you located from santa rosa?
Old 03-01-2005, 10:49 PM
mm 1hr30 to 2hr i think.
Old 03-01-2005, 10:52 PM
was willing to help you out if you were closer
Old 03-02-2005, 12:41 AM
Irish5.7's Avatar
dood
Rides:'95 M3
Region: USA - Great Plains
Irish5.7 is a New Registered Member
I'd personally replace that locking nut and probably the boot also, it's so cheap if you can afford the car to be down a bit longer to order them.
Old 03-02-2005, 07:22 AM
haha thanks kinghawk, are you going to bimmerfest in april?
Old 03-02-2005, 06:15 PM
woot i got it out thanks reavis
Old 03-02-2005, 06:51 PM
Got much info about bimmerfest? Would go........where is it about?
Old 03-02-2005, 06:55 PM
Rides:'98 M3
no problem, any time
Old 03-03-2005, 06:52 PM
ok i need help again. im putting the tierod back on and where it links up to the wheelside. the nut that goes on it. it keeps spinning, err the stud does so my nut isnt getting on. i tried useing a airgun its still not working
Old 03-03-2005, 07:12 PM
Rides:'98 M3
It is a tapered fit. You have to push the ball joint at the end of the tie rod up into the hole on the steering knuckle. Use a floor jack or just try pushing/pulling up on the ball joint real hard while tightening the nut.
Old 03-03-2005, 07:37 PM
swoop's Avatar
Got Bimmer?
Rides:2002 X5 ; 95 325is ; 99 Cavalier
swoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Memberswoop is a New Registered Member
i believe revis is right.. it's an easy 2 man job.. one person pushes/pulls on it and the other one tightens, or have a bottle jack and possible a peice of wood to set it on in case your car is too far off the ground to reach. best of luck, invest in a bentley service manual though, and your shade tree skills rock!!!
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379
