Go Back   DTMPower BMW Forum > Technical Discussions > E30 M3
Old 08-30-2002, 10:34 AM
Yes.
Rides:325is, M3
einhander is a New Registered Member
Need help with S14 swap
Hey guys I need some advice in swapping engines in my two cars. Are there any sources that would provide information or advice as to how to make this any easier? Anyone know of any special tools? I think I have what I need but I'm probably forgetting something. Any help would be awesome.
Old 08-30-2002, 12:47 PM
BMW Club Racer's Avatar
Rev It Up Champ
Rides:2008 Corvette 1LT Z51
BMW Club Racer is a New Registered Member
what are you swapping the S14 Engine into? I'm in the process of doing that swap my self, except its going into an E21.
Old 08-30-2002, 10:50 PM
Rides:88 BMW M3, 98 BMW 528i Sport
Reelizmpro is a New Registered Member
He has 2 M3's and he wants to do a straight across swap.
Barry Robinson
85 325e/325iS 2.7 (rip)
88 325iS
88 M3
Old 08-31-2002, 01:19 AM
Rev It Up Champ
The Factory Service Manual is probably the best source of information to help you with the swap. There are no really special tools that are needed for the swap. Since you are installing the same engine you are taking out, its pretty simple, and is just a bolt in process, everything lines up in the same place.
Is there some specific info you are looking for?
Old 08-31-2002, 06:40 AM
Yes.
Rides:325is, M3
No, I was just checking to make sure there are no hidden things that should be taken care of. I have all new engine and tranny mounts and the manual. Just being overly cautious. Thanks for the info. Barry is your M3 all done (the power upgrade I mean)?
Old 08-31-2002, 06:42 AM
TOLOFOU's Avatar
Screw Driver
Rides:Streetsweeper
TOLOFOU is a New Registered Member
I would lik to hear more on the E21 s14 swap.. What all has to be done.. I have a 1980 320i
Rob
Check out my site at:
http://www.tolofou.com
Old 08-31-2002, 08:00 AM
M3 Ryan's Avatar
Gangemi Spec
Rides:'88 E30 M3, '92 325iC Turbo
M3 Ryan is a New Registered Member
I did this in a day, on the street with a jack and 2 jack stands. Just needed a wrench to remove the clutch fan, everything else was very stright forward.
no new gaskets are needed, but I would reccomend some new hoses, and some will be in rough shape and will need to be replaced...
good luck!
Ryan Gangemi
'88 M3 2.5L Lachssilber/Black
'87 535iS 3.5L Lachssilber/Black
Old 08-31-2002, 08:43 AM
No, it's been put on hold for the time being.
Barry Robinson
88 325iS
88 M3
Old 08-31-2002, 12:07 PM
Rev It Up Champ
Rob
Hi Rob,
An S14 engine swap is a pretty complicated swap into an E21!
Parts you will need:
S14 enigne w/ engine harness, AFM and ECU
E30 M3 Transmission w/M3 shifter linkage or modify the 320 linkage
M10 oil pan modified to take the S14 oil breather
M10 motor mounts and block mounts
320i Tranny mounts
E28 5 series, E30M3, E36 M3 or any of the big block enigne cars, you will need the front part of the driveshaft since it has the larger coupling to match up to the M3 tranny. You will need to have the 320i driveshaft shortened and have the M3 coupling installed on the 320i driveshaft
E30 M3 radiator, the E21 lower radiator supports will need to be cut and lowered approx 1 inch or have a custom radiator made
you need the Euro323 coolant expansion tank, and have the mounts made on the right front shock tower
then comes the fun of wiring everything together, and you will need the Body to Engine Harness Connector since you don't want to cut the M3 wiring harness and would rather cut the Cheaper 320i Harness to wire everything to.
there are a few other things that need to be done, but they need to be figured out during the swap.
You will also need to mount the battery in the trunk
Old 04-01-2009, 02:15 PM
Rides:BMW 320is 1983
Region: USA - Great Plains
Duc748 is a New Registered Member
My S14 Swap in my 1983 320is
Everything seems pretty straight forward but I am curious about a few things. Will an E-30 M3 exhaust system follow the same path under my E21 320is? Or, is this going to be a custom job that I'll need to weld up? I have heard mixed things about the Speedo hook-up? Will the S14 work with my existing fuel pump and delivery system? I am pulling my stock engine and tranny this next weekend and going to start clearing the work area, removing the battery tray, and sizing things up. The new engine is a healthy one out of a 1990 M3 that had and S50 swap done on it. Any advice will be greatly appreciated. What do people think about me running the stock steering rack? Can I drop in a different system with power steering? Thanks in advance. Chad
Old 04-01-2009, 08:32 PM
Rides:BMW 318i 1985
fourdoorfanatic is a New Registered Member
you know the rest of your driveline will bolt up to the s14, right? the trans will bolt up, along with the flywheel and such. (people will say it won't hold up, if you beat the everloving shit out of it dumping the clutch every second you can, maybe not, but c'mon, its a high strung four cylinder, not a brutish s50 or something like that.) its essentially the same block. if you do it that way, speedo is unaffected. m3 trans has a...freeze plug thing (?) in the same spot as the 320 trans has the cable. it should be do-able that way as well, though im not positive. m3 trans has a bigger output flange so your driveshaft won't bolt on. erm.... your 320 is csi injection, right? if so the pump (s) are plenty capable of running the engine, the regulation of fuel is on the backside of the fuel rail. the only thing im not terribly sure of is the accumulator back at the fuel pump (stock 320), im not sure if it needs to be bypassed or left alone... *shrug* the car is light, throw power steering away!!! :P i don't use power steering in my e30 m50'd car, it hasn't bothered me a bit. good luck man! will be a proper sleeper.
Old 04-02-2009, 06:18 AM
S14 swap details
I do have the e30 S14 transmission that I would like to use and adapt the speedo if anyone knows how to pull this off? So it sounds like I will need to cut and modify my driveline to bolt to the M3 transmission flange. Someone said something about modifying the area around the shifter linkage openning? I guess I'll find a lot of this out when I set the engine and tranny in. Is it easier to put them in as one or should I remove the tranny and bolt it in from the underside. I've done this on the 320is and it was a pain.
That is good new about the fuel system.
Does anyone know if the fuse panel needs to be relocated or if it is fine where it sits?
Thanks for everyones help
Old 04-02-2009, 05:32 PM
Rides:BMW 318i 1985
i personally always put the engine and trans in seperately, but i have a lift at work so im not crawling around on the ground. fuse box...it might be tight there, are you using the s14 airbox and all or something a little "colder"? im trying to remember exactly how inward and forward the 320 fusebox is, probably really tight with the s14 box. as for your shifter, i was thinking, you could use and modify your "steel plate" carrier setup you have now rather than the aluminum carrier, shorten it as needed. thats what i always did with 5 spd conversions in 2002's, shortened the 2002 plate to fit accordingly.
Old 04-06-2009, 11:26 AM
I have all of the stock air intake assembly for now until I get the engine in an get it running. how much difference will I notice between my stock 320is tranny and the M3 tranny. If I don't need to cut or shorten the driveshaft that is great but if the M3's transmission is far superior, I will do what is necessary. Do you know if the exhaust system takes the same path front to back on both models, or will I need to custom fit a hi-flow exhaust system? Cheers for any info.... CHad
Old 04-07-2009, 06:13 PM
Rev It Up Champ
Wow! Talk about bringing a thread back from the dead!
Ok, the easiest and most simple thing you can do about this swap. Since its been years and I've tried and tested just about everything with my E21 and the S14 engine.
In its most basic form, the S14 is a modified M10 engine. Use the M10 engine mounts and brackets and bolt them to the S14 engine for that part.
Have your stock E21 transmission bell housing modified to accept the motronic sensors. Call up Aardvarc Racing in Cali, they have the equipment necessary to do the modification and its reasonably cheap. Home You want their M2 kit.
By doing this, it saves you a ton of modifications necessary to the body and drivetrain of the car. It also allows you to retain the stock speedo cable, so you don't have to go crazy with more modifications to make that work.
Depending on what year your car is, you will need the later brake master cylinder, which is shorter length wise and allows the intake tube to pass it perfectly into the intake manifold.
You will need to fab up a bracket to hold the air flow meter in place.
As far as the wiring goes, that's the real headache. At some point I did make a harness chart and posted it somewhere here or on bimmerforums. If you do a search, I'm sure you can find it. Otherwise I might still have it on my computer somewhere.
The exhaust system is another story. The stock manifold and downpipe fit the E21 fine. The rest of the exhaust system needs to be changed. I bought a used/damaged E30 M3 cat section and cut off the X pipe area and converted it to a Y pipe allowing use of a single exhaust from the cat back.
Good Luck!
Successories: "A Bend In The Road Is Not The End Of The Road.... Unless You Fail To Make The Turn!"
www.myspace.com/gjdixon
www.gpny.com
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737 738 739 740 741 742
