| sounds like the alternator stop working and you drove till the battery died. there is a main ground on the 2.7 under the air box body to oil pan. mine also has a small one by the exhaust valve cover gasket to tray area but my friends eta does not have that one.
__________________ e36 silencer's out, rims,M3 cams sway bars and springs front and rear, zimmermen crosdrilled rotors, comming soon a real intake, exahust, chip. lapped PIR @ 1:36.5 w/o cams ITA E30 325e 1:33.3/ PR 1:44.8 |
| Thanks for letting me know where the main ground was. I found it completely broken off on the oil pan side! I replaced the ground wire and got the engine to turn over. It will run for about a minute before it starts to idle badly and die. Replaced the plugs because they were bad. Tried again and the same thing, runs good for a minute or so then gets the shutters and dies. Any Ideas? |
| since you said you replace the starter wat you could of done is theres two wires that connect right there on the positive side of the starter one goes to the alternator and if its not connected or had a good connection your battery won't charge causing your car to die! so if your battery is low everytime! that is your problem and if not the start your car and check the voltage of the batter while car is running it should be 13.7 to 14.5 if its any lower than that you got a bad alternator or a bad connection on the starter to the alternator |
