Go Back   DTMPower BMW Forum > Technical Discussions > E30 3-series and prior
Old 09-26-2008, 02:09 AM
Rides:325es
positas123 is a New Registered Member
E30 best value performances options (after 23HP increase)?
I bought my 1989 325i cabrio just last November and have been enjoying it immensely as an everyday driver. I’m a student and don’t have too much money to throw at it, but I have increased the performance with a chip (off ebay), K&N filter and Signature Motoring heat shield. All in all this stuff was less than $200.00 and gave me a whopping 23 HP/19ft/lb torque increase on the dyno. (The Signature Motoring performance intake was actually in first and gave 8.3HP increase and the chip did the rest; except the chip w/stock intake only have +11 HP instead of the 18-20 advertised). Either way I’m happy and the car feels a lot lighter and responsive.
My next step is a performance exhaust. I’ve got maybe $450 to spend. Can I get something decent for this? Does anyone have tried/true recommendation? If anyone has something for sale, I'm interested. I would need something street legal and bolt on that doesn’t require any custom welding jobs. Thanks!
Old 09-30-2008, 06:07 PM
Rides:'91 318is E30
Reign is a New Registered Member
I've been thinking about getting an exhaust as well (after my tires and rims since I just bought my car for 2k from a customer). Although, I have gotten many compliments on the stock exhaust and the performance of the stock exhaust is great as is so it's not a top priority for me.
So if there are any upgrades besides an ECU or filter that are cheap and do make an actual improvement, let us know
Old 09-30-2008, 10:52 PM
austra's Avatar
C.S.C.C. Instructor
Rides:96 328i and 88gt 5.0 86 325e
austra is a New Registered Member
a diff swap. the next number set high like 4.10 are better then 3.73 for the 2.5 and you can find 4.36 for the 1.8 and 3.25 for the 2.7e
e36 silencer's out, rims,M3 cams sway bars and springs front and rear, zimmermen crosdrilled rotors, comming soon a real intake, exahust, chip. lapped PIR @ 1:36.5 w/o cams PIR ITA E30 325e 1:33.3 PR 1:44.4 thunderhill 2:10.1
Old 10-03-2008, 03:58 AM
Rides:88 325ix
combustion is a New Registered Member
What about a header, and maybe some 19# injectors
Old 10-14-2008, 09:18 AM
Goya20's Avatar
Rides:BMW, 325, 1987
Goya20 is a New Registered Member
where did u get your chip from? from what seller i mean? im thinkin of chippin mine.
Old 10-14-2008, 11:14 AM
Rides:1990 BMW E30
R3CKL355 is a New Registered Member
Hell.. i just gutted the cat, not sure how much of an increase, because im not dropping $200 to use my friends dyno, but im sure it will help just a lil,
Old 10-14-2008, 07:46 PM
j.amrol's Avatar
Rides:85' ETA, 86' ETA sport
j.amrol is a New Registered Member
Dude think for just one second... An engine steadily decreases in performance along it's life span.
Technically you gained way more (over what you had), rather than what was gained over off the lot rating. So your doing good.
You also have access to a dyno which is real good (custom ecu's are possible, deleting the afm too). Now port your intake, and head.
There's no need for upgraded injectors until you hit turbo.
Do the diff swap! no hp/ tq increase but acceleration is the key.
Replace the pistons with high compression pistons & have the block bored/honed, and new rings (or at least new rings will bring you back to off the lot performance at the least + your upgrades)
Diagnally parked, in a parallel universe.
Specifically integral parts as if a machine we're speaking,
or on drugs and we're peaking.
Living slow but constant.
Seemingly meaningless peices
if thrown stray your whole operation will seize.
No one ever said life was easy.
Old 10-17-2008, 03:54 PM
Rides:BMW 90' 325i 4 door
theoz2106 is a New Registered Member
You can get an exhaust for 250 to 500 and more but if your car is a manual then u can get headers,if it's an automatic you can't there is not enough clearence...Your on a tight budget and you want more,I recommend tune up the suspension,shocks(bilstien),springs(Eibach,BAV auto),Swaybars(bav auto,eibach),Strut tower bars front and rear,plus a urethane bushing kit front and rear,plus some steel braided brake lines maybe brake rotor upgrade or big brake setup and you will see that stock or even a little extra hp in these cars goes a long way when you have precise control over it....Hope this helped,if you want here are some reference sites....
BMW Parts and BMW Accessories | Bavarian Autosport
BMP design : BMW Parts, BMW Accessories & BMW Replacement Parts.
101 Projects forYour Porsche 911 - How to Rebuild Your Porsche 911 Engines (1965-89)
101 projets u can find for E30's and beyond,not only pics,but tech sheets and products and prices.......
Oz
Old 10-28-2008, 02:58 PM
StarkeyT22489's Avatar
E Dirty
Rides:87 E30 325ES
StarkeyT22489 is a New Registered Member
if u can weld then just make your own. get rid of the cats and the resantors and get a high flow muffler. and you will maybe spend 250. but depending on how loud you want it depends on how much you cut out. because my car is straight piped all the way back to the muffler and its pretty loud. but its worth it i love the sound.
Dream as if you will live forever, live as if you'll die tomorrow.
Old 10-29-2008, 12:16 AM
Rides:bmw, 87, 325 is 95 325is, 97 328i
EgMpower is a New Registered Member
me myself in my car i have a ported and polished head, and am about to port match the intake manifold and bore out the throttle body,
so unless you willing to spend 1,000 for a port and polish job on your head, then you should just get headers and port your intake manifold to give it extra airflow, now since you chipped your car, a vaf to Maf will really help you gain some hp will your bolt ons.
as in getting injectors... its not neccessary at all unless you turbocharged.
differential, it depends on the gear ratio, you don't gain any hp or torque it changes how fast you can get to your top speed. 4.10 will be more acceleration, which will equal to shorter gears and 3.25 will equal to longer gears less accelelration but the fact that you can hit 90 mph on your third gear! =D
Open for Mothers Day Dinner
1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 17 18 19 20 21 22 23 24 25 26 27 28 29 30 31 32 33 34 35 36 37 38 39 40 41 42 43 44 45 46 47 48 49 50 51 52 53 54 55 56 57 58 59 60 61 62 63 64 65 66 67 68 69 70 71 72 73 74 75 76 77 78 79 80 81 82 83 84 85 86 87 88 89 90 91 92 93 94 95 96 97 98 99 100 101 102 103 104 105 106 107 108 109 110 111 112 113 114 115 116 117 118 119 120 121 122 123 124 125 126 127 128 129 130 131 132 133 134 135 136 137 138 139 140 141 142 143 144 145 146 147 148 149 150 151 152 153 154 155 156 157 158 159 160 161 162 163 164 165 166 167 168 169 170 171 172 173 174 175 176 177 178 179 180 181 182 183 184 185 186 187 188 189 190 191 192 193 194 195 196 197 198 199 200 201 202 203 204 205 206 207 208 209 210 211 212 213 214 215 216 217 218 219 220 221 222 223 224 225 226 227 228 229 230 231 232 233 234 235 236 237 238 239 240 241 242 243 244 245 246 247 248 249 250 251 252 253 254 255 256 257 258 259 260 261 262 263 264 265 266 267 268 269 270 271 272 273 274 275 276 277 278 279 280 281 282 283 284 285 286 287 288 289 290 291 292 293 294 295 296 297 298 299 300 301 302 303 304 305 306 307 308 309 310 311 312 313 314 315 316 317 318 319 320 321 322 323 324 325 326 327 328 329 330 331 332 333 334 335 336 337 338 339 340 341 342 343 344 345 346 347 348 349 350 351 352 353 354 355 356 357 358 359 360 361 362 363 364 365 366 367 368 369 370 371 372 373 374 375 376 377 378 379 380 381 382 383 384 385 386 387 388 389 390 391 392 393 394 395 396 397 398 399 400 401 402 403 404 405 406 407 408 409 410 411 412 413 414 415 416 417 418 419 420 421 422 423 424 425 426 427 428 429 430 431 432 433 434 435 436 437 438 439 440 441 442 443 444 445 446 447 448 449 450 451 452 453 454 455 456 457 458 459 460 461 462 463 464 465 466 467 468 469 470 471 472 473 474 475 476 477 478 479 480 481 482 483 484 485 486 487 488 489 490 491 492 493 494 495 496 497 498 499 500 501 502 503 504 505 506 507 508 509 510 511 512 513 514 515 516 517 518 519 520 521 522 523 524 525 526 527 528 529 530 531 532 533 534 535 536 537 538 539 540 541 542 543 544 545 546 547 548 549 550 551 552 553 554 555 556 557 558 559 560 561 562 563 564 565 566 567 568 569 570 571 572 573 574 575 576 577 578 579 580 581 582 583 584 585 586 587 588 589 590 591 592 593 594 595 596 597 598 599 600 601 602 603 604 605 606 607 608 609 610 611 612 613 614 615 616 617 618 619 620 621 622 623 624 625 626 627 628 629 630 631 632 633 634 635 636 637 638 639 640 641 642 643 644 645 646 647 648 649 650 651 652 653 654 655 656 657 658 659 660 661 662 663 664 665 666 667 668 669 670 671 672 673 674 675 676 677 678 679 680 681 682 683 684 685 686 687 688 689 690 691 692 693 694 695 696 697 698 699 700 701 702 703 704 705 706 707 708 709 710 711 712 713 714 715 716 717 718 719 720 721 722 723 724 725 726 727 728 729 730 731 732 733 734 735 736 737
